Question about Ridgid 3 1/2" Round Head Framing Nailer
How do I unjam my ridgid nail gun
Serial number for my ridgid nail gun is awo92004592. I have a nail jammed how do I get it out?
2 Suggested Answers
  • 30 Answers
SOURCE: ridgid coilnail gun jams and safty jams in place and gun will not fire. also somtimes will jam
I keep saying this yet it is a good answer sometimes. Tar from shingles get up into the striking portion of a coil gun. Keep a carb cleaner spray near you and clean it up. Also! Make darn sure you are properly oiling the intake nipple of the air gun to properly oil the guns guts themselves. Very Important!
Posted on Jan 10, 2015
My Pro 8000 stapler has about 20 staples jamed I need to how to unjam thew booklet does not show this
Clearing the Nail and
Staple Chamber
If, while using your Cobra
staple
and nail gun, it becomes necessary to
clear a jam from the staple chamber or
track, follow these instructions:
With the bottom of the gun
facing away from your face and
body, open the staple chamber by
squeezing and pulling the plastic
track release straight down away
from the base of the gun and
sliding the track back.(Fig 1)
(Note: the jammed staple or nail
may cause the track to be harder
to slide out than usual. Once the
staple or nail has been cleared,
the track will resume its normal,
free operation) Loose staples or
nails will be expelled from the
chamber.
Clear any remaining staples or
nails from the track and chamber
area.
Reload the Cobra staple and nail
gun and continue using.
May 17, 2017 | Staples Tools & Hardware - Others
Ridgid r350rhd-round head framing nailer the nail is jammed in backwards behind the push rod. don't ask me how it is backwards
FYI The fact that you've managed to flip a nail in the nose can suggest a nail that's too short. Rule of thumb is that framing tools use from 50mm (2") up.
Sep 20, 2013 | Ridgid Full Round Head Framing Nailer...
Ridgid coilnail gun jams and safty jams in place and gun will not fire. also somtimes will jam
if safety is jamming, its either bent or the pin that keeps it in place is missing/broken, you can find the pin right in front of the trigger. now as far as the nails jamming could be a few things. 1. wrong nails 2.right nail but may have gotten a defective batch 3. bucket that holds nails is adjusted to wrong size. 4.nails have been dropped/ squished and coil is not round anymore 5. nose is very worn and two nails are trying to come out at a time 6. driver is worn/broken and is trying to push out two nails at one time
Sep 18, 2012 | Ridgid Air Tools & Compressors
My ridgid r213bna nail gun won't fire a nail, but has good pressure & no jam...
If a gun is firing and nails are not being driven into the work it's because of one of two problems. The nails aren't feeding fully under the driver or the driver isn't fully retracting each time the gun is activated. Is looks like you've eliminated a feed problem so you are going to have to take the gun apart to find out why air is not being held in the bottom of the head long enough to push the driver back up the cylinder. Go to www.ereplacementparts.com and bring up your model so you can follow along. Remove the four screws holding the head cap on. The things that can cause your problem are: the piston seal & o-rnig are damaged, the cylinder is badly scored, the o-ring & cylinder ring on the bottom half ot the cylinder are damaged or out of place, or the driver guide under the bumper is broke or missing. If it turns out internal parts are damaged or missing, I highly recommend the overhaul kit to replace all the 'soft' parts inside the gun as long as you have it apart.
Jul 22, 2012 | Nailers Ridgid Finish Brad Nailer R213bna...
MY RIDGID ROOFING GUN will not feed the nails and then jams up because it trys to shoot two nails how can i fix it?
I would look at the deeder area which is close to the plunger. If not properly oiled, it will jam up like this. See the link below and enter the model number (R175RND) to get the complete parts breakdown diagram. That should help you to open up the unit and check it out. Also examine any O-rings for signs of wear.
Dan
Link: http://www.ereplacementparts.com/ridgid-parts-c-7929.html?gclid=CJLzi4D70aMCFQo65QodJDG7wQ
Aug 23, 2010 | Ridgid ZRR175RND FactoryReconditioned 134"...
Arrow T50P gun jammed - how do you unjam it?
Buu a different brand or model this one is junk and should be taken off the shelf
Feb 06, 2010 | Arrow T50P ARROW STAPLE GUN
Bostitch nail gun number SB-21n1 is jammed and need manual to know how to unjam it or a solution online. Was using it in the staple mode and it jammed after about 5 staples. Was using bostitch staples.
Hello. Begin by disconnecting the air hose. That way you can not get hurt while removing the jam. Get a pair of needle nosed pliers and remove each of the jammed staples. They will pull out I assure you. Then Use a little WD-40 or compressor oil to lubricate the working mechanism at the firing head. IF you must loosen up the mechanism to remove all of the staple parts be sure to use the correct size allen wrench. I am providing link to a free manual for your gun in case you don't have one: http://bostitch.com/catalog_images/web_pdf/107674.pdf
Jan 12, 2010 | Stanley Bostitch 18 Gauge Brad Nailer 1 -...
I have a craftsman nailer full head framing gun. There is a jam of 2 nails in the cylinder. How do you unjam the gun
On that nailer, you have to remove the nail Magazine. And then clear jam thru the sloted open side. And then put the Magazine back on. Usually one big bolt on each side of the nose and 1 or 2 bolts on the rear body.
Aug 25, 2009 | Air Tools & Compressors
PowerShot staple gun model 5700m is jammed
There is a silver screw near the back bottom (where you load staples) and you must unscrew it. Completely remove the small bolt and the silver base will pop right out. This base is the track where the loaded staples sit while in the chamber. Just remove the jam and re-install in the reverse order. Works like a charm now.
Jul 01, 2009 | Powershot Tool Company PowerShot 5700KB...
Ridgid 3 1/2" Round Head Framing Nailer Logo
53 people viewed this question
Top Ridgid Tools & Hardware - Others Experts
rickb63
Jerry Kramer
Jerry Kramer
Are you a Ridgid Tool and Hardware - Other Expert? Answer questions, earn points and help others
