Question about BenQ Office Equipment & Supplies
Benq w1000+ turns on ok, but shortly after screen starts strobing brightly, then shuts down. red and green lights come on projector and sometimes(but not always) fan starts blowing frantically even when turned off. leave it for a while, and sometimes it works fine, other times it does the same thing again.
dhiman
  • 115 Answers
SOURCE: LCD shutting off automatically
The problem comes in the Lamp unit generally. check the condition of Lamp.
Viren
Posted on Nov 19, 2007
Marrie
  • 563 Answers
SOURCE: Green light flashing and then shuts down
Hi Gary
Have you resetted the lamp timer ? It must be done when a new lamp is inserted into the unit.
You can reset the lamp timer by holding the up arrow key on the Projector in until a online message appears. Then just follow the on-screen instructions.
If the problem persists , you will have to replace the Ballast wich is the lamp's power supply.
Posted on Mar 25, 2008
Had the same problem with PB2140, during startup the lamp went off and power and lamp leds turned on. This happened after the projector fell down. I read a post there hat mentioned it was probably the power supply so i disassembled the projector. I found out that a small transistor of the power supply was torn away but it was still inside the projector. I found it, put it back and the projector works just fine. Thanks!
Posted on Oct 29, 2008
Marrie
  • 563 Answers
SOURCE: benq 8250 projector shuts down
Hi david115
I've had this problem MANY a time before and what BenQ does wrong is that they only replace the two main fans at the back of the PB8250 , they should in fact replace both the fans and the Mainboard. This is unfortunately the only way to get around this problem.
Posted on Dec 12, 2008
projdoc
  • 2237 Answers
SOURCE: my benq projector turns on for a few minutes
if it goes through shut down mode (lamp first and fans run a while), reset the settings to factory default. while you're in the menu, check the lamp hours (under settings). if they're close to 2000 hours, replace the lamp. if the projector shuts down immediately, fans and all, you have a power supply problem. you'll need to replace it.
Posted on Nov 30, 2009
Benq pe8720 service manual
8720 Went out just prior to playing. Now will start up, go to benq logo then lamp goes off. on top of projector lamp light is red. repeat lamp does go on seems as bright as ever but shortly after benq logo goes off. By my recollection lamp is not beyond it's 2000 hour range.
Feb 18, 2012 | BenQ PE8720 DLP Projector
Benq w1000 project not turning on
Look at the manual page 34, for the indicator messages. I suspect it's the same problem I have (which I haven't had formally diagnosed yet!), which I believe is a defective fan. My projector had been making a really loud noise on startup, which varied in length and volume. Recently the projector has taken to turning itself off after being on for about a minute, and the power light flashes green, with the temp and lamp lights flashing red.
Jan 27, 2012 | BenQ W10000 Projector
How do I flip the screen when I mounted it upside down?
Page 14 in the manual
http://www.projectorcentral.com/pdf/projector_manual_5038.pdf
Jul 05, 2011 | BenQ W1000 Home Entertainment Projector...
Benq Projector MP721 stops illuminating after about 1 minute on. The lights are as follows: Power: Off, Temp: Red, Lamp: Green. Shortly after the projector shuts off. Thoughts?? My assumption is that the...
it might be dusty enough to hold in the heat. it needs a good cleaning. use canned air. if you still have an issue, the fans might be running too slow or the thermister (temp sensor) may be faulty. sometimes if it gets too hot in there, the thermister needs to be replaced, too.
Sep 11, 2009 | BenQ MP610 Multimedia Projector
Projector shuts down after turned on and both red lights blink
this model is prone to over heat. look near the lamp for the temp sensor it is most likely bad
Nov 30, 2008 | BenQ PE7700 Multimedia Projector
PB6110 Powers down after 30s, splash screen appears, red temp lig
Be sure to check the filters and make sure you have good airflow thru the proj. Cleaning filters solved our temp shutdown problem.
Nov 17, 2008 | BenQ PB6110 Multimedia Projector
Hi Gary
Mar 16, 2008 | BenQ MP610 Multimedia Projector
Hi there
Check if your blowerfan that cools the lamp - sits in front of Projector is running.
Nov 06, 2007 | BenQ PB2140 Multimedia Projector
Viren
Oct 01, 2007 | BenQ PB6100 Multimedia Projector
Top BenQ Office Equipment & Supplies Experts
Tom Chichester
Computer Links
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
