Question about Okidata Multipurpose Feeder For All Ol400E/600E Series 810E PC Desktop
Just changed the toner and there are 3 lines going across pages
My pages are printing with 3 lines across the page.
  • rosejacobs Mar 11, 2009
    Sir Bob
    I have an old Okidata OL 400e laser printer. Probably more than 10 years old. The three line are spaced about 3 inches apart and go across the page.
    Thanks for any help you can provide.
  • Serbob May 11, 2010
    What kind of printer and how old?
    Sniper:
  • 60 Answers
You need to purchase a new drum kit. I'm surprised that after 10 years you haven't already had to replace it. It may be cheaper to buy a new printer.
Posted on Mar 12, 2009
Why do I have yellow horizonal lines on printed page
Sounds like a faulty toner cartridge. Are all the cartridges OEM?
Jun 16, 2017 | Brother Hl3070cw Hl-3070cw Color Laser...
I'm getting a line that isn't printing through my printing from a Fuji Xerox DocuPrint C3055 DX
Possible reasons are: 1.empty toner cartridge, 2.dirt under one of the toner cartridge's developing roller, 3. dirt on the primary charge roller in the drum cartridge, 4. obstacle on the laser path.
Replace the empty toners first and try printing again. Follow the next steps if it didn't solve the problem.
Print a test page with 4 stripes across the page - black, cyan, yellow and magenta. See if all have the missing toner line or only one of them. If the white stripe is going trough only one color, inspect the cartridge with that color. It has to have the same stripe on the developing roller. See if there is some dust beneath it that makes the stripe and clean it with a brush. If the stripe is across all colors, then inspect the drum unit. The drum itself has to be evenly shining on the light. If there are uneven matte tracks on it, consider replacing. There should be a gap somewhere for the laser beam to pass and the drum is visible trough it. Look trough it for obstacles like piece of paper or hair. The primary charge roller has to be close to that gap inside, touching the drum. Look for dirt on it. Clean if possible.
Toner cartridges last approx. 6500 pages. The drum cartridge lasts between 14 000 and 28 000 pages depending on the color use.
Jul 02, 2014 | Digital Products Office Equipment &...
Black lines
Replace the toner cartridge :-)
Apr 05, 2014 | HP LaserJet 1020 Printer
Why is there black line printed across the page in 3 different areas when something is printed. I changed the toner catridge.
This is nearly always the fault of the toner cartridge. The previous cartridge may have left toner on the transfer roller and this may have contaminated the new toner cartridge. Take the toner cartridge out and inside the printer under where the toner cartridge goes you will see a felt roller that goes across the printer and has a gear at one end. Wipe this roller with a dry clean lint free cloth, rotating it to make sure it is completly clean.
Check the blue coloured drum on the toner cartridge to see if there is a black line going across it. If so clean it with the same dry clean cloth.
If this does not work then I suggest you buy a genuine toner cartridge and try that.
Jun 10, 2011 | Samsung ML-2510 Laser Printer
Rainbow line across the middle of the page
Possible print alignment issue.
Check the toner and then go to properties of printer.
Clean heads etc and then print test page.
Wizard should assist to troubleshoot
Jul 13, 2009 | Samsung CLP-510 Laser Printer
Horizontal black lines across page.
Horizontal lines usually indicate a toner cartridge that is not cleaning properly.
A. If the distance between defects is 38 mm (1.5 inches), 47 mm (1.85 inches), or 94 mm (3.7 inches), the print cartridge might need to be replaced.
B. Clean the printer.
1. Clean the inside of the printer and run a cleaning page to clean the fuser.
Over time, particles of toner and paper accumulate inside the printer. This can cause print-quality problems during printing. Cleaning the printer eliminates or reduces these problems.
To clean the inside of the printer
1. Turn the printer off and unplug the power cord.
2. Open the top cover.
3. Remove the print cartridge.
4. With a dry, lint-free cloth, wipe any residue from the paper path area and the print cartridge
cavity.
5. Reinstall the print cartridge and close the top cover.
6. Plug in the power cable and turn the printer on.
Cleaning the fuser:
Run the printer cleaning page to keep the fuser free of toner and paper particles that can sometimes accumulate. Accumulation of toner and particles can cause specks to appear on the front or back side of your print jobs. To ensure optimum print quality, HP recommends that you use the cleaning page every time that you
replace the print cartridge or on an automatic interval that you can set up. The cleaning procedure takes about 2.5 minutes to complete. A CLEANING message appears on the printer control panel display while the cleaning is taking place.
To run the cleaning page:
In order for the cleaning page to work correctly, print the page on copier-grade paper (not bond, heavy, or rough paper).
1. If your printer model includes a duplexer, open the rear output bin.
2. Press Menu to open the menus.
3. Use (Up button) or (Down button) to scroll to CONFIGURE DEVICE, and then press (Select button).
4. Use (Up button) or (Down button) to scroll to PRINT QUALITY, and then press (Select button).
5. Use (Up button) or (Down button) to scroll to CREATE CLEANING PAGE, and then press (Select button).
6. Follow the instructions on the cleaning page to complete the cleaning process.
7. If your printer model includes a duplexer, close the rear output bin.
If this helps resolve the problem, please post a reply. Binary Bob
Sep 11, 2008 | HP LaserJet 2420 Printer
Unwanted Horizontal lines across the printed page
Problem is either Laser, Toner cartridge or transfer roller.
Feb 15, 2008 | HP LaserJet 4000 Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Colour lines across the page
Hey Paul, Can you post a scan of the printed paper? It may help diagnose your problem. The most common cause of lines accross the page is either the PhotoConductor Unit or the 2ND BTR Assy.
Nov 30, 2006 | Epson Aculaser C1100 Printer
Okidata Multipurpose Feeder For All Ol400E/600E Series 810E PC Desktop Logo
67 people viewed this question
Top OKI Computers & Internet Experts
Richard Ames
Level 1 Expert
Stan Skaggs
Stan Skaggs
Brett Duxbury
Brett Duxbury
Are you an OKI Computer and Internet Expert? Answer questions, earn points and help others
