Question about Insignia Digital-to-Analog Converter for Analog TVs
Only receive channel 11
Converter box was working fine before broadcast switched to digital.. Now only channel 11 is received. Have mislaid the converter box instructions How do I get this thing working again ?
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 150 Answers
Just rescan the channels under the menu button!
Posted on Mar 23, 2009
TV on video can't get air TV channels
Do you have an Digital signal to analog signal converter box? if not you need to one, all signals are broadcast in digital now and your TV can't directly receive them without a converter box.
Nov 02, 2016 | Televison & Video
No TV broadcast picture. Is this a tuner problem?
yes it does seem to be a tuner problem , I also wonder what happens when you use the auto channel finder and tuner usually found in the set up section of the menu ? As well as was your TV working before and receiving input via the antennae but has now stopped working in this regard ? I also noted that attaching an analog to digital converter box worked fine , so your TV is capable of receiving a signal via that method , dose the converter box use your antennae input jack or a video jack to send the converted signal into your TV ? if it is using your antennae jack then it may not be a tuner problem .
Jul 19, 2014 | Sony Grand Wega Kdf-50we655 50-inch Lcd...
I am unable to tune in my mother- in- laws Sony Trinitron television Model KV-M14u as she has mislaid the operating manual when she moved down from Manchester. We have the remote but not the instructions...
Most Trinitrons use the menu button on the remote to set up funtions.Chanel Line Up, or set up chanels is under one of the funtions.Be advised that here in the US the switch to DTV requires that you have a DTV Tunner to receive over the air Broadcasts,Analog tuners no longer receive chanels(you need a converter box and anntena,Cable/Sat work fine.If this is an older model you need box.Try to get into menu,setup,chanels.Good Luck.
Sep 08, 2009 | Televison & Video
Converter Box Problem
If you are receiving digital signal and channel is fuzzy, something wrong. Only Analog signal is fuzzy. With Digital it is great picture or nothing. For channel 6, check to see if they are broadcasting in digital yet. If they are not, this is why you are not getting a signal. If they are broadcasting in digital, then you need a stronger antenna.
May 27, 2009 | Insignia Digital-to-Analog Converter for...
Can not get all my local channels
May Be becouse Antenna On Top Of Roof Is to old, Plugging cord in wrong place plug in: In
Mar 25, 2009 | Curtis-Mathis CM19011 TV
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Need help locating a box to make my TV receive true HDTV
You Dont need one your set is HD. So when the switch happens you are good to go. The only TVs that are going to need converter boxes is those who do not have HD or only have antenna.
Dec 27, 2008 | Hitachi 51F510 51" Rear Projection...
Analog/Digital
HDLCD2600 come set for cable. Make sure the tv is set for "tv" or "air" then run the auto channel memory or search feature of the set. If you have the manual it's under "memorizing channels". If your still have problems, call Sansui TV's customer service number 800 289 0980.
Nov 04, 2008 | Sansui HDLCD-2600 26 in. LCD Television
SONY DVP-NS57P does not display video
If your TV has no input selector but has a video input, the TV probably "hides" the video input between the lowest channel on the tuner and the highest channel. That means if your tuner goes from channel 2 to channel 119, the video input will be between 119 and 2. The best way to see if this is the case is to slect channel 2 and then use the up/down channel selector to go down and see if you find the video input. Let me know if this works!
Nov 02, 2008 | Sony DVP-NS57P
Receive one channel with Coverter Box
Make sure those 6 channels are also being broadcast in Digital format also, otherwise your converter box won't have a digital signal to convert for your TV. The switchover date is early next year I believe.
Oct 10, 2008 | Zenith C27A24T 27" TV
Insignia Digital-to-Analog Converter for Analog TVs Logo
64 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Alan Matzke
jason
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
