Question about Kitchen Ranges
My RCA stove keeps beeping and it says f`1 what dose that mean
It keeps beeping and f1 keeps showing up on the front
SOURCE: Stove reads "F1" on the display and beeps
Go to www.applianceaid.com/images/ge-built-in-oven-faultcodes
Posted on Sep 20, 2008
duby1990
  • 367 Answers
SOURCE: kenmore elite flat top stove
Analog to digital failure. Disconect power for 1 minute. if the code comes back replace the control board.
Posted on Nov 21, 2008
  • 360 Answers
SOURCE: The display at top of stove is showing "F1" and continuously beep
Maytag Range / Stove / Oven Fault Codes Failure Code Fault Code Description Solution F0 Function key stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F1 Defective touch pad or clock (ERC) Replace touch pad or clock (ERC). Touch pad is a more common problem. Refer to F1 test at the top of this page for more information. F2 Oven temperature too hot Replace relay board, if present, or oven temperature sensor (RTD). Check sensor harness. F3
or
F4 Shorted or open oven temperature sensor (RTD) Check sensor harness and harness connection between oven sensor and oven control. Replace oven temperature sensor (RTD) if wiring is ok. F5 Watchdog and hardware conflict Replace clock (ERC). F7 Function key shorted or stuck Replace touch pad or if touch pad is part of the clock, replace the clock (ERC). F8 Analog / Digital problem Replace clock (ERC). F9 Door latch Check door latch components.
Posted on Mar 19, 2009
SOURCE: "F1" error code on Magic Chef gas range Model 3488XRA
I'm not sure how to fix this, but my mom's magic chef has been doing this for close to 10 years. She's managed it by plugging a power strip into the wall outlet and plugging the stove into the power strip. Then she can just turn on the strip when she needs to use the oven. It only requires moving the unit once, and is easy for the technological/ home repair novice.
Posted on Aug 11, 2009
  • 80 Answers
SOURCE: F1 llight on, oven locked, stove beeps every few seconds
My stove did the same thing after I cleaned it. I had to have the sensor replaced. That is what the F1 code is.
John
Posted on Oct 01, 2009
I cant get my stove to stop beeping. f1 error
You need to get the exact model number and make of this stove. Get ready for a bad circuit board to be the culprit, because electronic stoves are pretty much unfixable by mechanical means and the problem usually comes from a bad capacitor, corroded or overheated circuit board.
When you get your model number and make, go to YouTube and just type in your model stove and ask "how to repair a F1 error code on a blah blah stove". There are so many video's there on how to repair things with actual instructions and pictures. It's great.
Use this link to close in:
https://www.youtube.com/results?search_query=repairs+to+appliances+or+stoves
Jan 27, 2015 | Kitchen Ranges
I have an amana artc8600 and the error code it has is f1. could you tell what the code means. Also, when i try to turn the oven on no matter what setting it keeps turning off i have to try a bunch of...
HI,
Disconnect power to stove
Gain access to the back of the clock (electronic range control or ERC).
Unplug the pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
Make sure everything is clear and will not short out when power is turned back on.
Turn power back on to stove.
Watch for the F1 and the beep
If you see f1 and hear the beep its the ERC
If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
Thank you for using fixya
Leo Ponder
Please rate me if this helped.
Jul 23, 2011 | Ovens
I have a 19 year od kenmore electric stove and it keeps beeping F1. I can hit cancel and it will be od for alittle while then goes back to beeping. Any ideas?
You have either a bad ERC (clock) or a bad touch pad.
Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
Watch for the F1 and listen for the beep.
If you get the F1 and beep, replace the ERC.
If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
NOTE: Some models incorporate the touch pad and the clock as one part.
Hope helps.
May 22, 2011 | Kenmore Kitchen Ranges
Error Code F1 displays once in a while. What does it mean?
How to test many brands of Ranges that are flashing a F1 fault code: You have either a bad ERC (clock) or a bad touch pad.
1. Disconnect power to stove
2. Gain access to the back of the clock (electronic range control or ERC).
3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire approx. 1 1/2" to 2" wide.
4. Make sure everything is clear and will not short out when power is turned back on.
5. Turn power back on to stove.
6. Watch for the F1 and listen for the beep.
7. If you get the F1 and beep, replace the ERC.
8. If after approx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
* ERC - Electronic Range Control
Hope helps.
Apr 20, 2011 | Ovens
F1 error message Kenmore Electric range model 790.95680301
Hi
F1 error means that you have either a bad ERC (clock) or a bad touch pad. To check these please follow these simple instructions:
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Aug 10, 2009 | Kenmore Kitchen Ranges
What does error code f 1 mean on an electic range if i hit clear the beeping stops but comes back on in a few seconds
Copied from another website:
Jul 26, 2009 | Frigidaire Gallery GLGF389GS Kitchen Range
or
Mar 19, 2009 | Maytag PGR5710 Performa Gas Kitchen Range
Digital screen is showing -F 1- and beeping
dont know the brand but f1 usually means you need a new clock/board.try unpluging for 5 min.then try again.other wise clock
Dec 31, 2008 | Kitchen Ranges
Kenmore 8114p643 showing f1.
F1 is either a bad electronic control board or a bad touch pad.
You find the solution on :kenmore oven with "F1" error
I quote:
"You have either a bad ERC (clock) or a bad touch pad.
    3. Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide.
    8. If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad.
If you can't find a new ERC you can send yours to stove clock repair and get it repaired!"
Dec 14, 2008 | Kenmore 91112 / 91114 / 91117 Electric...
Wolf built-in Wall Oven 762. Convection Fans stop turning intermitantly Oven shut down with F1 warning Later restarted ? meaning of F1 warning
http://www.applianceaid.com/fault_codes.html
click the link
Dec 06, 2008 | Kitchen Ranges
Kitchen Ranges Logo
27 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
