Question about Sport & Outdoor - Others
Schematics Winchester Model 150 Need to see how to install Trigger Spring.
Need to see how the trigger spring is installed.
2 Suggested Answers
agent91
  • 2100 Answers
SOURCE: winchester model 88. with the trigger assembly
Less Than Perfect
The Model 88 had its faults. The trigger moves with the lever and the resulting linkage to the sear results in a rather spongy, creepy trigger break. If you want to see your gunsmith turn pale, waltz into the shop with an M88 and ask for a crisp three-pound trigger.
If you already have taken the gun apart, don't be afraid to hone the parts on a stone , keep them flat, you don't want anything rounded off. Especially the sear. I found that quote up top from a winchester sight,
Posted on Feb 22, 2010
How dose the line return spring install can't really tell how to install it please jelp
nstallation of Wolff trigger return spring??? - The Firing Line ...
https://thefiringline.com/forums/showthread.php?t=132371
Sep 28, 2002 - 10 posts - ‎4 authors
I know how to install the main spring. How do you install the trigger return springthough? I'm asking cause I just ordered the Wolff GP 100 ... GP100 - Hammer/Trigger Spring Questions
Aug 8, 2012
Changing Springs in SP101
Apr 8, 2011
Wolff replacement main spring for S&W?
Apr 6, 2011
Show of hands...CZ trigger return spring
Feb 19, 2007
More results from thefiringline.com
Nov 02, 2015 | Cars & Trucks
Do they make a trigger kit for a pk380?
Not sure what you mean by "trigger kit", but if you mean how to reduce the lbs of trigger pull, several companies off spring kits.
Here's an example:
http://www.midwayusa.com/Product/177318/wolff-hammer-spring-pack-walther-ppk-s-reduced-power
Jul 01, 2014 | Browning Bar Mark Ii Safari .243...
Ryobi 970r
Hey Chris,
If you give me make, model and serial number I may be able to find a diagram for you.
Sep 23, 2013 | Garden
The spring in my trigger flew out. how do i put it back
The n60fn uses two triggers, rapid fire trigger (black metal) is pictued with your post and does not need a spring. Just replace the 3 mm roll pin that holds trigger to the body of the gun and you should be good to go. The other trigger is the white plastic sequential. The sequential trigger uses a fine spring between the trigger and centered on the tva6 trigger valve. Parts and breakdown at www.toolpartsdirect.com. Good luck
Aug 23, 2010 | Stanley Bostitch Air Nailer Trigger N60...
Removing bolt from a winchester model 67
Pull stock off your model 67 win. The trigger stays in the stock . Lift up on the barrel and action while pulling it toward the end of the stock. To separate them. Next open the bolt , then reach under the action grasp the arched piece of spring steel . Pull down gently on the spring steel retainer while pulling back on the bolt. You can also remove the ejector assembly in the same manner pulling down on it. Assemble in reverse order.
Mar 31, 2010 | Winchester (026196062448) (20 - 60x70 mm)
Winchester model 88. with the trigger assembly
Less Than Perfect
Feb 22, 2010 | Optics
Part fell out of gun dont know where it goes
is it the carrier support spring or the trigger spring?
go to www.winchester.com look for owners manual for model 94 come times the site dont work well.you may have to call them and ask for a schematic parts break down they will send it to you or e-mail it.
Oct 28, 2009 | Sport & Outdoor - Others
Husqvarna 365 order to install trigger, throttle catch and spring
Here's a link to the husky parts list.
http://www.usa.husqvarna.com/support_manual_search.aspx?webecsearch=10527&O=true
Mar 23, 2009 | Husqvarna Garden
Poulan 3400 chainsaw throttle trigger
Its a missing or broken spring in the handle(trigger). If you look inside the handle you should see a circular spring around the post of the trigger. This spring returns trigger to idle position. If its missing or broken the trigger won't spring back.
Oct 12, 2008 | Poulan Garden
Sport & Outdoor - Others Logo
29 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
