Question about Honda 84 Magna V45 Vf700 C Vf700c Generator Stator Coil
Backfire on acceleration, lack of power - Honda 84 Magna V45 Vf700 C Vf700c Generator Stator Coil
Hard to start, lacks power, backfires, checked for intake leaks, none.
lacking power might indicate cat is plugging up . backfiring might be timing is off a little .
May 16, 2016 | Cars & Trucks
My ed falcon 5.0l runs but won't rev & lacks power Have replaced air flow meter as it runs better with it did connected Checked computer for damage & condensation & foreign debree But can't find the...
have the fault codes read as it may be a combination of faulty sensors causing the problem. The ECM fault reporrting process is there for a purpose and that is to pinpoint the fault and to save money.
Jan 24, 2015 | Cars & Trucks
Blown turbo 2005 Chrysler PT Cruiser
indicates a turbo failure
remove it and have it overhauled/inspected
Oct 18, 2017 | 2005 Chrysler PT Cruiser
97 kia sephia, replaced battery, plugs, wires, cap, rotor, air filter, fuel filter, added heet water removal and lucas fuel injector. It sputters, backfires/pops when accelerating and it has no power,...
As you have replaced all the obvious things that could cause the symptoms it may be a good idea to have a cylinder compression test done , if comes back OK i'd try a fuel addative , one that covers the catalytic convertor , as there are many sensor's involved in the fuel/exhaust system as you know , this addative will clean any residue affecting there reading's , hope this helps
Apr 06, 2017 | 1997 Kia Sephia
On my 1999 chevy siverado 5.3 vortex engine on acceleration backfires at about 3000 rpm. Engine ides rough when heater controls or air condition is on.
Sounds like you have a bad spark plug or wire.It may even be a bad injector .
Symptoms of lack of power under load
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
Backfiring on acceleration of a 2002 GMC with 6.0 Engine
Backfires are usually caused by a lack of fuel...change the fuel filter. Also very old spark plugs (or plugs gapped to wide ) will cause this problem.
Jun 13, 2009 | 2002 Chevrolet Silverado
Lack of power
You may either have a partially clogged Catalytic converter or you may have a MAF Sensor (mass airflow sensor) going bad. When it seems to loose power, does it want to backfire through the intake? If it does, most likely the MAF Sensor is going bad. If the car seems to drive just fine at first then starts loosing power gradually while you're driving, the Catalytic converter is most likely partially clogged.
Sep 17, 2008 | 1998 Mercedes-Benz C-Class
Honda 84 Magna V45 Vf700 C Vf700c Generator Stator Coil Logo
20 people viewed this question
Top Honda Electrical Supplies Experts
John Trevino
Are you a Honda Electrical Supply Expert? Answer questions, earn points and help others
