Question about Caterpillar C15 Acert Engine Wdisplay Standdiecast
Anti freeze leaking out of freeze plug on front passenger side
Why does my Buick Rendevous, 2005, leak water into both front floorboards?
Is it leaking water or Anti Freeze?
If it's Anti Freeze you can pull down the rug or floor mat to check, you should also smell the Anti Freeze. This means your heater core is leaking & has to be replaced, if it's not leaking bad you can try a sealer called Aluma seal (my spelling could be wrong),looks about the size of a roll of dimes, most auto stores have it.
If it's water, my guess is the AC condensation hose is blocked. Does it leak only when the AC is on? this hose runs outside, usually on the
passenger side behind the front wheel, when the AC is on & condensation builds up, you will see water coming out on the ground, this is normal, but if that hose is pinched or blocked the water could end up running onto your floor. Hope this helps.
Sep 08, 2014 | Cars & Trucks
Overheating
Was the coolant old and weak? At ten degrees, a weak coolant could result in freezing and that can cause an engine freeze plug to burst open. Check the side of the engine block for signs of leakage around the freeze plugs. Another possibility is the heater hoses. They run along the passenger side of the engine as well. The last possibility is the heater core. If it leaks you may smell coolant inside the passenger compartment. You MAY get a wet floorboard on the passenger side. Coolant leaking from the core usually will fall into the condensation pan for the A/C and run out of the passenger compartment thru the firewall on the passengers side.
Jan 07, 2014 | 2003 Chevrolet Silverado 1500
99 ford f250 6.8 litre engine i have anti freeze in my two front spark plug ports on the passenger side
could be intake, could be head gasket. take the radiator cap off and fill it to the brim with water, then start the engine and look for bubbles in the water. you might have to top it off while it's running to get a good reading. if any of the plugs you took out were much cleaner than the rest, or had a white crust deposit on them, the head gasket is probably the culprit.
Feb 27, 2013 | Cars & Trucks
My 1994 chevy caprice is leaking water
will try to help. where is the leak coming from? can you tell?under the front of motor where the engine fan is? could be water pump. could be a busted hose,upper or bottom radiator hose.there are 2 hoses that run to your heater core at the firewall or dash panel, could be there. leaking from sides of engine? could be a freeze out plug rusted through or if it's gotten below freezing and you did'nt have anti-freeze, most likely a freeze plug, they are designed to save your engine block from busting when you don't have anti-freeze in freezing weather. if you can repost your problem with a location, front, sides, or inbetween the back of engine and transission, i can help you. hope this helps and thank you for choosing fixya.com
Nov 21, 2010 | 2005 Chevrolet Equinox
Anti freeze leaking from bottom of engine on front passenger side... Any ideas ?
TIGHTEN HOSE CLAMPS NEAR FIREWALL UNDER HOOD, TRY COOLANT STOP LEAK
Nov 19, 2010 | 2001 Hyundai Accent
Anti freeze leak across the front do this car
yes it has freeze plugs,water pump may be leaking,fuel pump has nothing to do with coolant leaking
Dec 20, 2009 | 1992 Buick Park Avenue
Coolant leak front passenger side leaking anti freeze over right front fender well can not see leak
the coolant resvoir bottle is located above that fender well it's possibly has a small crack in it i just fixed one the other day
Oct 23, 2009 | 2003 Ford Taurus
Anti freeze leaks behind passenger front wheel
check heater hose lines and transmission lines to your radiator also check leaking at heater core
Oct 13, 2009 | 1996 Pontiac Grand Am
Caterpillar C15 Acert Engine Wdisplay Standdiecast Logo
78 people viewed this question
Top Caterpillar Toys Experts
fordexpert
Are you a Caterpillar Toy Expert? Answer questions, earn points and help others
