Question about Bernina Sewing Machines
Bernina 1260 I can't get the new light bulb to stay on
Needed to replace light bulb but the new one won't stay on I know it is working but it just flickers
3 Suggested Answers
SOURCE: Bernina 1230. Works fine except the two bulbs
Did more research and found the answer on a FREE site.
Posted on Nov 22, 2009
  • 1116 Answers
SOURCE: Bernina 1230. Works fine except the two bulbs will
I have had this happen and found the switch was broken and not making contact inside the machine. We prepped the plastic and use a two-part glue for plastic.
I don't know how long the repair lasted as I sold the machine.
Posted on Mar 11, 2010
How do I change a light bulb in my Bernina 707?
I don't have a 707 but do have a 530-2 Record. Unfortunately, with some of these older machines, Bernina did not provide a very good method for accessing the light bulb. On later machines, the side cover would either be hinged or removable. If yours doesn't have this capability, the only way of changing the bulb is by reaching in with your fingertips, gripping, and turning the bulb to remove it and then installing the new bulb in the reverse manner (difficult for someone with big fingers). Sometimes it helps to use thin rubber gloves (like the surgical type), lightly moisten the finger tips to provide more "grip." There is also a sewing tool available that is somewhat like a pencil with a rubber suction at the end made specifically to help with replacing sewing machine bulbs. If you are creative, you may be able to fashion something similar.
Have you tried LED bulbs? I've installed them in all my Berninas. They provide a lot more light and do not get as hot as the regular bulbs--as well as, they supposedly last much longer! They seem expensive at the outset but if I never have to change a bulb again, so much the better!
In case you need it, here is the manual for your machine:
BERNINA Sewing Systems
Oct 17, 2017 | Bernina Sewing Machines
I removed the old light bulb and now trying to replace it on bernina 930. the bulb is the right one but it won't go in
Ah-ha--have had the same problem. When you remove the old bulb, there is a black flipper inside that is spring-loaded and closes. You have to hold that flipper open in order to push the new bulb into place.
Inserting light bulb into Bernina 930
Mar 12, 2017 | Bernina Sewing Machines
How is it possible to replace the light bulb in the Bernina minimatic 807? I managed to remove the dead bulb, but cannot install the new one
Try using rubber gloves, like surgical gloves and moisten them slightly. Usually, that will provide enough grip while trying to insert it. Very difficult from experience. But, can be done.
There is a bulb insertion accessory tool included with some newer machines (although not Bernina--another brand) that is basically like a cut-off plastic chopstick with a suction device on the end. If you are creative, you may be able to fashion something of your own.
Dec 22, 2016 | Bernina Sewing Machines
How do I change the light bulb on my Bernina 1530?
You might check out some of the older Bernina manuals to get an idea of how it may work in your machine. The 1260 is the closest manual available. Looks like your machine takes the same push-in bulb. So, you would push up on the bulb and twist. Then you would install the replacement the same way. Sometimes, using tight fitting medical gloves helps grip the bulb in order to twist.
BTW--I have older Berninas and upgraded their bulbs to LED.
Oct 03, 2016 | Bernina Sewing Machines
What to do when foot pedal just stopped working on old Bernina 830
There are a few problems possible. Assuming that there is not a mains (house) power problem, use the following logic to sort out the problem:
1. Do you have a light (assuming that the light bulb is good)? continue to #2.
2. With the machine unthreaded, the presser foot up, and the power cable plugs fully plugged in at the motor and foot control, depress the control to the run position.
Carefully bend and wiggle the cables at the plug locations one at a time. If the motor runs, the cable wires are damaged so you will replace the cable.
3. If available, try a (known good foot control) from another Bernina 830 of that exact vintage.
If the test foot control runs the machine, replace your foot control. Note: If the foot control is a type 213 for very old models, suggest that the control be replaced with a two wire electronic phase type control. (requires the foot control plug end to be cut off and rewired to the new phase controller). These electronic phase controls can be purchased from EBAY. Stay away from the Bernina type 213 control if possible. The type 213 controls have not been available for many years and it is highly likely that these controls are in a used condition, so you will not know if it has been properly adjusted.
If the 830 is a later model machine with the type 232 or 290 foot control and it is determined to be defective, no problem as they can be repaired.
4. If the (known good foot control) still does not work, you can assume that the motor has a problem. Motors for the Bernina 830 are occasionally available on EBAY and other sources.
Note: If the motor brushes have worn out and the commutator has been damaged, the motor is also salvageable.
Note: Always unplug the machine from the mains power when not in use as per Bernina instructions.
SewTechnical Home
Jun 05, 2014 | Bernina Sewing Machines
Bernina Display backlight not lighting but machine working
Bulb is burned out. Install a replacement bulb.
Feb 08, 2014 | Bernina Sewing Machines
How do I Replace light bulb in bernina 1010
Theres a gray flexible cap about 1.5" long and .75" in diameter that comes with the machine. It is used as a tool to screw and unscrew the bulb. Weirdly I have had my machine since I bought it new in about 1987 and have never replaced the bulb. And I do use it, at times heavily.
Aug 17, 2012 | Bernina Sewing Machines
Nov 21, 2009 | Bernina Sewing Machines
Bernina light won't stay on
the switch may be faulty when you say that you can press in just have a look at the switch for dirt or just replace
Apr 23, 2009 | Sewing Machines
Bernina Buttonhole foot #3A
Hi, you must have an 1130S which means it could also be a circuitboard issue. If the LED/LCD light for the buttonholer does not flash you either need a new RET-Print (circuitboard) or a new buttonhole foot. Sorry to say that you DO more than likely need a new buttonhole foot according to my manual on this machine. No way to repair the foot that I know of.
You should bring the machine in and try it first.
Guess not all news is good news. Sorry.
Rick (Bernina tech)
Aug 18, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
63 people viewed this question
Top Bernina Sewing Machines Experts
Tally Girl
Tally Girl
jnissen
Level 1 Expert
Derek Massey
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
