Question about Kitchen Ranges
Whirlpool extractor fan (AKR 651 IX) making a noise
My Whirlpool extractor fan (AKR 651 IX) in the hood above the cooker is making an unusual noise. It sounds like the fan is running at very high speed and makes a high pitched noise. The hood is just over 2 years old.
Any ideas on a simple fix or who is best to call on for a repair?
Thanks!
bigg t
  • 640 Answers
SOURCE: Dishwasher Making Loud High Pitched Noise.
How deep do you want to get into this?It sounds like the wash pump motor bearings that are worn.You can pull the unit out flip it over and wd40 the bearings in the motor or you can replace the bearings.Try to lube them first.
Posted on Feb 24, 2008
aborcass
  • 2651 Answers
debris caught iside pump assy is what it sounds like
  • 351 Answers
SOURCE: High Pitched Noise
try washing on hottest cycle it may be the seal in the spray pump somethimes the rinse aid can put a glaze on the seal if that doesnt work you can replace just the front part of the motor( in australia) dont know where you are.
Posted on Mar 09, 2008
shaggyrat
  • 1224 Answers
SOURCE: INDESIT HI161IX - positioning above the cooker
if its hidden hood that pops up it just has to be flush with counter
this is so you have a clean flat service that make it look like you have extra room
if its a regular hood like old days height should be between 2 to 5 feet from stove to hood for quality air flow easy to install
Posted on Jun 01, 2008
SOURCE: Kitchen extractor fan
hi! most of the time this will be sticky switch normally located on the inside edge of the extactor unit behind the filter mesh!.hope his helps
Posted on Dec 20, 2008
Have a Neff D9610 cooker hood. Has 3 separate speed switches. Slowest speed switch does not work other ok. No noise from motor when slow switch on. Is the problem with the switch or the motor?
When on high speed the motor is running at it's normal speed.
When a slower speed is selected (mostly) there is external circuitry to reduce the current to the motor so it runs at a slower speed, though in some cases the motor could be specially wound for multiple speeds. The latter way is unlikely to be found in a cooker hood or extractor fan or other small appliance.
The fault with your appliance could be the switch or the current reducing circitry. It is only by delving inside and testing that the fault could be found.
Oct 02, 2016 | Cars & Trucks
Where are the fuses in a Victoriana Deluxe Leisure cooker? The extractor fan and light have stopped working
It would be fused to the house current most likely through a circuit breaker on your service box.
Jul 19, 2016 | Kitchen Ranges
Lights have stopped working on my whirlpool extractor hood at the same time. Bulbs are ok and fan works. Model AKR 906. Please help.
first check the lamps in another device since it some times shows its ok bur actually it is not.then look for false connections and at last the holders if the lamps went out one by one.if all together then it must be the switch.
Nov 28, 2012 | Kitchen Ranges
Dww061350b
if both fan and light have quit working then you have an electrical supply problem. start with checking for thrown breakers in the breaker panel. if none are tripped then you have a broken wire or a wire no longer making a good connection. try twisting the wire nuts tighter were it wires in above it
Jun 02, 2012 | Kuppersbusch Kitchen Ranges
Hygena APP2500 cooker extractor hood?the lights on the hood work but the extractor itself does not work, is this likely to be the motor that needs replacing or the switch unit ? Plz advice
if u have a meter u can check the switch and the motor,By putting it on the continuity mode and check to see if u have a bad motor or switch
Apr 02, 2011 | Dryers
Elica oven hood fan not working
fan & light on elica extractor fan not working over cooker
Feb 25, 2009 | Kitchen Ranges
Jun 01, 2008 | Kitchen Ranges
Fan and light not working where is fuse box?
Hi - I have a neff extractor fan and have the same problem. The light and fan have both stopped working. Does anybody know where I can find the fuse as I suspect that this may be the problem too?
Dec 07, 2007 | Whirlpool GZ7730XGS Stainless Steel...
Kitchen Ranges Logo
673 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
