Question about ClosetMaid Joiner Plate Set Joins 2 Wire Shelves Together
Need OLD Closetmaid joiner plate #1172-00 - ClosetMaid Joiner Plate Set Joins 2 Wire Shelves Together
How can we take it apart after we drained the pool?
Question:
How do I properly remove my above ground pool?
Answer: by Osko Pool n Spa Onground Pool Removal Guide
Recently, a reader of one of my other articles asked the question;
" How do you take down an above ground swimming pool to move it? I can't seem to find anything to help me. I read your article on replacing a liner but I need to know how to move the entire pool".
Well, (I thought to my self), this is a very good question. So, here is a basic step-by-step guide on the basic proceedure: ( You'll need at least three people, to help with your wall).
1) Drain all water out of pool using a sump pump.
2) Remove skimmers, returns, lights etc.
3) Remove old liner, (use a razor knife and cut into manageable folded pieces). You'll need a new liner if your going to reinstall the pool.
4) Remove Top Seat Ledge covers
5) Remove Top Seat Ledges.
6) Remove Top Rail and Joiner Plates.
7) Locate Wall Bolt Joint on the Pool Wall and remove the corresponding Upright.
8) Now, get some help and remove all Wall Bolts and associated hardware.
9) Next, start pulling the wall out of the bottom rail (track). And roll the wall up as you remove it from the bottom rail. When finished, duct tape the wall so it does not unroll.
10) Pull the uprights, bottom rail and bottom rail joiner plates out of the ground in sections.
11) Remove uprights from bottom joiner plates.
12) Make sure to separate all components and save all hardware!
That's it!
Hope this helps!
Apr 09, 2016 | Intex 32 x 16 x 52" Ultra Frame...
Where do i find parts for 1983 joiner ?
Biscuit/plate joiner? Or jointer? What make? What model? What parts? Check first with the manufacturer, then check with eBay. Depending upon the part, some may need to be custom made. Things like bearings, pulleys, motors, belts, knives, bolts, screws, nuts... they're all readily available as generic parts. Not so many parts are specific to a machine - mostly the castings, which are the hardest to find for an older machine. Sometimes a broken casting can be rescued by a VERY talented welder, but it has to be done VERY specially and VERY carefully or it'll warp and may crack.
Jun 16, 2014 | Grizzly Crafts & Hobbies
Manual for Ryobi biscuit joiner JM80
They call it a "plate joiner".
Go to
http://manuals.ryobitools.com/system/files/5567/original/jm80_239_eng.pdf?2011
Sep 01, 2010 | Ryobi Thickness Planer Blades
Need to buy a dean deep fryer cover plate and joiner
cheaper to get them made by local sheet metal shop
Apr 12, 2010 | Frymaster Dean 2424G Deep Fryer
Need an instruction manual for a Model 557 Porter Cable Plate Joiner
Owners manual is here. Exploded diagram is here.
I would like to note the manufacturers site lists 557 Types 1-4. Not sure what the difference between them is, but if you need the link, it's here on page 4 of 5.
If this answer helped, please vote. Thanks!
Apr 10, 2010 | Porter Cable - Cable 557 Factory -...
Is there a 2" blade available for the DeWalt Biscuit Joiner
Because of standardized sizes of biscuits, the only blade you can and should use, is the same size that comes with the tool. Anything smaller will not create the right diameter groove for the biscuits to fit properly.
Feb 16, 2010 | Black & Decker DW682K Dewalt Plate Joiner
Blade change problem for Porter Cable 557 plate joiner
Putting it in the freezer for a couple of hours may loosen the screw by contraction and or you will have to use an impact wrench unless it is completely stripped , then you will have to drill it out.
Apr 08, 2009 | Porter Cable - Cable 557 Factory -...
Looking for the manual for use for a Skil biscuit joiner. Can I find one online to print off? Chris oldlincolnian@wwdb.org
Here is a link to the owner's manuals page at Skil.: Skil OM
Unfortunately, you haven't listed the model number, and skil manufactured several biscuit joiners or plate joiners over the years. If the manual you're looking for isn't available to download online, there's a phone number listed on that link or you can email Skil to acquire older manuals.
I hope this leads you to the solution to your problem. Thanks for consulting the folks at FixYa!
Mar 26, 2009 | Saws
Missing info.
go to sears.com and order the manual u need.
Mar 03, 2009 | Dmm 10 Plate Joining Biscuits
ClosetMaid Joiner Plate Set Joins 2 Wire Shelves Together Logo
118 people viewed this question
Top ClosetMaid Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a ClosetMaid Furniture Expert? Answer questions, earn points and help others
