Question about Samsung RS2534 Side by Side Refrigerator
Samsung side by side SRS598NSS. fridge not cooling freezer working fine
The fridge freezer has always worked fine freezer set on -20c. fridge on 3c, Then I noticed the fridge was flashing on th 3c and the fridge now is not cold. freezer is fine, any idea, I have never had a problem with fridge/freezer. It is just over five years old.
SOURCE: Samsung RCS21DCNS Side by Side
probly the evaporator coil in fridge all frozen up you need to pull all the back out inside the fridge section and defrost with air drier
Posted on Sep 21, 2007
  • 9 Answers
SOURCE: SAMSUNG RS20CCMS
Defrost by turning off for 48 hours and the unit will work ok (for a while)
Its a design fault common to many Samsung Side By Sides
Posted on Sep 06, 2008
  • 5 Answers
SOURCE: loud noise from the freezer side
The problem is a buildup of ice on the plastic housing (the curved plastic bit) in the back of the freezer under the fixed shelf where the icetub goes. The fan behind this plastic housing is hitting the ice when the defrost comes on.
Unplug the fridge, unpack the freezer, remove the four screws in the back, take off the sheetmetal backing and let the fridge thaw. You can remove the plastic piece after a while and get the ice off (be careful not to remove the styrofoam insulation by going too quickly).
Reassemble and you're back in business, for a few months. I'm never buying Samsung again myself.
Posted on Sep 20, 2008
tborn6
  • 700 Answers
SOURCE: samsung rs2533sw fridge not cooling
it sounds like the refrigerator evap is frozen up causing the compartment to get too hot. shut the unit off and let it thaw out. then take the screws out of the cover to check the stryrofoam on the back side of the cover to see if theres broken spots on it causing the air to bypass the evap causing it to freeze. Theres two screws behind the light cover and two at the very bottom of the cover and two behind the decorative plugs about 1/2 way
Posted on Dec 22, 2008
heatman101
  • 43501 Answers
SOURCE: Samsung Side by side Fridge not cooling
Check out these tips...they can help you figure out whats going wrong with yourrefrigerator and why it is not cooling
Refrigerator not Cooling or Fridge not Cooling
How to Defrost Refrigerator Defrost Timer Problem
Water Running in refrigerator from Freezer
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Posted on Sep 30, 2010
Hi, my admiral side by side fridge is having problems. The freezer is working fine but the fridge is not cooling. I noticed 2 days ago that the temperature indicator for fridge was bleeping at 4 degrees. I...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
heatman101
Aug 28, 2011 | Admiral 26 cu. ft. Side-By-Side...
I HAVE A SAMSUNG FRIDGE SIDE BY SIDE .THE FREEZER DOES NOT FREEZE IT SHOWS 19/20 C ..THE COOLING SIDE WORKS FINE..WHAT IS THE PROBLEM
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Aug 21, 2011 | Samsung RS2630SH Side by Side Refrigerator
Fridge side not cold on lowest setting, freezer side is working fine any suggestions?
heatman101
Oct 16, 2010 | Samsung RS2630SH Side by Side Refrigerator
My Samsung Freezer isnt working but the fridge is fine
without checking equipment you can only assume things that may go wrong...1st..try fully defrosting complete unit,clean all vent/drain holes then switch back on and let unit do its thing for 24 hours.then check temperatures are minus 18-20c for freezer and plus 2-5c for fridge (approx)unless you have electrical meters to check, this is just about all you can do..
Feb 19, 2010 | Samsung RS2630SH Side by Side Refrigerator
Water dipenser
The instruction book suggests this could be because the freezer temperature is set too low. Mine is set at -20C. It says the water line can freeze stopping water flow. Try reducing the temperature.
Sep 03, 2008 | Samsung RS2630SH Side by Side Refrigerator
Fridge does not cool below 40 degrees
This is a common problem and a design fault...
Jun 25, 2008 | Samsung 24.8 Cu. Ft. Side-by-Side...
Samsung RS2534 Side by Side Refrigerator Logo
130 people viewed this question
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Dan Webster
Dan Webster
Paul
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
