Question about Xerox Phaser Office Equipment & Supplies
Scan error 027-519
Everything works great with this machine-I just need to know what to touch to get the scan to work. It's set up correctly
2 Suggested Answers
Dinoza
  • 112 Answers
SOURCE: HP All-in-one will not scan
I think I have the solution for you (after facing similar problem). Try installing the drivers and then go to my computer right click on the HP and select "Scan using wizard". My HP is able to scan using this method although I still can't scan using the button on the printer so if you don't mind clicking the mouse instead of the printer's button you should be fine. Let me know if it worked. Cheers, D.
Posted on Jul 14, 2007
My HP 8600 Premium no longer sends or accepts FAXes. It says it's connecting, but never does. And returns error 344. I know the other fax machines are working fine. Please advise.
Here's a document that explains some on the fax error codes: http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?objectID=buu02549
The code 344 indicates noise or static on the line and usually the best way to get around that is to disable Error Correction Mode and/or lower the fax speed.
To disable the Error Correction Mode (ECM) touch the right arrow, then Setup, then Advanced Fax Setup, then down arrow and then Error Correction Mode and set it to Off.
To lower the fax speed, also go to Advanced Fax Setup and set it to Slow.
Nov 07, 2014 | HP Officejet Pro 8600 Premium e-All-in-One...
Ge pss26sgpass keep in defrost error code bc ?????
That is actually a "tc" error code.
This error means that the display board isn\'t communication correctly with the temperature control sensors which is why it\'s giving the error. It may stop cooling so you need to keep an eye out. Either way, try to unplug the unit for 5 minutes (don\'t plug it in early it\'s hard on the compressor). Plug it back in and see if the error goes away. If it doesn\'t, you need to order and replace your display control board because it\'s just not working correctly unfortunately.Here is the board to order.
Dec 01, 2012 | GE (PSS26MSRSS) Side by Side Refrigerator
Lexmark Pro901 When scanning from document feed the machine seems to scan only a part of the page whilst cutting out the information at the bottom of the page.
Make sure to set the correct paper size when scanning from the ADF. If you're scanning a legal size document, set the paper size to legal.
If it doesn't work, try to reset the printer back to its factory settings:
1 From the home screen, touch Setup (wrench icon), and then touch Use Factory Defaults.
2 Touch Yes.
3 When prompted to set the initial settings of your printer, make your selections using the touch screen.
Oct 12, 2012 | Lexmark Pro901 All-In-One Inkjet Printer
Error Processing ...
a note on this is scanner plugged into a power strip by chance?
most scanners prefer a direct connection(and the user manual usually does not state that) to the wall socket
give that a whirl and let me know how it works
might want to go to their website and grab drivers again and make sure it's got a clean set
May 22, 2012 | RTO Neat Receipts 00315 NeatDesk Desktop...
Hi, I have a Saeco Primea Touch Plus, in the display it says error 5. What ca I do? Regards, staffan
I had that error too, the very first day after i received my Saeco Primea Cappuccino Touch Plus from Germany. The curiosity is that the machine was able to prepare a cuple of cups and suddently died with 5 in screen. Going to the service, they said that error 5 is about a lack of pression in pipes, probably due to the unprotected transport to Romania. I don't know if they fixed alsi some jonctions, but i had to pay for few rings. Everything took a day in service, but now is working fine. Hope it was usefull and my english enough inteligible.
Apr 17, 2011 | Saeco Primea Cappuccino Touch Plus Coffee...
Setting up the network scan
on machine touch the following
utility
one touch
one touch
new
touch smb/pc
touch name and enter a name
touch down arrow (go to page 2)
touch reference
touch either the domain or the workgroup your computer is logged into
touch open
browse to your computer
touch open (after highlighting your computer)
If user id/password blocks pop up then enter the name and password that you login into the computer with
browse for the folder you want to use.
then hit ok
this takes you back to the page 2 screen with everything set for you.
hit ok then hit close until you are back to copy screen and try.
This is the steps I use and it works 99% of the time. Also if the system admins have turned smb protocol off then you cannot use it. You will need to use another method.
Apr 07, 2010 | Konica Minolta bizhub C250 All-In-One...
I have a ricoh 1515 and can not get scan to file to work
You need to tell the machine it has a delivery server, this can be done by selecting user tools/system settings/file transfer/delivery option/On. After doing this you may have to remove and readd the I/O device from within scanrouter.
Oct 18, 2009 | Ricoh Aficio 1515MF All-In-One Laser...
Im trying to scan and the canon says: "set the pc to start scan"...? Nothing pops up on the computer, what do i need to do?
I'm using an MG5220 and got this same message. Here's how I fixed it.
On the printer control panel press the soft key to select the scan function. Then hit the soft key to select Save/Forward. Then select Foward scanned data to a PC. On the next screen make sure to select the appropriate PC. In my case I'm connected wireless but the selection was set to USB connection and that's why I was getting the error noted above. When I picked the PC that is connected wirelessly everything worked fine again.
Jul 12, 2009 | Canon PIXMA MX850 Multifunction Printer
Won't scan today
I got no help from you. Called Canon USA and got immediate assistance, which resolved the problem. Please don't contact me anyomre. Thank you.
May 28, 2009 | Canon PIXMA MP780 All-In-One InkJet...
261 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
