Question about Olympus Safe Hot Shoe to PC Sync Flash Adapter cat No.200329
Olympus e510 hot-shoe doesn't respond...
few days ago i've noticed that my flash unit fl-50 won't trigger when attached to Olympus e510 dslr camera...
i think that the problem is with camera's hot-shoe slot because the flash triggers off the camera with the wireless transmitter test button (and, of course, reciever attached on the flash)
the flash unit sits perfectly in the hot-shoe of the camera, but for some reason doesn't recieve the shutter information from the camera
thnx for your help,
sincerely
D.
  • tommyfodo Apr 04, 2009
    I have the same prob with my olympus evolt 5 series digital cam. As it sits right now the pop up flash is released and readied for action whenever I attach the flash unit to the hot shoe. The hot shoe came completely off last week. I tried re setting with super glue but I still have to tilt the flash in strange directions once it is attached in order to get it to fire. Most times it doesn't and the built in flash just reacts as if I don't have another unit attached. I think that the hot shoe's connection to the camera info center is completely severed. Help!
Sadly I think the problem is a design fault. Simply put the pins don't align accurately when you slide the flash unit on and lock it into position. There is slight misalignment, even though the locking pin has slipped into the slot.
I have had an absolute nightmare with the hot shoe on my E-510, and it took me ages to figure out what the problem was, having cleaned the contacts to within an inch of their lives!.
When you slide the flash on and lock it the pins don't connect accurately with the plates on the hot shoe plate. The only way I can get the **** thing to communicate with a flash unit or flash extension cable is to slide it on, partialy lock it and start gently wiggling the flash unit backwards and forwards until the flash icon on the menu screen lights up, then quickly finish the locking procedure.
Even that, though, doesn't guarantee consistent communication with the camera. Swinging the camera up and down between shots often jiggles the contacts out of alignment again and suddenly the flash won't fire again, neccesitating a repeat of the whole wiggle method. Often I have to turn camera and flash off and reboot everything again because once the camera loses communication it won't talk to the flash even when it's correctly realigned. It's either bad design or poor manufacture, but whatever it is it's a huge nuisance.
Posted on Oct 27, 2011
    Problem Solver:
  • 7 Answers
Have you tried cleaning the hot shoe contact? If the contact is dirty it may not communicate with the camera. The "contact" Its the metal "circle" in the middle of the hot shoe. Using a pencil eraser, rub the contact gently until you create eraser crumbs, then gently rub the "circle" with a soft cloth. See if this fixes it.
Posted on Mar 16, 2009
How do you synchronize a non olympus flash unit to an olympus e 500
Install flash on hot shoe and use shutter speed on camera set to no faster than 1/125. Read the owners manul for flash AND camera. Be careful, some trigger voltages may be higher than what your cdamera can handle and may ruin internal flash usage, if not camera itself. better to use a Wein Safesynch hot shoe. This mounts ion hotshoe of camera and flash is attached to this.
Dec 30, 2010 | Olympus EVOLT E-500 Digital Camera
Hot shoe
If the flash is not sitting securely on the hot shoe when attached to the camera you may want to send the camera body to Olympus repair center for service. Their telephone number is 800-622-6372 option 2 and then option 3 to discuss the repair process and pricing if needed.
Dec 29, 2008 | Olympus EVOLT E-500 Digital Camera
Olympus FL36 flash unit
Hey I have an E510 and an fl 36 flash unit and no problems for a year now.
And no problems at all {knock wood]!
Have you checked to see if all the flash pins are making contact?
Normally I only turn my flash on after I put it on the camera and then turn the camera off and then on again to see if everything is ok. I remember the flash would not communicate with the camera on a shoot and after a while I realized that the flash was not all the way in the hot shoe. Fool around with the flash off the camera first and see. The flash have modes that you have to set up if the mode is set in full manual that might be a problem. There is a button that you have to hold down for three seconds to get in the menu, Get hold of your manual or download one My buttons are fine and have not faded any at all. I realize that the power button an the flash is hard to press on, I do hope I was of help .GOOD LUCK
From Chris
May 29, 2008 | Olympus FL-36 TTL Flash
Connect an flash and aftermarket bracket
When using an external flash with the C-8080 Wide Zoom, you will need the appropriate flash cable with your flash and aftermarket bracket. The Hot Shoe Flash Cable (FL-CB05) mounts to the C-8080 Hot Shoe and the opposite end attaches to the aftermarket flash bracket’s flash shoe or to a standard tripod attachment thread (1/4x20).
Sep 04, 2005 | Olympus Camedia C-8080 Wide Zoom Digital...
Connect an FL-20, FL-36, FL-40 or FL-50 external flash
The FL-20, FL-36, FL-40 or FL-50 external flash can be attached directly to the hot shoe on the camera. You also can use the FL-BK01 Flash Bracket and the FL-CB02 Hot Shoe to TTL cable.
Connect these external flashes...
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-770 Zoom. FL-CB02 Hot Shoe to TTL Cable - this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-770 Digital Camera
Connect to external flashes
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-770 Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-765 Digital Camera
Connect a FL-20, FL-36, FL-40 or FL-50 dedicated external flash
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket - used to mount an external flash to the C-750 Zoom. FL-CB02 Hot Shoe to TTL Cable -this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-740 Ultra Zoom Digital...
The FL-20, FL-36, FL-40 or FL-50 dedicated external flash can be attached directly to the hot shoe on the camera. To use the FL-20, FL-36, FL-40 or FL-50 flash off-camera, you will need a bracket and appropriate flash cable. Please use the following information as a reference: FL-BK01 Flash Bracket (item #200666) - used to mount an external flash to the C-5060 Wide Zoom. FL-CB02 Hot Shoe to TTL Cable (item #200663)- this cable is required for the dedicated FL-20, FL-36, FL-40, or FL-50 flash.
Sep 04, 2005 | Olympus Camedia C-5060 Wide Zoom Digital...
Flash cable
The FL-CB05 Hot-shoe to Hot-shoe flash cable is approximately 3 feet (1 meter).
Aug 31, 2005 | Olympus Camedia E-20N Digital Camera
Olympus Safe Hot Shoe to PC Sync Flash Adapter cat No.200329 Logo
375 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
