Question about Dishwashers
Does the 154587401 dishwasher have a filter that requires removal and cleaning
2 Suggested Answers
co7196
  • 3433 Answers
SOURCE: dishwasher isnt getting water too it and stops half way through the cycle are there any filters on the machine that require cleaning?
No,No, inlet filter. Sounds like the water control solenoid is not opening or you have a hose kinked or the water turned off under the sink--Note, no intentions of insult, Just need to check everything checkable before calling in costly help. Good Luck. Thissolenoid is controlled electricaly throught the timer, so either one could be faulty.
Posted on May 24, 2009
Bosch dishwasher sgs43e how do I replace water filter
Bosch dishwashers don't have water filters per say. It may have a salt water softening system. It does have a small mesh filter in the inlet hose but if there is any kind of actual water filter inline with the system then it is external to the dishwasher.
They do have though microfine filters in sump of the unit which require cleaning regularly. This is removed by turning the plastic handle anticlockwise on the grill which is under the bottom spray arm. You turn the plastic handle to unlock the grill and lift it up revealing the filters.
Refer to the user manual for more information. If you don't have it, you should be able to download it from the BSH website.
Jun 09, 2014 | Bosch Dishwashers
How to clean the filter
Most require removing the bottom spin arm and the screen. There should be a filter under that screen that can be cleaned.
Jan 28, 2013 | Dishwashers
Filter needs cleaning. How do I get at the filter?
Dishwasher filters are important to catch food particles and other debris. The dishwasher cleans small portions of food from the dishes, cooking pans and silverware. These particles must go somewhere. The drainage system on the washer may clog if filters are not present. Most Maytag dishwasher models have two types of filters, "Coarse" and "Fine." You should clean the "Coarse" filter after two or three wash loads. The "Fine" filter can wait for a cleaning for about 300 loads or three months.
jQuery('.intro .thumbnail').each(function(i,e){ jQuery(e).find('img').one('error',function(){ jQuery(e).remove(); }); }); Difficulty: Easy Instructions Things You'll Need:
  • Sink sponge
  1. Empty the dishwasher. Remove all dishes including pots, pans and silverware.
  2. Pull the bottom rack out as far as possible. The filters are under the basket on the Maytag dishwashers. It may be convenient to lift the rack out. Typically, if you lift, the wheels leave the track.
  3. Remove the "Coarse" filter. This filter is a small, round knob in the middle of the "Fine" filter. A round knob is around the "Coarse" filter. Hold on to the handle and lift straight up.
  4. Knock the contents of the "Coarse" filter into the garbage can. Run the faucet to remove smaller particles. Wipe the dishwasher filter with the sink sponge if debris is stuck-on. Push back into the filter holder when complete.
  5. Take out the "Fine" filter. Turn the round knob that is around the "Coarse" filter counter-clockwise. Once the knob is loose, pull up. The "Fine" filter will come out of the dishwasher.
  6. Rinse the "Fine" filter with the hot water faucet. Scrub with the sink sponge to remove any stuck-on fragments. Replace the filter into the dishwasher. Push down and turn the knob clockwise to tighten.
Jan 09, 2011 | Dishwashers
I have a KA dishwasher model number KUDM24....is there any maintenance, i.e.e filter to clean. Dishes do not seem to be getting as clean as they once were. Residual on glass ware, not bad but not...
There are many probable causes of failure .
A dishwasher's water inlet valve is its most common part to fail. When your dishes are not being fully cleaned, quite often a faulty water inlet valve is to blame. Test your dishwasher's water inlet valve, and if it is no longer functioning as it should, you will have to replace it.
Water temperature is a key element in achieving clean dishes. A dishwasher's heating element is not designed to heat the water that enters it. Rather, the heating element is designed to maintain the heat of the water that enters the dishwasher. Its a good idea to run the hot water in your sink for a couple of minutes before you run the dishwasher. Just to make sure the water is nice and hot before it enters the dishwasher. If the water is unable to stay hot, it can adversely affect your dishwasher's cleaning ability.
There is a filter in your dishwasher. Its function is to keep large particles of food and foreign objects away from the pump. Many of the newly-manufactured dishwashers have self-cleaning filters, and routine cleaning isn't a concern. However, some other dishwashers need to have the filter removed and cleaned regularly. If the filter or grate is clogged or blocked with debris, it may interfere with the normal functioning of your dishwasher
On some models in kitchen aid you must lift off the spray arm and then lift the filter up. It is fastened with spring clips. On other models removing the spray arm reveals screws at the top of the filter housing that need to be removed to get the filter up.
Oct 29, 2010 | KitchenAid Dishwashers
Is there a filter on seimens dishwashers as i seem to have a blockage and the water wont flow away
Yes there are filters, and also it is easy to pinch the drain hose. If drain goes into disposal, be sure teh plug is removed from disposer port. The filters require surgery to find and clean.
Oct 13, 2010 | Siemens Dishwashers
How do you clean the filter
Of all the problems you might encounter while using your dishwashermag-glass_10x10.gif, a clogged filter is one of the easiest to fix. The filter can get clogged with food or detergent, which can block the water from flowing correctly through the spray arms. Although you should check your user's manual for directions more specific to your dishwasher's filter, there are some simple things you can do to make sure that your filter is squeaky clean.
  1. Step 1 Disconnect the dishwasher from its power source. This may require unplugging the dishwasher or flipping the appropriate switch on the circuit breakermag-glass_10x10.gif.
  2. Step 2 Remove the bottom rack from your dishwasher.
  3. Step 3 Remove the filter cover, which should be located on the bottom surface of your dishwasher.
  4. Step 4 Use your hand to remove the worst of the debris. If necessary, wash the filter with soap to remove the heavier grime.
  5. Step 5 Replace the filter and the lower rack of the dishwasher.
    You can also use a wet vacuum to clean the filter.Make sure to replace the filter after cleaning. If it is not replaced, the grime that usually gets stuck in the filter will end up on your dishes
Nov 15, 2009 | KitchenAid 24 in. KUDS25SH Built-in...
Water is not coming out of the top water jets for dishwasher
What is the model of this KitchenAid diswasher and approximatly how old is it? On some newer, energy saving models water is alternated from lower to upper spray arms. But ...
Remove filter that is in the sump area beneath the lower dish rack. Screws will need to be removed to open the area up. Look for blockages and clean filter.
Reassemble and test. If problems remain, it is probably a failing pump motor and will require a service call.
Mar 30, 2009 | KitchenAid Dishwashers
Silverware and dishes not getting clean, leaving grit on dishes
It cleans poorly If your dishwasher is cleaning poorly, check these:
Water-inlet valve
Internal filters
Drain valve
Spray arms
Water temperature
Detergent cup
Water-inlet valve Most cleaning problems are caused by the dishwasher not getting enough wash water, so the water-inlet valve is often to blame. This valve is usually at the bottom left or right of the dishwasher, behind the lower access panel. It's the device with the main water line from the house, a rubber tube to the dishwasher, and two wires attached to it.
When a water-inlet valve is defective, you may hear the sound that's usually referred to as "water hammer." If the water-inlet valve is defective, you need to completely replace it.
Dishwasher Water Inlet Valve Replacement
Be sure to read and understand any instructions that come with the new water inlet valve.
Tools required:
Adjustable wrench
Multi-Screwdriver
Pliers
Step 1. Disconnect the dishwasher from its power source.
Note: Dishwashers are usually wired directly to the home’s electrical system. To disconnect the power, switch off the circuit breaker or remove the fuse for the electrical circuit the dishwasher is attached to. Try to turn the unit on after disconnecting the power to be sure you were successful.
CAUTION: If you’re not sure you’ve shut off the power properly, DO NOT CONTINUE. Call a qualified appliance repair technician to complete the repair.
Step 2. Turn off the water supply to the dishwasher. This is usually underneath the kitchen sink or in the basement or crawlspace near the location of the dishwasher. Pliers may be helpful here.
Note: If there are no shut-off valves, you must shut the water off at the main water supply valve for your home.
Step 3. Remove the lower panel(s) of the dishwasher. These are usually held by 2 to 4 screws at the upper and lower corners of the panel(s).
The inlet valve is usually near the front of the dishwasher. Attached to the valve you’ll see: 2 or 4 wires, the water supply line from the house and the water feed line that goes to the dishwasher.
Step 4. Remove the household water supply line from the valve. The line is usually secured with a brass compression nut. The water supply line is usually copper or braided stainless steel.
CAUTION: Water supply line may be hot.
Step 5. Remove the fitting from the valve the water supply line was attached to. This fitting may be very difficult to remove. It may help to put the valve into a vice in order to remove the fitting. If you cannot remove it, replace it. The fitting is not an appliance part but a plumbing part that is available at most hardware stores.
Step 6. Remove the screws holding the valve to the dishwasher frame.
Step 7. Label the wires to the valve so you’ll be sure to reattach them correctly.
Step 8. Remove the wires from the valve.
Step 9. Remove the clamp on the black rubber water discharge tube and pull the tube off of the valve.
Step 10. Reinstall the old fitting (or a replacement fitting if necessary) onto the new valve the water supply line was attached to. Use Teflon tape or pipe joint compound as a thread sealant. Make this fitting tight to prevent leaks. Make sure that the fitting points in the same direction as the old one so that the water supply line will meet up with it properly.
Step 11. Install the new valve in the reverse order of the removal instructions.
Note: The water supply line is under high pressure. Be sure to tighten the fittings properly.
Step 12. Turn on the water to the machine, and check for and correct any leaks.
Step 13. Reinstall the access panel(s). Restore the power to the dishwasher and test.
Note: You may have to let the dishwasher run a few minutes before it reaches the next water fill cycle.
Internal filters Every dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
  • Most modern dishwashers have self-cleaning filters that don't need any routine cleaning.
  • Some have filters in the bottom of the dishwasher that you need to periodically clean. You don't need any tools to remove the filter, and cleaning it is easy. Consult your owner's manual to determine which type you have and its maintenance requirements.
If your filter is clogged, it may be causing the cleaning problem.
Drain valve Some dishwashers have a valve (or gate) that should open only during draining. If debris lodges in the valve, it can't close properly, so water drains out during the wash cycle. Most dishwashers drain into the garbage disposer. If yours does that, listen for water flowing into the disposer during the wash cycle. If you can hear it then, the drain valve may be clogged.
Spray arms There's a spray arm at the bottom of your dishwasher--it may have a tall spray tube mounted to the center of it. There may also be a spray arm located directly beneath the upper rack of dishes and/or above the upper rack.
If debris is blocking the holes in the spray arms where the water comes out, it could cause cleaning problems. Regularly inspect each of the spray arms and clean out the holes as necessary.
Water temperature To get the best cleaning results, the water entering your dishwasher needs to be hot enough. Try running the hot water in your kitchen sink for about 30 seconds before starting the dishwasher, to pre-heat it. Also, if your dishwasher lets you select a higher wash or rinse temperature, try that to see if it helps.
To check the temperature of the hot water that comes from your kitchen faucet use a waterproof thermometer. If the water isn't 120 degrees Fahrenheit, your dishwasher may have trouble getting your dishes clean. You could increase the temperature of the hot water to the whole house--and therefore the dishwasher--by adjusting the hot water heater thermostat.
Warning! To lessen the risk of scalding, don't set the hot water heater temperature higher than 120 degrees Fahrenheit.
Detergent cup Dishwashers don't perform their best if detergent is introduced only at the beginning of a cycle, so add detergent to both parts of the cup.
Mar 03, 2009 | Bosch 24 in. SHU66C02 / SHU66C06 Built-in...
No clean dishes
Internal filtersEvery dishwasher has some type of filter to keep large food particles and foreign objects away from the pump assembly:
Drain valve
Spray arms
Detergent cups
If the detergent cup isn't opening, see the "The detergent cup doesn't open" section, below.
Sep 12, 2008 | Kenmore 16602 / 16604 / 16609 Built-in...
D1260 indesit dishwasher
The pump is situated underneath at the right hand back of the machine, you will need to remove the right hand panel to gain access. its not an easy job as it will probably need replacing. a local engineer should charge around 60-70 gbp
Dec 03, 2007 | Indesit 24 in. IDL700 Built-In Dishwasher
Dishwashers Logo
47 people viewed this question
Top Dishwashers Experts
Owen Barnes
