Question about Singer CG-590 Commercial Grade Sewing Machine
My singer CG-590 sewing machine wont feed fabric.
This problem happen after sewing the first 20 stitches correct, then it started making weird small stitches. Now it wont move the fabric all together. I am a beginner too so all the help I can get will be appreciated!
Happened to me to dont worry!! Its natural ;)
Posted on Aug 25, 2013
How to move feed dogs under needle for singer 514
First, make sure the feed dogs are in the up position and NOT dropped for darning.
Second, check that the stitch length is set to at least a 2 or 2.5 to make sure the feed dogs will actually move the fabric a noticeable distance. The closer the stitch length is set to zero, the closer together the stitches will be until it will sew only in one place because the fabric will no longer advance.
The feed dogs need to move. They should actually rise, move toward the back of the machine, drop down, move forward to the position to again rise--this creates one stitch. If the fabric is not moving, then it is possible that your machine has not been cleaned and oiled recently. Old oil will dry and cause the moving parts to seize.
It was working now it seems to be frozen the needle part wont move
Mar 07, 2016 | Singer Sewing Machines
I have a singer CG 590C. It didn't come with manual. I'm just learning to sew. My bobbin was hung up with thread when I pulled on it I pull the whole bobbin casing out. How do I get it back in? Help
First thing, you should probably get a manual for your machine.
Singer CG 590 Commercial Grade Manual
How to thread Singer CG 590
This machine is listed as a commercial grade professional sewing machine, so you are going to have some additional learning curve if you are just beginning to sew.
Nov 23, 2015 | Singer Sewing Machines
Singer 9030 runs but don't sew
try changing the needle--make sure the needle is the correct one
for the fabric being sewed.
also make sure the needle is turned the correct way in the needle
holder and pushed all the way up into the needle holder.
Nov 08, 2012 | Singer Sewing Machines
My singer cg 590 c puckers when I zigzag and sometimes when I sew straight seams
a wide zig-zag on a light weight fabric single layer is almost guaranteed to pucker up, just because the thread is under tension and this is often stronger than the fabric being pulled together by the stitches.
However, if a straight seam is puckering, this could be caused by a blunt needle, too big needle, or too tight tension or too long stitch length. You should be able to vary some of these variables to reduce the puckering and improve the stitch appearance. Other things to check might be the top thread being caught up somewhere in the thread path and pulling on the stitching.
If I am finishing the cut edge of aa single layer of light weight fabric I would use a three step zigzag to hold the fabric firmly and neatly.
Hope this helps a little?
Mar 29, 2011 | Sewing Machines
I am new at sewing, my machine is sewing small stitches and then larger stitches, I need it to just sew small sitches
Check to make sure the stitch length gauge isn't loose allowing it to jump between longer & shorter stitches, or that it isn't set on variable stitching. Something that could create this too is if you're holding the fabric too tightly so that the fabric feed doesn't pull the fabric through smoothly & easily - allow the machine to pull the fabric through on it's own and control the speed with your footfeed, not your hands. Hope this helps! Have a good time!
Nov 08, 2009 | Singer 3116 Simple
Singer CG-590
You can find a Users Manual plus a workbook that you can get in PDF and print. Users Manual is 44 pages and workbook is 58 pages. Go to www.mannualowl.com and search for Singer CG 590n manual. It's all free.
Apr 19, 2008 | Brother CS-8072 Computerized Sewing...
Threading CG-590
I have a CG590 SEWING MACHINE AND CAN NOT THREAD IT WITH THE DIRECTIONS THAT CAME WITH IT. CAN YOU HELP THANK YOU, SANDY
Sep 21, 2007 | Sewing Machines
Singer CG-590 Commercial Grade Sewing Machine Logo
416 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
