Question about Global Door Controls Residential Mini Door Closer in Brown TC901-BR
How to install a door closer - Global Door Controls Residential Mini Door Closer in Brown TC901-BR
    Habit-Forming:
    Filmmaker:
    Uploaded 5 video answers.
  • 108 Answers
Most come separated but if not separate the arm that holds to the door and door frame. Look to your installation manual or instructions to see the proper placement of unit to door. Depending on the door/frame you might want to pre-drill some holes for the screws after placing and marking the spots. Place the main piece back on an screw to the door. Mark out where to drill the arm to the frame of the door. Turn arm or use screws to adjust it to fit to the main unit without connecting it. On the bottom take the cap covering up the nut and turn it 30 - 45 degrees (or recomended by maker) with wrench HOLD it there until you connect the arm to the unit. Make sure that it connects properly. After screw the arm onto the unit and recover bottom with cap. Done!
If the door closes too swiftly, slams, or is hard to open then it needs to be adjusted by turning the S, L, or BC valves on the side.
S- how fast it swings from wall to 1-3" from door frame (hits you)
L- those 1-3" to the frame ( Slamming)
BC - controls how much force is needed to open the door
Posted on Jun 05, 2015
Why wright pneumatic door closer v150 slams closed
Adjust the speed. Adjudsting screw in the end of it (on the door edn). Tun it in to slow down, out to speed up. Should only need 1 or 2 turns. If still not adjusting, replace the unit.
May 13, 2014 | Wright Products Heavy-Duty Black Pneumatic...
How spring gate closer works without any human intervention or electricity?
It's a device that consists of high quality steel spring in a spiral shape which is installed around the door or gate that close the door automatically without any human intervention or electricity. For any further information about gate closers you can check this Web Site.http://www.gateshut.net/details-of-gate-closer.html
Jul 18, 2013 | Lockey Hydraulic Gate Closer TB600 Heavy...
Any one can suggest me child proof door closer system?
I think you'd try spring Gate Closer system because they are not heavy as compare to hydraulic door closer system and close the door not forcefully as other door closer system.And it's easy to install. http://www.gateshut.net/about-gate-closer.html
May 14, 2013 | Cars & Trucks
I have 2 mintcraft hydraulic door closers and one of them will not close on its own when opened past a certain point, is there a way to fix this?
The problem you have is there is either something inside the closer keeping it from closing or the closer is worn out and has tightened up. You can take the closer off and see if you can get it to work without being attached to the door to determine what is causing the problem. Also if your door is in a windy area then that could cause it to stay open. If you can't figure out what's causing the problem then you can replace the closer with a new one. If i'm not mistaken they run somewhere between 10 to 20 dollars depending on where you go to buy one.
Feb 07, 2013 | Mintcraft Black Hydraulic Door Closer...
Door on fridge side has droped 10mm the plastic washer has worn away i think .Can i get a spare please its situated at the bottom of door
Take the model number ( you didn't list it here ) to a parts house and tell them you need the door closer for the frig door . To install , remove the 3 screws holding the top door hinge located under tho top hinge cover , and lift door off bottom hinge . Remove all food items from door first . The closer should come with a lower hinge and the piece which attaches to the door . If not , tell them you need the door piece also. Or the kit may come without the hinge , but , with both the hinge piece and the door piece in the package .
Aug 09, 2009 | Refrigerators
Top of refrigerator just inside the fridge door has condensate collecting and eventually dripping onto the floor. I "inherited" this fridge from previous tenant who SWEARS that it is was caused by a...
If the door pops open after you close it, or the door is hard to push closed, the door closing mechanism has probably failed. Make sure you check for the obvious things, such as something sticking out of one of the shelves or orange juice cans rolling around the door shelf area causing the door to bounce back open when the door is slammed.
If you notice any unusual sounds when the door is opening and closing, such as a clicking or grinding sound, your door closer is probably worn.
There are three common types of door closers used in domestic refrigerators and freezers. We list here all three, along with how to access each component in order to change it.
The most common door closers used today are small plastic cams mounted at the bottom of the refrigerator and freezer doors. When you open the door, you cause the door to climb up onto the lower cam. When the door is released, the incline helps the door shut. To view a common door cam kit, <a href=" http://www.repairclinic.com/0081.asp?RccPartID=1035 ">click here</a>. You can see how the upper and lower cams each have a hill and valley that work against each other to make the system work.
In order to change these, remove all food in the door, and remove the upper hinge in order to take the door off. Most hinges have a plastic cover that can be removed by prying up on it to expose the upper hinge screws. Usually, the cams mount with one screw -- one on the bottom hinge and the other on the outer door panel. On some models, the lower cam is riveted onto the lower hinge, and it's easier to purchase the lower hinge complete rather than try to drill out the old rivet.
If the cams you are replacing are for the freezer door that has a water line going through the middle of the cam, you not only have to remove the door but you must also disconnect the water line. Most water lines are fed through a channel in the door panel and clamped into place in the dispenser housing. Or, there may be a quick disconnect fitting behind the kick plate or apron on the unit. Once you've installed the new cams, you may want to put a light coating of lithium or silicone grease on the surfaces where the cams meet.
Another type of door closer is actually part of the upper hinge assembly itself. To view this style of closer <a href=" http://www.repairclinic.com/0081.asp?RccPartID=781123 ">click here</a>.
In order to change this style, pop off the hinge cover, and remove the screws that retain the upper hinge. From there, pry up on the hinge and pull it through the hole in the outer door panel. If the spring is broken and will not come through the hole, remove the inner door panel. This is a big job so you might want to remove the door and lay it on a flat surface. Fold back the door gasket and remove all the screws around the perimeter of the door until you can separate the inner door from the outer door to gain access to the hinge assembly.
A third type of door closer commonly used is one that is internally mounted to the outer door panel, and you must separate the inner and outer door panel to gain access to the closer. To view this type of closer <a href=" http://www.repairclinic.com/0081.asp?RccPartID=616347 ">click here</a>. In this style, the hinge pin actually goes through the closer. The hinge pin has a flat spot on each side of it that meshes with the cams on the closer. To view this style of hinge pin <a href=" http://www.repairclinic.com/0081.asp?RccPartID=641650">click here</a>. On some Sub Zero units, this closer is mounted to the lower portion of the door and removal of the inner door panel is not necessary.
May 05, 2009 | Refrigerators
Briton 2003 door closer slamming closed
This product has a Ten year guarantee, return it and get your money back and buy a Dorma TS72 adjustable door closer.
Cheers
Mar 20, 2009 | Hardware & Accessories
Lost instructions & templates.
you can fined it here cheers peter ,,http://www.ferret.com.au/c/Locks-Galore/Ryobi-door-closer-range-available-from-Locks-Galore-n665613
Sep 23, 2008 | Ryobi Multi-Volt Battery Charger
Global Door Controls Residential Mini Door Closer in Brown TC901-BR Logo
655 people viewed this question
Top Global Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Global Hardware and Accessory Expert? Answer questions, earn points and help others
