Question about Evesham Emedia Ebox (EBOXAPR04) PC Desktop
Ebox fails to load up
1- When I press the on/off button the ebox comes on and displays the image of the CORE CELL logo (this happens within the first 10 seconds of turning the ebox on.
2- After this the monitor starts to flash as if it is turning on and off repeatedly. This is as far as the ebox loads up to.
3- The ebox fails to get to the windows XP logo screen.
Any one know what the problem is???
Thanks for your help in advance.
  • simongautrey May 13, 2009
    I have this problem. A PC engineer has told me that the motherboard - K9mgm-2 ms-7252 version 1.2 is failing. The problem is now to find a replacement motherboard as it needs to have an infrared connector and media output socket at the rear. I have contacted the recommended service partner for Evesham below.
    Sniper:
  • 62 Answers
Evesham is no longer in business but the following url is for a company that supports their products..
http://www.tewktech.com/
As a matter of fact, I understand this company has ex-Evesham employees. Good Luck and please rate this solution .....
Posted on Mar 27, 2009
Wont load software
you may have to do a factory reset. With the device turned off, press and hold the volume down button, and then briefly press the power button. - Wait for the screen with the three Android images to appear, and then release the volume down button. - Press volume down to select clear storage, and then press power. - Press volume up to start the factory reset.
Mar 16, 2014 | RCA Tablets & eReaders
My son changed the password on Samsung Focus phone and is locked out because he cant remember the new password. It keeps saying he is locked out for 2 hours until we can try again when incorrect code is...
If you're still stuck. More then likely the only thing to do is a factory reset, I locked my own self out of the phone within the first 20 minutes I had it. Only after a certain amount of incorrect inputs, it put a time limit, and at the end of the time, every failed attempt doubled the amount of time I had to wait. You will lose everything on your phone if you do you do this.
1. Press and hold the Camera, Volume Down, and Power buttons simultaneously.
2. Release Power when the phone vibrates, but continue to hold down Camera and Volume Down.
3. Release Camera and Volume Down when the Format prompt is displayed on screen.
4. Press Windows logo.
5. Press Windows logo again to confirm the hard reset.
This is exactly what I did, and it worked.
Feb 05, 2011 | Samsung Focus i917 (8 GB) Smartphone
Windows starts to load, but sticks and does not finish.
this problem is mostly due to viral problem you can try these in ORDER 1)you can restore ur data by restoring your pc by pressing F8 when it displays the acer logo then select repair computer there > enter password > select system restore>select the required restore point(or you can choose system image recovery if you r already created a system image)
2you need reinstal your windows To reinstall *insert windows disk *press F12 when acer logo appears>select boot from dvd/rw>press any key to start installation follow the instructions....
Dec 29, 2010 | Acer Aspire One PC Notebook
I have Nokia 3110c. When I switch it on, NOKIA logo comes, screen flashes 3 times with white blank screen and goes off. It never comes again. It happens every time I press power on button. There is no...
Possible that the software of the phone is corrupt or a possible hardware is defective.
You can remove the battery and memory card, have the card scanned for virus. replace battery after 15 minutes so that the phone is reset.
if the phone wont boot back the services of the Nokia support must be sought for reinstalling the software.
Oct 23, 2010 | Nokia 3110 Cellular Phone
My iphone display nothing on screene when i start it shows only image of apple
If this will not boot at all try plugging it to your computer and see if iTunes can do a restore.
If this fails try putting your iPhone device to recovery mode by doing the following steps:
  1. Plug your USB cable into your computer.
  2. Turn your iPhone off by holding the power button down until you see “slide to power off”. Do as instructed.
  3. Now press and hold the Home button while reconnecting the USB cable to your iPhone. After iPhone is connected it should power on the device.
  4. Continue holding the Home button, you will see the Apple logo appear and then finally a “Connect to iTunes” will be displayed, now is the time to release the Home button. You will then see the following image:
Aug 07, 2010 | Apple iPhone 3G
My MacBook turns on, but stays on a white screen and does not load the OS. Any ideas how to fix?
Dose the apple logo comes and the spin or no ?
if its coming permission issues
if dosent come the apple logo and the spin then please reset the eprom
by pressing command +option+p+r and press the power button to on and wait till you listen three times the chime the third time release all the button and say hello to your Personel desktop
thanks
Apr 18, 2010 | Apple 13" MacBook Notebook Computer ...
My iphone wont load up i did a reset on the phone to factory settings and now when it cuts on its stuck on the apple logo
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Sep 23, 2009 | Apple iPhone 3G
My iphone is disable
Step 1: Turn off your iphone
Step 2: PRESS & HOLD home button, then PRESS & HOLD on/off button on the top
Step 3: DONT release both button, untill u see Apple logo display, then release the on/off button, in the meanwhile still HOLD the home button aorund 30 sec.
The display will come out a screen, it showed USB & iTunes logo.
Step 4: Open your iTunes, RESTORE. FINISH & DONE.
Jul 27, 2009 | Apple iPhone 3G Black Smartphone
Sansa e200 load main image failed
If this happened after updating your firmware, the Sansa FAQ from here http://www.sansa.com/support/sansa_e200/faqs says try this -
03. "Load image failed" appears after updating e200 firmware Applies to the following Operating Systems:
  1. Windows XP, Vista
This error may be caused by the firmware failing to load or the file system is corrupted.
STEP 1 – Reset the player
  1. Press and hold the Power button for approximately 30 seconds.
  2. Turn the player back on.
If the error persists, proceed to steps 2 and 3.
STEP 2 – Connect the player in Recovery Mode
  1. Turn off the player.
  2. Slide the Hold/Lock switch on top of the player so an orange color is showing.
  3. Press and hold the REC button and connect the device to the computer.
  4. A message will appear on the device display screen confirming the connection and a 16MB partition will be viewable in My Computer.
  5. Release the REC button.
STEP 3 – Download and update the firmware
  1. Download the firmware from the Sansa Forum.
  2. Open the zip file
  3. Extract all the firmware files to the 16MB-FORMAT drive.
  4. Disconnect the player.
  5. Slide the Hold switch to the unlock position.
  6. Turn on the player
Dec 29, 2008 | SanDisk Sansa e200 MP3 Player
Evesham Emedia Ebox (EBOXAPR04) PC Desktop Logo
119 people viewed this question
Top Evesham Computers & Internet Experts
Simon Clarke
Level 1 Expert
Lakshman P
Are you an Evesham Computer and Internet Expert? Answer questions, earn points and help others
