Question about HP laserjet Cp2025dn color Card Printer
Event code 13.0000 - HP laserjet Cp2025dn color Card Printer
Error code 1000008e, c0000005, 8a4f726e, a3a5da34, 00000000
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem
Dec 20, 2012 | HP Compaq dx2400 Microtower - KR601UTABA ...
What is error code 104
if you need more help with this post a reply with the error message details
hope it helps
Nov 08, 2012 | Computers & Internet
How can I channge event log if I can't enter set up with F2
if you want to get the event log and the error code
click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have
hope this helps
Jun 29, 2012 | Computers & Internet
How to get oak's letter
Use either Action Replay or a Wifi Event. The Event, however, has already passed. An event is an actual event and place such as a convention. You can purchase an AR generally anywhere for about $20, though they do go " *boom* " fast. If you already have one, neoseekers.com and codejunkies.com are great sites for codes.
Nov 28, 2010 | Nintendo Pokemon Diamond for DS
Problem Event Name: PnPDeviceProblemCode Architecture: x86 Hardware Id: PCIVEN_8086&DEV_2A42&SUBSYS_01761025&REV_07 Setup class GUID: {4d36e968-e325-11ce-bfc1-08002be10318} PnP problem...
Problem signature:
Architecture: x86
Hardware Id: USB\VID_0421&PID_0355&REV_0490
Setup class GUID: {4f919108-4adf-11d5-882d-00b0d02fe381}
PnP problem code: 00000027
Driver name: ccdcmb.sys
Driver version: 7.1.32.68
Driver date: 05-18-2011
OS Version: 6.0.6001.2.1.0.256.0
Locale ID: 1033
Oct 02, 2009 | Acer Computers & Internet
Accept x and y from user and calculate x raise to y
here is the solution;
solution 1 (need 3 text boxes, Namely text1, text2 & text3 & a command button. Put the code below in the button click event) Dim x, y As Integer x = Text1 y = Text2 Text3 = x ^ y
solution 2 (put the code either in form load event or button click event)
Dim X, Y As Integer X = InputBox("Enter X", "X ? ") Y = InputBox("Enter Y", "Y ? ") MsgBox "X^Y = " & X ^ Y
May 18, 2009 | Polar Electro Wearlink Coded Watch
Windows event log service wont start, error code 5
Your right its not a virus, and its not because your running one of the top anti- virus software,the problem is else where.
Have you checked the log files to see if you have permission?????
Have you checked event viewer to see if you have permission????
I need to know or the fix I have for you will not work.
Mar 13, 2009 | Dell Inspiron 530 Desktop Computer
How to block ctrl+c and ctrl+v in opera:java code
function noCTRL(e)
var code = (document.all) ? event.keyCode:e.which;
var ctrl = (document.all) ? event.ctrlKey:e.modifiers & Event.CONTROL_MASK;
var msg = "Sorry, this functionality is disabled.";
if (document.all)
if (ctrl && code==86) //CTRL+V
alert(msg);
window.event.returnValue = false;
else if (ctrl && code==67) //CTRL+C (Copy)
alert(msg);
else {
if (ctrl==2) //CTRL key
alert(msg);
return false;
Feb 06, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Computer will not start
When Windows crashes with blue screen, it writes a system event 1001 or 1003 and a minidump to the folder \windows\minidump. Check system event 1001 and 1003 and it has the content of the blue screen
Event ID: 1001
Source: Save Dump
Description:
The computer has rebooted from a bugcheck.The bugcheck was : 0xc000000a (0xe1270188, 0x00000002, 0x00000000, 0x804032100).
Microsoft Windows..... A dump was saved in: .......
Event Source: System Error
Event Category: (102)
Event ID: 1003
Description:
Error code 1000007f, parameter1 0000000d, parameter2 00000000, parameter3 00000000, parameter4 00000000
Control Panel -> Adminstrative Tools -> Event Viewer -> System -> Event 1001/1003. Copy the content and paste it back here
Aug 17, 2008 | HP Compaq Presario SR1230NX (PJ518AA) PC...
HP laserjet Cp2025dn color Card Printer Logo
80 people viewed this question
Seeker5211
Seeker5211
