Question about Kenmore Elite 45986 Front Load Washer
Removing front panel of WCF7500VW
Need to remove front of washer to put a water temp button back in its place.
jsrock516
  • 5911 Answers
SOURCE: removal of front panel HE3 kenmore washer
Follow these steps: 1. Remove the three screws in the back of the machine that holds the top of the washer on. The top case should slide back and then lift off. 2. With the dispenser tray off, remove the torx screw behind it. 3. Now take a putty knife and gently place it under the console just above the door. Gently lift up and pull the console from the left hand side first. It should gradually pop off. Be careful not to damage any of the wire connectors. Lay the console across the top of the washer. 4. Remove door by removing the hinge screws. Support the door while loosening so that it doesn't fall. 5. Feel around behind the rubber door boot at the door opening. There will be a wire retaining hoop holding the rubber boot to the door frame. Find the tension spring at the bottom of the door and pull the hoop out of the groove. 6. Pull door boot off the door frame opening and push it inside the drum. DO NOT remove the boot from the wash tub. 7. Remove the three screws holding the door latch assembly to the front of the washer. 8. The only thing left holding the front of the washer on is four screws. One on each corner at the top and one on each corner at the bottom. Once you remove the last four screws the front of the washer will come right off. I now this seems very involved, but it is simple if you follow the steps given. Reassemble everything in reverse order. Use care when handling the wire harness of the console and the door. Make sure you put the door latch assembly back on FIRST before you reinstall the rubber boot. When reinstalling the door boot reseat the gasket all the way around the door frame first. Then take the wire hoop and reinsert in the groove starting at the 12 o'clock position and work your way around to the 4 and 8 o'clock positions. You might want to have a second person assist you with holding the hoop in place at this point. With tension holding the hoop into the groove, take the remaining portion of the wire hoop and pull down while spreading the tension spring apart to snap it back into place along the bottom of the door. This will be your greatest challenge. The console will snap back into place by inserting the bottom edge first then snapping the top into place. Let me know if you need further assistance. I hope this helps you.
Posted on Aug 14, 2007
RescueTech
  • 145 Answers
SOURCE: Kenmore washer 60 series
Hi, thanks for using the FixYa service. Your lid switch is probably broken. Make sure you can hear it click when you open and close the lid. It it is a very common problem on that model. Probably has nothing to do with the pillows, that was just the last load in the machine before the common part failure. Get me the exact model number and I can get you the replacement part number.
Posted on Dec 19, 2008
SOURCE: Removal of front cabinet panel of washer section
Should be two screws on each side of the bottom of the front panel. Takes those out and push the panel up and out. (There are two "tabs?" in the middle of the front panel that lock into the side panels, so you have to push up and then pull out.)
Posted on Jan 15, 2009
  • 7 Answers
SOURCE: Removing Back Panel of Kenmore Washer Model 11020902990
if its less than 15 years old its a direct drive whirlpool, no belt, remove the cabinet, not the back panel. look up direct drive whirlpool washer cabinet removal on internet, and replace the coupler, most likely, if it drains.
Posted on Jan 30, 2009
  • 117 Answers
SOURCE: How to remove knob from panel
If there is a black tab on the back of the timer, it needs to be pulled out of the timer before you can remove the knob
Posted on Mar 02, 2009
Need to remove and replace electronic water valve
First off unplug washer.
Turn water off hot and cold.
Disconnect water lines from valve.
Remove screws from top panel on washer then slide top panel off.
Remove connections on valve. Make mental note for what goes where. ;)
Remove valve.
Install new valve.
Connect wires.
Put panel back on and screws back in.
Connect water lines hot for hot and cold for cold.
Turn water on and check for leaks around connections.
Plug washer in.
Run a load!
Hope this helps.
Oct 26, 2012 | GE WBVH6240F Front Load Washer
HE3 no error codes, will not start when button is pushed. All mode lights are on push any wash cycle and no go. Checked water lines, drain line, no obstructions. When you push the wash cycle button it...
Disconnect power to the washer and open the door. Remove the door gasket retaining hoop by stretching apart the retaining spring at the bottom of the door opening. Gently peel the part of the door gasket near the door lock/latch assembly off the lip of the right side of the door opening. Remove enough of the door gasket to access the door lock/latch assembly behind the front panel.
Remove the three screws securing the door lock/latch assembly to the front panel and slightly lift it then pull it back off the front panel. Pull the door lock/latch assembly out of the washer and disconnect the wiring harnesses.
Connect the wiring harness to the new door lock/latch assembly and install it back in place behind the front panel. the door lock/latch assembly and put the eased part of the door gasket back into position over the lip of the door opening.
Check that the door gasket is properly seated before putting back and securing the retaining hoop around the lip of the door opening and the door gasket.
Feb 26, 2011 | Kenmore HE3T Washer
Do I need to clean the filter behind the lower front panel? I removed the panel but nothing in the owners manual that describes it. I heard that you need to do this every year or so for general...
Remove the lower kick plate. Unscrew the two screws holding the kick plate in place, and gently pull off to remove. The kick plate is the lower outside cover of the washing machine.
Place a small bucket under the white hose. Remove the cap on the white hose by untwisting it. Allow any remaining water in the hose to drain into the small bucket. There shouldn't be much water, but there can be some.
Look inside the white hose. Remove any visible obstructions or lint.
Look inside the hose cap. This is where the lint filter is. Remove any visible lint with your fingers. Rinse the hose cap under warm water to remove any remaining lint.
Twist the cap back onto the white hose. Put the kick plate back in place. Screw back on.
Oct 19, 2010 | Whirlpool Duet GHW9150P Front Load Washer
I have a kenmore washing machine and the wash temp. does not work on cold or warm anymore, just hot even when it is on the warm setting.
The problem is the cold water solenoid on the water inlet valve. Replace your valve and the problem will go away. This is a very simple and inexpensive repair.
To replace the water inlet valve, follow these steps:
1. UNPLUG the washer.
2. Turn off the water source and disconnect the fill hoses from the back of the washer.
3. Remove the toppanel of the washer by locating and removing the screws that hold the panel in place in the rear. With the screws removed, the panel will slide back, then lift off.
4. With the top panel removed, disconnect the dispenser hose(s) and electrical connections to the inlet valve.
5. Remove any mounting screws holding the valve in place and reinstall with a replacement valve.
Replacement parts can be purchased on line at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare. The first three sites on the list also include helpful exploded view diagrams of your washer to help with locating parts and assembly.
NOTE: Before you begin, check the sediment screens on the water inlet valve by turning off the water and disconnecting the fill hoses from the back of the washer. There are small screens in the hoses (sometimes) and the inlet valve. If you live in an area that has hard water, or uses well water, sediment, rust and scale and clog these screens. Sometimes a good cleaning with some distilled vinegar helps.
If you have any questions, please let me know. I hope this helps you.
Feb 14, 2010 | Kenmore HE2 Plus Front Load Washer
Door boot seal on a front load washer how to change
front gasket/door boot.... replacement isn't easy but do-able. first remove three screws that hold front lower panel on and remove panel (where lint filter is). then remove 3 screws that hold on top panel (screws located at rear of top of washer), next remove 3 screws on top front of washer, then remove 4 screws that secure the contol panel. you must remove the washer door at this point, just a few screws and pin hold the door on. now, remove control panel by gently pulling the top away from the washer, it's held by a few plastic snaps. then, remove three screws that secure front panel of washer. now you're ready to remove the old boot/gasket. first look toward lower right side of gasket and pull the spring and remove wire that secures front of gasket. next... at about 3 o'clock on the gasket you'll find a longer screw (about 3 inches) that secures the rear of the gasket. loosen this screw until you can remove the gasket. remove the water inlet and hose from the boot/gasket.... now remove gasket from washer. you're ready to install new boot/gasket. find the small triangle on the new gasket and line this up w/the triangel at the top of wash tub. begin working the gasket onto the lip of tub, make sure to align the triangle and water outlets of the gasket w/the triangle and outlets of the washer tub. once back of gasket is on install the rear wire holder and tighten screw to former tightness. now work front of gasket onto the lip of washer, install spring wire to secure the front. place water inlet and hose into respective holes on the gasket. put front panel back on, put door on, put control panel on, put top on... and wash. like i said, not easy but do-able... i completed it in 1.5 hrs w/no instruction.
Nov 11, 2009 | GE WSXH208A Front Load Washer
How do I replace the drum gasket at the rear of Model 97273100.
Replacing gasket is fairly simple - need 2 people. UNPLUG FIRST - 1. Remove the plastic cover on top of machine that is mounted to back of control panel. 2. remove dispenser - push down on tab at back and it will slide all the way out. 3. Remove lower front cover by removing 3 screws holding it on bottom. 4. Remove 3 screws holding top panel on back of machine and slide cover back approximately 1 inch and lift off. 5. Remove the 3 screws that hold the control panel on - note these are different type of screw so keep track of which screw goes where - one of the screws is next to dispenser opening. Once this is done you can reach in to machine and disengage locking tab on right side under "washer temp" - have someone hold this part aside if you do not want to disconnect the cables. 6. Remove spring loaded wire securing door seal to front cover. 7. Remove the the 4 screws holding the front cover on. This item is a bit heavy so be careful. Disconnect the three door latch wire harness and place this aside. 8. On the right side of the gasket you will find the clamp screw that holds the seal to the drum - loosen this screw almost all the way and remove this wire clamp. carefully remove the two tube connections and remove the gasket completely. Take note how these were installed before removing. Now you can carefully clean the gasket seats on the drown and door and replace the gasket and reverse the steps to put the machine together. While you have the covers off it would make sense to remove and clean the pump strainer mounted on the lower cross support - this can be messy with lots of water coming out so go slowly and have plenty of towels and a shallow pan to catch the water with. HOPE this helps.
Jun 16, 2009 | Washing Machines
My Duet front load washer slowly fills with water after wash cycle is finished - what needs to be fixed? Front door is open.
The cold water valve is probably stuck open. It should open only when there is voltage across the valve. It could just be clogged inside. If you can remove it, you might be able to take it apart and clean it. Just make a note of how parts fit together as you are taking it apart. Clean all parts with old toothbrush and reassemble. Before you reinstall, connect it to a garden hose outside. No water should come out when you turn the hose on. If it still fails, just buy a new valve.
1. Unplug washer, turn off water supply and remove hoses from the back of the washer.
2. Remove the top panel by removing the three screws that hold the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off.
3. The water inlet valve will be located at the left rear of the washer (as viewed from the front).
4. Remove the dispenser hose, electrical connections and mounting screws and the valve is removed.
5. Install new valve by following these steps in reverse order. NOTE: When reinstalling top panel, make sure you lay panel on top of washer, leaving a couple of inches of room from the front panel. Then, slide panel towards you (front of washer) so that the top panel slides into the mounting clips.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Apr 08, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Belt amana washer replace mod lw6501w2
I have a similar amana top load washer and just changed the belt. Here are the steps I used to change the belt:
1) Unplug the washer
2) Slide the washer away from the wall about 12"
3) Remove two screws from the bottom of the front panel, slide the front panel down (there are 2 metal tabs that slide into slots on the top of the front panel - observe how they slide into/out of the slots). Set the panel aside.
4) Remove the electrical connector (upper left of motor). Press down on the top of the plastic connector - this will undo the catch hook holding the connection in place). Observe how the belt is routed before proceeding.
5) Remove 4 bolts holding the motor in place. You can remove the motor - even with the water pump and hoses in place - they will flex.
6) Remove the water pump from the motor. There are 3 torx - head screws to remove. Note: You will need a star shaped (torx) head driver (Looks like a screwdriver but with a "star" head on it. The one I used measured just under 3/16 in diameter.
7) carefully remove the water pump. - remove the old belt from main pulley under washer drum and also from the water pump. Insert the new belt - be sure to put the tension pulley on the outside of the belt.
8) Reinstall the water pump to the motor. Reinstall the motor. Route the belt correctly in the water pump body area first - them slide the belt around the left side of the main drum pulley - rotate the pulley counter-clockwise and the pulley will tug the belt onto the pulley. Once in place - check bolts and belt - then reattach the electrical connector (remember to press the plastic lever on top of the plastic connector before sliding it in place). Reattach front panel - slide the top of the panel onto the metal tabs - then attach screws at the bottom.
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Whirlpool front loader washing machine
I would recommend you replace the water inlet valve. This is the only device between the fill hoses and the dispenser that controls the flow of water. The "hissing" noise you hear could be a defective solenoid in the valve that is staying open and allowing water to flow. Try turning the water off at the tap to see if the sound goes away. If it does...water inlet valve. Another tale-tell sign of an inlet valve leaking would be a small trickle of water running down the dispenser tube in the rubber door boot. Over a period of time, the tub will begin to fill and possibly overflow (even with the washer turned off).
You can find a replacement valve at searspartsdirect.com. Just type in your model number and look under the "Dispenser Parts" heading for item number 1 (part #8181694).
Replacing the valve is simple. Just follow these steps:
I hope this information is helpful to you. If you still require assistance, or if you feel I'm wrong in my assessment, please post back and let me know.
Oct 06, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Elite Washing Machine leaking water
Okay...my experience with this model front loader leads to the following possible problems:
CAUTION: UNPLUG the washer if you plan to service the interior. It is dangerous to have your hands inside the unit with moving parts and energized. Plug the washer back in and stand back if you plan on doing any operation checks.
1. Door bellow ripped or torn (this is the gray rubber boot around the door - open the door and inspect along the entire door boot. Including the areas behind the rubber fold where the rubber meets the wash tub. It is common for them wear out and tear. NOTE: Make sure the fill hose on the left-hand side of the door boot is fully snug in place. Sometimes it will come loose and leak BEHIND the door boot.
2. Drain pump or hoses leaking - You will need to remove the lower panel under the door to see inside the washer. Remove the three torx type screws under the front lip at the bottom of the panel. For easier access, place a small block of wood under each front foot. The washer is heavy so you may need assistance to lift the front slightly. CAUTION: Do not lift on the door, push on the door panel or control panel. If the panel sticks, slightly tap on the sides and it will drop down and come off. The pump is located in the front under the wash tub. Make sure the clean out trap is snug and all your hoses are tight and not torn. Check the drain hose that leads out of the back of the washer from the drain pump to ensure it is not cracked.
3. Air Dome hose has come loose from the tub - This will be a small rubber hose connected to a plastic piece (called an air dome) on the right-hand side of the wash tub as you are looking in from where you removed the bottom panel. It should be located behind the drain pump and mounted physically to the wash tub. The other end of this hose runs to the pressure switch, which turns the water flow off when the washer tub fills to the approriate level. If this hose comes off, the washer will start to leak on the FILL cycle and will not shut off. I don't think this is what you are talking about, but it is still worth a look since you have the panel opened.
4. Tub seal leaking or tub cracked - These would be the most undesirable of all possible problems because it would require the removal of the entire wash tub in order to correct. Inspect the wash tub seam and make sure there's no water coming from around the tub.
I hope this gives you a few possible items to work with. Inpsect the washer interior when you get the panel off and post back if you can determine where the leak is coming from.
HELPFUL HINT: Put the washer into diagnostics mode if you plan to leak test. At the control panel select DRAIN/SPIN, NO SPIN and press any key under OPTIONS 4 times (it must be the SAME key, however). "C00" will be displayed on the operator console, and you will hear the door latch engage. The washer will run through a series of tests by filling using hot and cold water, checks all your dispenser features, tumbles the drum, spins and drains. This diagnostics can be stopped at any time by pressing the PAUSE/CANCEL button twice. The drain pump will come on and drain the washer.
I hope this helps you...
Feb 20, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
108 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
