Question about LG Nb3520a 2.1-channel Powered Soundbar With Power
Lg soundbars why does pmc2/0.0 show on display panel
Lg soundbar
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
Sep 03, 2016 | LG Televison & Video
A LG soundbar to a Laurus TV I've fix a optical lead one end and jack plug on the other but it doesn't work
A fiber optic cable carries infrared light path only. It's a digital signal, you can only connect this to equipment that has an optic connection. Adapting it with any kind of analog jack just simply won't function.
laurus tv images Google Search
checking the Google images of the Digital module does not show a tos-link connection for the module.
Apr 17, 2015 | LG Televison & Video
How do I get my headphones to work with my Panasonic smart tv and LG soundbar?
Let me see if I can understand what you want to accomplish.
You have a Panasonic Smart TV, and an LG soundbar. But you want to use a set of headphone. I guess that your TV is already connected to the soundbar, no?
The first thing that you need to check is for an output, it must be from the sounbar, it could be a 3.5mm jack, or an RCA jack. Usually soundbars only have input, meaning that only takes the sound in, never out. If you have an audio output from the TV, you c an always try, but the soundbar won't be use then.
Feb 06, 2015 | LG Televison & Video
How do I connect a soundbar optical cable to the 32884 techwood tv
You will have to use an alternate method of connection to your Techwood TV.
Jan 30, 2015 | LG Televison & Video
I have a lg 2540 soundbar connected to my 37inch lg tv. Soundbar works fine on all channels, with the exception of all the HD ones. My tv is connected to a Humax satellite box. Any ideas please.
Maybe the HD channels do not support showing the sound bar via a satellite box connection. Call the manufacturer of the box and inquire with them.
Nov 20, 2014 | LG Televison & Video
Optical out not working with LG sound bar
got same problem the LG sound plate works with bluetoth mode but don't not detect the pioneer tv set..
May 08, 2014 | Pioneer PDP-4270HD 42 in. Plasma...
Sound bar compatibility
Make sure red glow is coming from TV's Opt out cable when TV is on. If it is, it is working. The best solution is use an LG soundbar with an LG TV. There is a differnce in digital outputs and with a "service remote" (used by authorized LG servicers) you might be able to change the TVs factory setting to make the vizio soundbar work. but I think you'll be better off with the LG soundbar.
Feb 18, 2014 | LG 47LH55 47 in. LCD HDTV
How to pair my soundbar and wireless lg soundbar
Press and hold the reset button on the back of the subwoofer until the light on the front starts blinking. Then with the soundbar turned on, press the stop button on the soundbar and the mute button on the remote at the same time. The display should say "REMATE". The sub light should stop blinking then and should be linked.
Feb 03, 2013 | LG Lsb316 Sound Bar With Wireless...
LG Nb3520a 2.1-channel Powered Soundbar With Power Logo
Computer Repairing
Computer Repairing
