Question about Microsoft Windows Vista Home Basic Edition
Internet and Network Connection
Hello all, I just purchased a new computer that has Windows Visa installed on it. When connecting it to my office network it seems to be having some issues. It will connect to the network with no problems, but the internet doesn't stay connected. It will constantly connect and reconnect to the internet. All of our other computers stay connected with no problem, and the Ethernet wire connected to the new computer has no issues. Everytime it disconnects from the internet I click on the network icon on the bottom right of the screen (next to the time) and diagnose my problem. The computer finds that there is no problem with anything, and then amazingly the internet is working again! Has anyone else had this issue? Is there any way to correct it? Please let me know! Thanks all!
  • Tim Nelson
    Tim Nelson May 11, 2010
    what type of connection is it? if its dsl or cable i would try to set your connection up for a static ip. to help you more i need to know the maker of your router, so i can walk you through the steps.
  • Chuck May 11, 2010
    Check to see if your router has a firmware update first.
    then with the vista machine go to control panel and check for updates. Now under the optional ones see if there is one for your network controller and install it by checking the appropriate box and install the update for it.
    then get back to us here on fix ya.
  • 189 Answers
We had similar problem earlier and unformtualtly we have to install the OS again. you can first check you firewall setting, try disabling firewall and check. Or will suggest reinstall the OS.
You can also try running antivirus/antispy/CCleaner etc before that.
Regards,
Sails
Posted on Mar 12, 2009
DOESN'T DETECT WIFI
The wireless feature on a Gateway computer allows you to connect to a network without the hassle of cables. This allows you to browse the Internet conveniently wherever you are. Gateway computers rely on Windows operating systems, which come with a built-in feature to manage your wireless connection. This feature makes turning off your wireless connection an easy process if, for a moment, you prefer to connect to the Internet using a wired connection.
Click the Windows "Start" menu and click the "Control Panel." Click Network and Internet Connections > Network Connection, if you are using a Windows XP Gateway computer. You should see your wireless connection. For Windows Vista and 7 Gateway computers, click "Network and Sharing Center" from the Control Panel and click "Manage Wireless Connections." You should see your wireless connection. Right-click your wireless connection and click "Disable" to turn it off. Close "Network Connections" when you are done.
Mar 03, 2013 | Gateway ONE GZ7108 All-in-One Desktop PC
Tip
Set up and Use Internet Connection Sharing
To enable Internet Connection Sharing on a network connection
You must be logged on to your computer with an owner account in order to complete this procedure.
Open Network Connections. (Click Start, click Control Panel, and then double–click Network Connections.)
Click the dial–up, local area network, PPPoE, or VPN connection you want to share, and then, under Network Tasks, click Change settings of this connection.
On the Advanced tab, select the Allow other network users to connect through this computer's Internet connection check box.
If you want this connection to dial automatically when another computer on your home or small office network attempts to access external resources, select the Establish a dial–up connection whenever a computer on my network attempts to access the Internet check box.
If you want other network users to enable or disable the shared Internet connection, select the Allow other network users to control or disable the shared Internet connection check box.
Under Internet Connection Sharing, in Home networking connection, select any adapter that connects the computer sharing its Internet connection to the other computers on your network. The Home networking connection is only present when two or more network adapters are installed on the computer.
To configure Internet options on your client computers for Internet Connection Sharing
Open Internet Explorer. Click Start, point to All Programs, and then click Internet Explorer.)
On the Tools menu, click Internet Options.
On the Connections tab, click Never dial a connection, and then click LAN Settings.
In Automatic configuration, clear the Automatically detect settings and Use automatic configuration script check boxes.
In Proxy Server, clear the Use a proxy server check box.
Bhautesh.
on Feb 24, 2010 | Computers & Internet
My windows xp has no internet connection. i install windows vista and it has internet connection and i install again windows xp and it has no internet connection w is the problem?
There are some windows will not run automatically the internet connection. You should install the motherboard driver so that the network or internet connection will functioning. After installing it will required you to restart your computer system to take effect.
May 29, 2010 | Microsoft Windows XP Home Edition
Computer will not accept new internet connection after cleaning of malware, can't "install ip address" network and connection icons will not do job when entering information
go to control panel and click on network and internet connections inside that up corner there will be create new connections go to that and do what computer says. sometimes it will work.
May 01, 2010 | Microsoft Windows XP Home Edition
Can not locate net work adapter
Possible cause:
The hard drive contains all the necessary drivers that makes the computer function and that includes Internet connection. When you installed the operating system and all other software it does not mean you installed the driver for the motherboard which contains the drivers for the LAN.
Solution:
Run the drivers CD that came with the motherboard. If you don't have the CD. contact the PC manufacturer for the driver CD. Otherwise, you can purchase an add on NIC(network interface card).
Mar 20, 2010 | Computers & Internet
How can i set up a connection to a network with windows vista basic
There are several ways to do this you can use a router, wireless router or set up a direct connection. With a router all you have to do is connect your modem to the router and computers to the router. For a wireless connection you need a wireless card installed in your computer and a wireless router. You connect your modem to your router and set up your wireless connection with the software that came with your card or through windows wireless service. You can also connect two computers through their ethernet port with an ethernet cord. You plug coonect them with the cord go into control panel open network connections and to the left chose set up home or small office network. You will need to configure the computer with internet access as the host and the other as a guest. You can share any type of connection such as dial up, cable, dsl, and broadband.
Dec 30, 2009 | Microsoft Windows? Vista Home Basic...
No Networks Recognized when I upgraded to XP Pro
Are you using a wired or wireless connection?
Check the Device Manager to see if there are any missing drivers or yellow exclamation points.
Report back.
Mar 10, 2009 | Acer Aspire™ T180 PC Desktop
Can't share internet over lan
You must share your internet to other computer using your lan connection in able other PC can open internet wondows.To do this
go to my network click set up home and small office network then follow up wisard set up before you close set up insert your cd windows installer e.g. xp or vista click additional task,click home and small office network again from cd follow wizard then click finish,then insert your cd wondows installer to other computer and repeat procedure on set up home and small network restart your PC everytime you install internet sharing,be sure one PC will assigned as server
Mar 06, 2009 | Computers & Internet
Using multiple networks
if you are using windows 2000 or later start the routing and remote access service (make sure to set it to automatic) and that should solve your problem.
Jan 13, 2009 | Intel REALTEK nc-r150201 Network Adapter
Missing password and printer connection
are you using internet router for your wireless network? you download software for your internet router or if you want reset your internet router this will refresh your router and give the manufacturer original settings with "admin" user without password.
you can also connect your printer to other computer and share it so that other computer on your network cab use it. just open the share printer in the network and windows will install it or go to add printer and look your printer using network.
hope this will help you.
Nov 24, 2008 | Linksys Ultra RangePlus Wireless Routr...
Microsoft Windows Vista Home Basic Edition Logo
50 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
