Question about GE Monogram ZDI15C Automatic Icemaker
I have a G E Monogram zdis15 under counter ice maker How long should it be befor it starts making ice
SOURCE: ge monogram zd115c automatic icemaker not making ice
Have you checked to assure the long narrow hose that comes from the upper lback left corner is attached both on top and inside the water tray? This drove me nuts for 3 hours.
Dan
Posted on Jul 29, 2008
peyton32034
  • 410 Answers
SOURCE: My GE Monogram Ice Maker keeping turning its self
the rate the light flashes is a code for trouble shooting the electronics on the unit ( such as bad coil sensor, bad bin sensor or shorted grid cutter) if you will look behind the front grille you should find a tech sheet that will tell you what the flasing means and tell you what components to replace. BTW the most common failure is the cutter grid and bin sensor. the sensor is the white rod on the right hand wall inside the unit. besure it is plugged in. Let me know if I can help you futher. thanks Peyton
Posted on Mar 21, 2009
Sea Breeze
  • 4654 Answers
SOURCE: GE Monogram Ice Maker ZDI15 makes an ice sheet but does not drop or melt the sheet into cubes.
Below is a couple og links. One is for the user manual and the other is for parts should. Sounds to me the cutting grid is not getting hot and cutting the ice into cubes. PDF below, click link
http://imgs.ebuild.com/xCat/ebuildWebB/15?ObjectID=1105&Variant=Original
For parts or free answers go to this link and enter your model number into the search feature. Model ZD115C That will take you to a page with pictures and part numbers. The home page you may call or email for answeres. I did see a control board and for some reason the cutter is not heating this will cause the problem. Thanks, Sea Breeze
http://servicepartstec.blogspot.com/
Posted on Apr 27, 2009
bobicehouse
  • 1524 Answers
SOURCE: GE Monogram Ice Maker ZDIS15...ran a clean cycle,
Turn it back to clean and see if the water pumps.
Posted on May 04, 2009
SOURCE: GE Monogram Ice Maker makes ice, unit doesn't cool enough
This model Icemaker makes ice by flowing water across a freeze plate. It is located in the top of the unit behind the white cover directly below the ON/OFF/CLEAN switches. After freezing a sheet of ice it releases and slides to the cutting grid. It then drops into the ice bin and begins to melt and the whole process starts over again. The level of ice in the bin is controlled by the high level sensor on the right side of the ice bin. It is a whit tube with two wires coming out of the top. Without this sensor it can overrun the bin capacity. Bottom line this unit does not freeze ice, it only holds it like cooler does.
Posted on Jun 04, 2009
Zdis15
check hot gas valve to make sure it is not bypassing when in freeze mode this will not let the evaporator plate get cold enough. need to check refrigerant pressers.
Jun 07, 2013 | Kitchen Appliances - Others
My ge monogram ice maker randomly goes into cleaning mode
Your ice maker is electronic and the electronic board inside has failed. Not much you can do in this case except replace the ice maker. Your Monogram uses a=> WR30X10093 Ice Maker Assembly
and here=> WR30X10093 Ice Maker Assembly I will be here should you have questions, Thanks Sea Breeze
Here is a Ice Maker Service Manual that may help should we have missed something=> HERE
Feb 28, 2013 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZDIS15 has ice (sometimes) getting stuck on freezing plate. It gets hot & tries to release, but only partially (sometimes works fine). I have cleaned with solution, run the cleaning cycle...
It is time to run a ice machine cleaner through the unit, instruction should be on the door. When you get a build up is causes your ice to bind to the evaporator plate and cause this problem. Most ice machines require cleaning every 6 month to prevent this. Use nickel safe cleaner only, and most of the time this will correct the ice binding on that evaporator plate.
I hope this helps
Aug 11, 2011 | GE Monogram ZDI15C Automatic Icemaker
GE MONOGRAM ZFS826DRC SS ice maker not working
Push the white paddle in three times slowly within 15 seconds. Then wait 2 minutes. You should see the ice maker start to cycle. If the ice maker doesn't cycle, replace the ice maker. If you need a new ice maker, you can go to the link below
Order Ice Maker
Refrigerator Parts
Mar 06, 2011 | GE Monogram ZISS480DRSS Stainless Steel
My water dispenser and water to ice maker isn't working. any suggestions?
my monogram ice maker wont make ice. it is on, the water fills the pan but thats as far as it gets. the area is cold. the hoses appear open. i have cleaned the dust of the compresser. what else can i do before i call the repair man?
Jun 15, 2010 | GE Monogram ZISx420DR 42-inch Side by Side...
Ge monogram bottom freezer ice maker spills ice
It takes weeks for ice to dissipate in a freezer.
You may can adjust your cut off lights or wire cut off to cut off before it's so full.
Jul 01, 2009 | GE Monogram ZICS360NRRH C... Bottom...
GHE monogram ice maker.
pull the icemaker out, say be one inch, shack it a bit, and jam it back in. We've done that each time we had that problem, before it started to work. The icemaker is designed poorly, my openion, and gets jammed easily each time you use the crushed ice. crushed ice jams the ice crusher, and cloggs the pathway resulting a no ice dispensing situation. Also try using only whole ice cubes, instead of the crushed ice. the less you use the crusher the less you'll have to problem. one last thing. if the ice is sitting in the basket for a while, due to poor ice despensor opening door design, the ice in the basket cloggs together causing the probelm.
May 19, 2008 | GE Monogram ZISS480DRSS Stainless Steel
GE Monogram ZDI15C Automatic Icemaker Logo
59 people viewed this question
Top GE Kitchen Appliances - Others Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Sal DeAngelo
Are you a GE Kitchen Appliances - Other Expert? Answer questions, earn points and help others
