Question about Refrigerators
Chute replacement on toro ss5000 - Refrigerators
Ironfist109
  • 3018 Answers
SOURCE: How do you install the
  • It really is a very simple install. You get those sometimes. Just to easy to be that easy. What the recycle does is stop the grass from blowing out the side of the mower making it distribute evenly and cutting the grass multiple times.
  • Here is a picture of the recycler kit after installation.
  • You just remove a couple bolts to remove the old bag attachment and replace the new one you have (pictured above) There may be a couple screws as well but the two bolts in front are the ones to remove.
  • Don't forget to put a mulching blade on. You just turn the mower on its side and remove the blade mounting bolt. Remove the stock blade and add a mulching blade. Remember to mow a little slower too and let the blade do its job real well.
  • That's it really. If you have any questions or comments please feel free to ask.
  • Hope this helps and thank you for using FixYa.
Regards, Tony
Posted on Jul 27, 2011
BAMOUT
  • 2478 Answers
SOURCE: How do I replace the belt on a toro ss5000 #74630 timecutter
Go to you tube On the line replace belt toro etc.
Posted on Jun 21, 2014
  • 1169 Answers
SOURCE: I have a toro timecutter ss5000 and the battery will not stay charged. I bought a new battery same problem. What actually charges the battery the solenoid?
Actually is the alternator on the engine thru a voltage regulator and 25A fuse then thru the ignition switch to the starter solenoid and on to the battery..
Posted on Mar 23, 2015
Testimonial: "I don't see an alternator don't believe this model has one"
claudeinmo
  • 9098 Answers
SOURCE: Need drive belt pattern for Toro SS5000. My mower keeps throwing the drive belt.
LOOK AT THE DECK OF A UNIT AT THE TORO DEALER AND SHOOT A PICTURE OF THE BELT.
Posted on Jun 19, 2015
  • 3519 Answers
SOURCE: How do I get the belt on the engine back on. Mower will not go forward or back
http://www.partstree.com/parts/toro/mowers-zero-turn-lawn-mower/74631-toro-timecutter-ss-5000-zero-turn-mower-sn-314000001-314999999-2014/belt-and-pulley-assembly/
Give this link a try. Once you have the belt diagram, and the right belt, it has to fit.
Posted on Aug 17, 2015
Toro ss5000 cuts unevenly
i would bet you have one side in the wrong attachment hole without turning it on put the deck down and you will see the problem
Aug 23, 2017 | Toro Garden
How to check the charging system on a toro timecutter ss5000
The battery should show about 1.4- 2 volts higher than the voltage rating of the battery when the engine is running at high idle.
Jun 18, 2017 | Toro Garden
Timecutter ss5000 loses power
check for rusted or failing bearings on the cutter shafts
Oct 02, 2016 | Toro TimeCutter SS5000 zero turn mower
Toro 50" ss5000 time cutter with Kawasaki 22hp engine battery wont charge. Allow me to only cut about 3 times before battery is drained.
Take battery out, charge with 12v auto charger. In a couple days check voltage 12 or better
Jun 23, 2016 | Toro Garden
Jun 18, 2015 | Toro Garden
Jun 21, 2014 | Toro Garden
I just bought a new toro ss5000 22 hp kawasaki and it will not start, has gas, oil level seems ok turns over fine.
there has to be a safety mechanism you are over looking. check that you have spark. if not then it is a sensor, if so then check you have fuel flow. being brand new i am thinking you are just over looking something simple. if all else fails try a small amount of starting fluid through the carburetor and see if it starts and runs on that. I know that sometimes after I rebuild a unit it takes some "help" to get it going then it runs and works fine
Feb 17, 2013 | Toro TimeCutter SS5000 zero turn mower
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
