Question about RCA D52W19 52" Rear Projection Television
LC401EM3F Digital Television comes on screen then shuts off
Television won't work
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Before going further; try a hard reset first. If it does not help you, replace the main digital board. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; visit the site linked here.
Aug 16, 2016 | Emerson Televison & Video
40" LCD TV LC401EM3F, went off. Will not come back on.
The main power supply regulator board should be checked and replaced. If you are not familiar with electronics, do not attempt to repair. Whether you suffer fatal electrical shock! Instead, contact the nearest service center.
Feb 19, 2013 | Televison & Video
Tv wall mount screw size for a emerson LC401EM3F
The instructions say that it calls for M8 x 1.575" (40mm) screws.
Nov 23, 2012 | Emerson Televison & Video
Screen comes on but then shuts down after a few seconds
Something short circuit is there at it main digital board.
Sep 27, 2012 | Soyo MT-SYTPT3718AB 37 in. LCD Television
My remote will not allow the tv to come on and stay on. screen says digital television and goes off. why?on. the tv will say ditigal television and the go off. why?
Do a factory reset to this TV. Refer its user manual for details. Just do a hard rest too. To make it hard reset, unplug the TV from AC mains wall outlet, and re-plug it after 10 minutes or so.
Jun 22, 2012 | Philips Magnavox 13MT143S 13" TV
The closed capioning will not come off the screen. I went in the tv menu to shut it off but the tv menu says it is off but the words are still coming up on the screen
If you are getting your broadcast signal by way of a digital satellite or a digital cable box, you will need to access the menu(s) within them to turn off the (CC) closed captioning. I have had times when I had to contact the satellite or cable co. to have them help me get into their "special" menu to shut this off. Good luck !
Jan 04, 2010 | Vizio P2 42 in. HD-Ready Plasma Television
Akai lct 2701td comes on then shuts down
Hi
You have power supply problem. Please go to ebay and buy cheaper price:
AKAI LCT2701AD POWER SUUPLY MLT166A
Thanks
GEORGE
Mar 11, 2009 | Akai LCT2715 27 in. LCD Television
Sony 52" flat screen will shut off and then come back on. What is the problem?
please mention exact model number of your Sony 52" tv to provide you help.
Oct 23, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA D52W19 52" Rear Projection Television Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
