Question about Mitsubishi WD-73827 73" HDTV DLP TV
Picture getting darker over the years
I have a Mitsubishi 62 inch DLP TV that is about 3 years old and I am just notcing that my picture seems to be getting darker and less bright and vivid then when it was new. Is this common? Is there a solution for this? I have recently replaced the bulb and that didnt seem to help.
I've noticed no one has mentioned cleaning the optics and mirrors of the TV. If the TV optics become dirty this well effect the brightness. I would do a serch on the cleaning of DLP TVs. This will be the cheapest way to go.
Posted on Feb 07, 2013
    Sniper:
  • 53 Answers
It could be your Light Engine. However, I would first check a few things:
1. Make sure your Low Power/Lamp settings are adjusted so that they meet your brightness needs.
2. Make sure you used a Mitsubishi original lamp, as generics get chewed through fast and hard.
3. Try another lamp; sometimes you can get a bad one in the bunch.
All those things don't work, consider a Light Engine ($400 + for parts; $300+ for labor)
Posted on Aug 01, 2009
  • 80 Answers
SOURCE: Dark picture problem
did you change the lamp with an original or bulb only - mitsubishi only sells the lamp and housing!!!
never use generic
Posted on Oct 16, 2008
SOURCE: TV will not turn on
the tv sucks and is a total ripoff . i have the same one.
Posted on Jan 08, 2009
  • 11 Answers
there are 2 mirrors did you clean both there is one down in front near the light source when front screen removed lean in and look down there is another smaller mirrorclean it
Posted on Jul 07, 2009
kevin_gordon
  • 21 Answers
SOURCE: only 1/2 of my mitsubishi 62 inch dlp tv screen
Sounds like one of the light sources has failed or half of the projection source has failed(first is more likely)
If your TV is still on warranty you may want to call them to come pick it up. I doubt you'd want to move this yourself since it weighs over 100lbs
Posted on Aug 15, 2009
pimptwzt
SOURCE: Mitsubishi 1080p 73'' DLP HDTV - Color distortion
This would be the little sensor on the light wheel. Its cheap, you can get them online for around $2. You will need to take the light engine out and remove the color wheel cover and remove the color wheel and then remove the sensor. You will have to desolder the sensor and remove it to replace with the new one.
What is happening is the sensor is overheating and not tracking the color wheel properly there for the colors get messed up. Once you replace the sensor the tv should work like normal. The part is
(Sharp GP2S40 Photointerrupter). It is very difficult to find because they are not made anymore. Most major online part stores do not carry them but I found a lot of them at Wright Hobbies. Good luck.
Posted on Dec 24, 2012
Mitsubishi dlp tv picture is getting darker
One of two possible issues:
1. Lamp is nearing end of life and may dim just before total failure.
2. A few of these models have 2 mirrors(check with Mitsubishi to see if yours is one) A large mirror in back (never gives a problem and do not try to clean it. Some idiot in these sets used a small mirror inside that the optical unit shines the picture into (wedge shaped mirror and small) and it is facing up----the fans intake air from the front of the set around this mirror--it gets coated with lots of dust---Picture can loose up to 70% of its brightness and clarity if that mirror is dirty--looks like 20 year old set .
If you do not wish to check with Mitsubishi GOOGLE THE MODEL NUMBER with "mirrors" to see.
If it has 2 mirrors I can tell you exactly how to get at it.
SD TECH
Mar 31, 2012 | Mitsubishi WD-65736 Television
The color is really dim,
i have a wd62528 62" dlp hdtv that shows a picture but very dim. I have tried numerous things including factory reset and checking the lamp. I started to get a new lamp but was told if i have a dim picture getting a new lamp will do nothing. However, Mitsubishi support said that if i have a dim picture but was not continuing to get worse or darker, then they were 100% sure i just needed a new lamp. I'm confused. Will a new lamp solve my problem or no. i would just buy and try but it is very costly. please help
Nov 02, 2010 | Mitsubishi WD-62528 62 in. LCD Television
Samsung dlp has dark picture?
It sounds like your lamp is about to die out,this tv lamps are good for 6000-8000 life hours witch is a average time of 2-4 years old and with time the picture starts to get darker and darker until one day black screen here is a link with the lamp you need
http://www.discount-merchant.com/SearchResults.asp?Search=BP96-00608A
Sep 03, 2010 | Samsung DLP HL-P5663W 56" TV
My 62 inch dlp tv came on and was working then with out any noise or notice the picture went to black and a steady red light came on under the word "lamp". We looked at the bulb and it does not look burned...
The tv lamp was replaced when? The tv on about 4 or 5 hours a day right?The lamp was replaced about a year or a year an a half ago?The projection lamp is dead,the life span is over.Must replaced with a new lamp.
Jul 01, 2010 | Mitsubishi WD-62525 62" Rear Projection...
Jan 02, 2009 | Mitsubishi WD-62327 62" Rear Projection...
No picture on my 62" DLP Mitsubishi
I am not sure what the problem is, but usually if a lamp is bad, the other 2 lamps will still function. Since you are getting no picture at all, I am thinking it is a circuit board problem. TV electronics are expected to last 3-5 years. After that, many components will start to go out one by one. If you have your tv repaired, I would replace the whole circuit boards instead of just the bad component. The power board is the #1 board I would replace 1st. This is the most stressed board and will cause most of your tv problems.
Dec 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
never use generic
Oct 06, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi rear projection tv color problem
I'm going to guess that this unit is a DLP projection set and that the lamp is not new. Try a new lamp. The heat of the lamp will char over time. If not the lamp, some of the internal filters in the light engine might be getting effected by heat and require replacement.
Keep us posted.
Dan
Sep 12, 2008 | Mitsubishi Televison & Video
Samsung 61 inch DLP Has a strobe light affect
possible color wheel,call for est cost of repair
Jul 29, 2008 | Samsung DLP HL-P5663W 56" TV
Picture seems to be alot darker than before. toshiba 62hm95
I just replaced a lamp in a Sony LCD projection that was just over a year old and it was bad. It was a VERY dim picture. You have a DLP but, in either case a dim or dark picture is almost always caused by the lamp.
Feb 23, 2007 | Toshiba 62HM95 62" HDTV
Mitsubishi WD-73827 73" HDTV DLP TV Logo
461 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
