Question about Ricoh Aficio MP 2000 Black and White Copier
Error occurred sc: 982 - Ricoh Aficio MP 2000 Black and White Copier
4 Suggested Answers
  • 903 Answers
SOURCE: help me : Ricoh aficio
sc982 is usually an error with the NV-RAM (non-volatile RAM). Have you recently replaced the NV-RAM? If so, it probably just isn't sitting right on the board.
Have you tried turning the machine off (with the main power switch) and turning it back on? If the error reappears, you likely have a problem with your NV-RAM and it will need to be replaced.
Sorry for the bad news, but hopefully this information will help.
Posted on Sep 24, 2010
  • 126 Answers
SOURCE: my 2000le says error occured
you machine language does not match your country language. you have to change the language settings in the copier SP mode. only a Ricoh technician can change it. please consult a Ricoh Technician as you cannot enter the machines SP mode.
Posted on Jan 03, 2011
  • 525 Answers
SOURCE: error occured sc:982 Please help
SC: 982 Localization error
Symptom: The localization settings in the nonvolatile ROM and RAM are different (SP5807).
Possible Cause:
- First machine start after the NVRAM is replaced
- Incorrect localization setting
- NVRAM defective
Posted on Feb 02, 2011
Error OCCURRED SC:982
real hard to guess make and model so U do the searching on google .com
Mar 07, 2015 | Office Equipment & Supplies
Mp 2000 sc 982
i'm guessing == Scan, Color
Jan 03, 2015 | Ricoh Aficio Mp 2000 Copy Machine
Hai ....am vivek .please help me dears...i have RICOH Aficio 2045 ...it will appears sc 990. What's the solution for this error?? Plz help me ...
SC 990 is software performance error. This means The software attempted to perform an unexpected operation.
Possible causes:
1. Software defective
2.Internal parameter incorrect
3.Insufficient working memory
4.When SC occurs, the file name, address and data will be stored in NV RAM this information can be checked by using SP 7403. Note the above data and situation in which this SC occurs. Then report the data and conditions to your technical control center.
Apr 23, 2013 | Office Equipment & Supplies
Error occured SC:302 Functional Problem Turn main power switch off and on if the error appears again. Call Service
SC:302
Charge roller current leak
Symptom: A current leak signal for the charge roller is detected.
Possible Cause:
?? Charge roller damaged
?? High voltage supply board defective
?? Poor connection of the PCU
May 27, 2011 | Ricoh Aficio MP 1600L Black and White...
Error occured sc:982 Please help
Possible Cause:
- NVRAM defective
Feb 02, 2011 | Ricoh Aficio MP 2000 Black and White...
We could not complete your itunes store request unknown error occured 42110?!
This error can occur if you are not running the latest ITunes software or remove the SC Info folder. See support article from Apple for details on removing this SC info folder on your operating system: http://support.apple.com/kb/ts1597
Jan 29, 2011 | Apple iTunes
My 2000le says error occured 982
Nov 29, 2010 | Ricoh Aficio MP 2000 Black and White...
Help me : Ricoh aficio MP 1600 ero SC 982?
Sep 13, 2010 | Ricoh FT5832 Copier
982 Service Engine
This is caused by an option on the printer not be seated correctly or there's a prob. with 2000-sheet feeder option.
Usual Cause:
  1. Reset power or power the printer off and on.
  2. If this does not resolve the error:
  3. Power the printer off.
  4. Reseat all of the paper feed options on the printer:
    • Remove all optional drawer options, like a tray 2 or tray 3 drawer, and reposition them from the bottom up.
    • Reseat the printer on top of the duplex option, if one is installed.
    • Reseat other options such as the envelope feeder or additional output bins.
2000-sheet feeder option? See below:
Explanation of the Issue
A cable can come loose inside the 2000-sheet feeder option and cause one of the following three conditions to occur:
  • The printer displays a 982.xx error. NOTE: The .xx extension can be any number.
  • The printer displays a 990.xx error. NOTE: The .xx extension can be any number.
  • The printer does not recognize the 2000-sheet feeder option installed.
The issue is with a toroid on one of the cables (see the blue/black wire cable highlighted in the image below). When the 2000-sheet feeder option is moved, the toroid can pull the cable loose, causing an error. NOTE: This toroid was removed in later versions of the 2000-sheet feeder.
Jun 11, 2009 | Lexmark T644 Laser Printer
Ricoh Aficio MP 2000 Black and White Copier Logo
21 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
OfficeServiceAjnc
OfficeServiceAjnc
fares
Level 1 Expert
SOURAV KAPOOR
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
