Question about GE Profile PFSS5RKZSS 25.1 cu. ft. French Door Refrigerator with Spill Proof Glass Shelves, QuickSpace Shelf, LED Lights, External Ice/Water Dispenser and Can Rack: Stainless Steel
Water will not dispense in my GE profile FSS5RKZSS. Ice is dispensing
  • 1073 Answers
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Posted on Apr 12, 2008
SOURCE: GE Profile side by side fridge - water dispenser doesn't work
More than likely, your water line is freezing up in the door. You can remove all of the ice cubes and lower the freezer temp to about 3. Leave the freezer door open for about 5 minutes or so and if this does not work, leave the door open a little longer. Also, disconnect the water line at the base of the freezer door, near the floor, and press the dispenser lever. If you have water there, you most likely have a frozen line in the door. Changing the water filter often will help but it is not the answer and is can get quite expensive. By the way, Make sure to hold the dispenser lever forward for at least a couple of minutes each time you test for water flow. If you do not get water at the connector at the base of the door after you have disconnected the line, you have a problem with the valve in the back of the refrigerator.
Posted on Nov 17, 2008
SOURCE: GE Profile TFT25 PR. Ice maker quit producing
Had the same problem. Replace the water filter and is should begin making ice again.
Posted on Mar 11, 2009
SOURCE: Ice dispenser only dispenses crushed ice
You may not need to replace the solenoid.  If you hear the hum, and not a loud click and don't see then rod move, it may be frozen with ice.  Test it manually with your hand, it should be free  to move up and down.  If not, then it is frozen with ice.  Remove the ice dispenser and let it thaw and dry out.  You should then be able to move to rod and it will work fine, at least until it freezes again.  Anyone know how to prevent it from freezing up? Its a continual problem for me
Posted on Mar 28, 2009
  • 19 Answers
SOURCE: Ice maker in our GE profile refrigerator is not working
Ice maker Diagnostic Test:
- Remove the ice bucket
-Turn the ice maker off, wait 15 seconds than turn it back on
-Press the ice paddle three times, this will begin diagnostic test.
-PLEASE DO NOT TOUCH ICE MAKER DURING DIAGNOSTICS
-In 3 minutes you should see the rack inside turn 360 degrees
-AND the ice maker bowl should fill with water
-IF either DID NOT work, call 1-800-GE-CARES for ice maker replacement. A service call is approx $80. The $80 will be deducted from the part/labor if you choose to purchase/install parts from the service technician. If not, you will pay for the service call. Good luck.
Posted on Apr 05, 2010
GE Profile PFSS6PKWBSS control panel display does not light up
more than likely the mainboard in the rear of the unit is defective,as the dispenser board gets its power from the mainboard and the dispenser bpoards normally dont go bad
Feb 01, 2013 | Refrigerators
GE Side By Side Ice Machine & Water dispenser not getting water
you may have a pin hole in your water line to your dispenser or you could be leaking at the water valve itself on the water dispenser side. you'll have to pull the refrigerator out from the wall and look where the main water line goes into the back of the refrigerator. you will probably have to take the back off to see. be sure you put the back of the refrigerator back when you are through.
Jun 05, 2010 | GE Profile PSW26P Stainless Steel Side by...
GE profile side-by-side water dispenser works, no ice though
Ice maker bad or the ice maker water valve mounted on the same bracket as the dispenser is bad. These frigs are prone to bad ice makers after a few years.
Sep 29, 2009 | GE Profile PSW26P Stainless Steel Side by...
My ice maker will not work, Ge profile Arctica.
Here you go...my dad had the same issues...Good Luck!
http://www.youtube.com/watch?v=sW2yqQjEcLI&list=HL1329704348&feature=mh_lolz
Jun 23, 2009 | GE Profile Arctica 25.4 Cubic Feet...
Ice maker only dispenses crushed ice, won't dispense cubed ice anymore.
I have a GE TFX25ppbaaa refrigerator. The ice maker corkscrew motor would run and provide crushed ice only. The corkscrew motor would not run when the switch was moved to the cubed ice ( half moon) setting.
I replaced the large Light/ water/ crushed ice/cubed ice switch , ( product service number GEH WR55X129 ) ( part number GE 162D6372 PO17 )and it fixed the problem. Cost was about $43.00.
Apr 17, 2009 | Refrigerators
Dispenser does not dispense
SOUNDS LIKE THE MICRO SWITCH OR PC BOARD BEHIND THE LEVER IS BAD,REMOVE CHECK CHECK AND REPLACE IF NEEDED,MIKE
Sep 03, 2008 | GE Profile Arctica Stainless Steel Top...
GE profile performance tfx30ppz ice dispenser not working
Had the same problem. The water line from the valve to the ice maker was cracked due to heat from the compressor.
Jan 09, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE Profile PFSS5RKZSS 25.1 cu. ft. French Door Refrigerator with Spill Proof Glass Shelves, QuickSpace Shelf, LED Lights, External Ice/Water Dispenser and Can Rack: Stainless Steel Logo
105 people viewed this question
Top Refrigerators Experts
Sal De
Charles T Nevin
Charles T Nevin
Randy Justice
