Question about Dell Dimension 2350 PC Desktop
Dell 2350 Won't boot up without cd
Dell 2350, hard drive crash I replace it with 200gb hd format and install xp. But after installation computer Windows won't load with out Boot cd on the disc drive.
  • 131 Answers
Check the jumper on the back of your drive. Chances are that the jumper is either on "slave" or "cable select". Change the jumper to master, and try rebooting.
Posted on Mar 13, 2009
  • Gord Thurston Mar 13, 2009
Is this computer able to dual boot win 7 and xp
Which version of xp are you trying to install 32 or 64 bit ?
Your ability to install a second operating system on your Windows 7 system hinges on one thing: partitions. If your computer has only one partition, you can't dual-boot your system without erasing all information on your computer. Two hard drives, or two partitions, enables you to dual boot. Check this information first, before proceeding.
Click "Start" and type "disk management" into the search bar. Click on "Create and format hard disk partitions" in the list of programs to open "Disk Management." Look at the list of partitions and available drives. The information here will be different on every computer. "C" is your primary hard drive and active operating system partition, and this drive contains your Windows 7 installation. You can't install Windows XP here without formatting the system. Check for secondary drives and partitions in Disk Management. Your system may have a "D" or "E" drive. Some computer manufacturers create a hidden partition with recovery software: don't remove this partition. If you have a secondary partition called "D" with more than 2GB of free space, you can install Windows XP here. b> Installing XP b> Insert the Windows XP Setup disc into your CD or DVD drive and close any windows that appear. Shut down your computer with the disc in the drive. Turn the computer on and look for a message saying "press any key to book from CD." Press any key on your keyboard when this message appears. Most computers are configured to look to the CD or DVD drive first, before booting to the operating system. If your system doesn't recognize the disc, you will have to enter your BIOS and change the boot order. Look to your manual for information on changing the boot order. Press "Enter" on the "Welcome to Setup" screen to load the Windows XP setup program. Read the license agreement and press "F8" to accept. Windows will detect that an operating system is already installed on your primary partition and present a list of other partitions to install XP. Use the arrow keys to select your secondary partition ("D") and press "Enter" to confirm that you want to install XP here. Then choose what to do with the partition: leave the file system intact or format the partition using FAT32 or NTFS. Windows XP supports both file systems, but requires NTFS on partitions larger than 32GB. You don't need to format the drive to install XP. Follow the prompts on screen to enter your personal information, serial number, and date and time. The setup program copies files to your PC and reboots -- don't press a key to boot to the CD. When you have to operating systems installed, a DOS screen appears asking you to choose an OS; press the down arrow key to highlight Windows XP and press enter to complete the setup. You will have to choose this every time to boot into XP, otherwise your computer will boot to Windows 7 by default. Hope this helps.
b>
Jan 06, 2013 | HEWLETT-PACKARD Pavilion Desktop with AMD...
I have a old gateway pc and I would like to install a Hard Drive from a Dell pc into it. Can it be done?
Swapping the hard drive from the Dell into the Gateway will not work because the Dell hard drive has been installed with Dell specific drivers and configurations.
When you install the Dell hard drive into the Gateway you need to wipe the hard drive and install a fresh copy Windows XP onto this hard drive and the Gateway device drivers etc.
Oct 29, 2012 | Computers & Internet
Hi install Windows 7 on my hp compaq nx6310 Celeron M. and put a 500GB HD I worked fine but after installing some programs are lost anrranque files then I wanted to install windows xp tells me not see the...
restart your computer witht he XP cd in your drive and maiing sure it boots to cd by either pressing F12 or going into your bios and setting the priority to cd first then hard drive second after you have done this if it still cant see the hard drive then the hard drive has developed a fault and will need replacing if you havent formatted it yet try and see if it boots up to windows 7 if it does then it means the xp cant format the drive. if you have more problems then please use the comment below to describe whats being done. Kronoguy
Jun 29, 2011 | HP Compaq Business Notebook nx6310 -...
Mine hitachi hard disk is 80GB SATA i cant able to install OS because it is showing error some virus found and u r not able to formate this. first when i put OS CD in drive it will install some files and...
The problem is that XPinstallation CD does not have a SATA driver, unless you have a SATA drive on adisk etc. and can install the driver when XP asks for a hard drive driver then,XP cannot detect the hard disk and therefore won't install XP. The FIX. Go into the BIOS anddisable the SATA drive (enable IDE emulation), this will make XP think it is aIDE/PATA hard disk. Then you can install XP normally. When Windows hasbeen installed then install all the device drivers (including the SATA driver),then shut down and boot up and got into the BIOS and enable the SATA drive.
Apr 15, 2011 | Hitachi (14R9464-20PK) 250 GB Hard Drive
I was looking for step-by-step install guide to putting new hard drive and loading Windows XP on my Dell Inspiron E1505?? I purchased a WD 320GB SATA hard drive to replace my dead 80gb hard drive....Dell...
All you've got to do is:
1) Insert the new hard drive.
2) Press the F8 key as the laptop boots. This will take you into the BIOS.
3) Locate the disk drive priority setting in the bios.
4) Set Priority 1 to your CD/DVD drive and priority 2 to the 320GB hard drive.
5) Save settings and exit the BIOS. This should reboot your laptop.
6) Insert the Windows XP CD.
7) It should not start the setup as it recognises the CD.
8) I will recommend that you format the drive before you install, go along with the format (make sure it does a full format).
9) After the format it will reboot your system.
10) You will be prompted with a message like "Press any key to boot form CD", DON'T press anything otherwise it will start all over again.
11) Now it should start the install. Follow the on-screen instructions.
Mar 15, 2011 | Dell Inspiron E1505 Notebook
Have a HP SR1010V, 33GB HD - XP Home. Want to 1) replace HD with a 100-200GB HD OR 2) ADD a 100-200GB HD and 3) ADD a DVD drive. What is best way to copy data to a new HD and to boot the new HD. Rather...
The easiest route would be to install the new hard drive in place of the old hard drive and place the old hard drive below the new hard drive and make it a secondary hard drive or slave drive. Once you have them installed this way you can install Windows XP Home to the new hard drive once you have it installed to the hard drive then you can copy everything from your old hard drive to the new one. Once you have everything copied from the old hard drive you can then format it within Windows to have 33GBs of space to store anything you wish. If you need more detailed instructions don't hesitate to reply.
May 19, 2010 | HP Compaq Presario SR1010V (568656) PC...
No iede found
is the hard drive showing in bios? you may have a hd too large for the bios to read. has it been fdisked or formatted?how large was the od hd? was it the same type hd? either way when you reload the operating system you will need a disk. post back and let me know, i will try and help. just the info you gave is not enough to attempt repair.
Jul 19, 2009 | Compaq Presario R3000 Notebook
Replace bad HD with new 5oogb
This is a rather technical problem with MS Windows and the 48bit Logical Block Addressing scheme.
You can read more details here: http://support.microsoft.com/kb/303013
Short solution: You have to install Service Pack 1 (or better SP2) in order to get past this problem.
I assume that you had this disk in you computer before, so the BIOS should be able to handle this as well.
Dec 08, 2008 | Western Digital 500GB My Book Pro-External...
Dell Dimension 2400 - Adding second HD
set the jumper on the maxtor to cable select and see if that fix's things ?
Nov 29, 2008 | Dell Dimension 2400 PC Desktop
Re-install windows
If you hit "delete" at start up (immediately before or after the beep)the computer will take you into BIOS. It could be a different key for your computer but it will tell you at start up. In BIOS, on the "boot" settings page there will be a "device order" list. Most computers from the last few years will have an option for "removable" device or "USB" device etc. YOU MUST PUT THAT DEVICE FIRST ON THE BOOT ORDER! I originally assumed that you already tried this, but the function is so standard that I have to point it out. OTHER OPTIONS -try an upgrade installation -copy the install cd to a booting hard drive partition (advanced) -pull out the hard drive and install windows on it in a separate computer. If you truly can't boot from an external device, than putting a new CD drive in seems like the most painless option... though I know thats not what you want! If it just a cd drive you need they come for about $10 nowadays. Food for thought anyway!
Aug 27, 2007 | Dell Latitude C640 Notebook
Dell Dimension 2350 PC Desktop Logo
232 people viewed this question
Alun Cox
