Question about Garden
Sears 917.271021 Riding Lawn Mower
I have replaced the carburetor and fuel solenoid. After the mower starts there is gas coming out the muffler due to excessive gas being dumped into the intake.
thabrain
  • 76 Answers
SOURCE: murray riding lawn mower
with switch off try crossing out the solenoid. take an old screwdriver and place it on the two metal contacts jetting out from the solenoid usually by the battery or close to the ignition. if strarter engages when this is donr replace solenoid. if not replace starter. hope this helps.
Posted on Oct 28, 2008
boscia
  • 163 Answers
SOURCE: Replacement of gas tank on a Sears GT3000 riding mower
if theres no leak yet you can easily patch it with an epoxy puddy, available at your local auto parts store. i've used it myself on gas tanks, radiators, boats and its never failed me yet
Posted on Nov 30, 2008
  • 376 Answers
SOURCE: Poulan ride on lawn mower will not run by itself--if you pour gas into the intake it will run until the sm amt runs out
It could be your fuel shutoff solenoid is not working or is stuck from gum, varnish or rust in your carb bowl. The fuel shutoff solenoid is located on the bottom of your carburetor. To check it, have someone, or yourself if you can reach the ignition switch, turn the key to the on position and back off several times while you listen by the carb. You should hear a click each time. If not, the carb will have to be taken off and cleaned and checked. You will probably find water and/or rust in your bowl plugging up the main jet. Best to take it to a shop.
Posted on May 16, 2009
panilling9
  • 284 Answers
SOURCE: gas coming out of exhaust is it the carburetor and why
carb. float stuck open
Need to remove carb. replace float needle valve and possibly the needle valve seat,
change your oil also
saturated with fuel
Posted on May 25, 2009
  • 73 Answers
SOURCE: mower won't start
im sure the switch is bad, trying to jump is a good way to find out if the starter is bad but of course wont start cause of no spark, alot of these have electronic magnetos
Posted on May 28, 2009
A lawn mower that gas comes out of the exhaust.
It sounds like the float in the carburetor is stuck in the open position.This will allow fuel to flow through the carb and out the muffler.
May 04, 2015 | Garden
Why does the engine quit running after it gets hot?
You might want to try this one but pricey thing, replace the carburetor! I have a 2008 Sears DTY 3000 25 HP two cylinder Briggs and Stratton Engine, I struggled for a year and half if it quitting when it gets hot. I replaced everything, Gas Cap, ignition module, fuel lines , filters , spark plugs, gas tank, exhaust / exhaust manifold and it all did not help. Due to the acidic (Alcohol added to the fuel) gas two the rubber inner control gaskets disintegrated causing "vapor lock" when the engine got warm/hot. Replace the Carb and then put additive into the fuel.
Oct 13, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
My husqvarna kohler yth21k46 is 2 days old and i turned it on ran for 20 mins and smoke came out from engine gas leaking from bottom of the air cleaner thought it was going to explode . what should i...
After reading your question it sounded like the smoke was due to fuel leaking on the muffler and or excess fuel entering the combustion chamber. I would due the following diagnostic. In a quite area turn on the ignition switch. You should hear the metallic click of the fuel cutoff solinoid on the carburetor.
Mar 20, 2012 | Husqvarna Riding Lawn Mower 46 Cut Kohler...
Bought this lawn mower.It was sitting for two years and now it won't start.
first things first:
1) make sure that the kill for the magneto/coil is breaking contact( it is on the side of the mower,follow the cable down from the red bar)
2) gas to carburetor
3) spark to plug/s
4) gas to cylinder/s
pull plug and try starting mower, observe spark plug for spark and fuel coming out of cylinder/s. if spark no gas, then check to see if it getting to the carburetor, if it is then it is the float and seat in the carburetor and will need to be cleaned/replaced/rebuilt. Or just simple pour gas into the carburetor and try starting if it starts then it is the fuel line, carburetor. Hope this helped Tim
May 22, 2011 | Garden
My starter will turn the engine however, it will not fire. already replaced fuel filter, air filter, plugs and battery. any suggestions. prior to this happening the mower would start and run then the...
Do you have a fuel shut off solenoid on the carburetor? If you do there will two wires going to a solenoid on the bottom/bowl of the carburetor. You need to make sure this is working properly. You may also have some debris or blockage in the main metering jet in the carburetor. Hope this offers some type of help.
Feb 17, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
I have a 7 year Craftsman 17.5 HP 42 in. lawn tractor. It starts to leak gas recently and stops frequently after running over 30-40 minutes. I can not identified where is the gas leak from but I saw gas on...
I have a Craftsman mower. Last year I had a similar problem with the mower stopping after running awhile. I noticed that the plastic gas tank was collapsing. The next time it began to stall, I immediately loosened the gas cap and it didn't stall. The vent holes in the cap had plugged up. Check this out.
I can't help you locate the fuel leak, although it sounds like the carburetor float is not stopping gas from flowing into the carburetor.
Dec 02, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Have troy bilt riding lawn mower engine is not getting gas through carb. what is the solenoid thats attached to the carb?
That is the fuel solenoid that allows gas to get into the carburetor when it starts up. The fuel solenoid opens up when the key is turned on to allow fuel into the main jet of the carburetor.
go to www.precisionope.com, you should be able to find an Illustrated parts list on the engine.
Sep 28, 2009 | Troy Garden
Murray riding mower 12.5 hp briggs & stratton spitting oil & gas out of carb & muffler when trying to start
Drain oil... it is full of gasoline due to a bad float pin and rubber gromet in your carb. When your float pin and gromet fail, gas just keeps flowing into your carburetor, eventually flooding your motor with gas and oil mix.
Jul 07, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
john h
