Samsung X418 NP-X418 X420 NP-X420 white US layout keyboard Logo
A
Anonymous Posted on Apr 19, 2013
Np-x420 cmos battery
Where is cmos battery
Bios error 8302
Hi, there could be a number of reason for this ..
1. Hardware problem
2. BIOS setting has changed, entering the bios can sort this.
3. Real time clock battery voltage has dropped too low therefore contents of BIOS not held when turned off, this can be sorted by replacing the CMOS battery
http://www.computerhope.com/issues/ch000239.htm
Please keep me updated.
Regards
tip
Sony np-f330 battery...
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as udtek.com, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on Oct 19, 2010 • Computers & Internet
tip
Notebook Samsung X120 , X420 , X520 presented at IFA Berlin
Samsung has introduced its new notebook(A1185) at the IFA 2009 in Berlin, the latter the most important event in the world for consumer electronics industry . The names of the new Samsung notebooks(Sony VGP-BPS8A) belonging to the series X, X120 , X420 and X520 . All computers are able to guarantee a good time ( about nine hours) and good portability.
samsung_x120.jpg From the images collected by the presentation computers feature a beautifully designed and elegant, with the finishing touches. The colors are white pearl , black pearl and titanium . All three new models are based on Intel CULV .
The new series of notebook(Pavilion DV2000 battery) Samsung ranks among the lightest . The Samsung X120 is a 11.6- inch laptop weighs 1.3 kg , the X420 has a 14 inch display and weighs 1.8 kg , while the X520 is a 15.6 inches and weighs 2kg . The display line X are 16:9 .
Regarding connectivity, the Samsung X have nothing to envy of the competition. They are equipped with HDMI ports , wireless, webcam , Bluetooth , 3 USB ports.
The price of Samsung X120 , X420 , X520 , respectively, is 599 euros , 649 euros , 689 euros and will be available on the Italian market by the end of October .
Dell Inspiron 1521 battery Dell Inspiron 1100 battery
Toshiba PA3534U-1BRS battery
on Aug 17, 2010 • Computers & Internet
Reset bios password on samsung NP 550
Remove the CMOS battery from your laptop and leave out for a few minutes,then reinstall. This should clear the BIOS
The CMOS battery is the battery that usually looks like its the size of a quarter or a large watch battery
tip
Sony NP-BG1 battery|Cheap NP-BG1 digital camera batteries
New,1100mAh, 3.60V, Li-ion, Sony Battery Pack
  • Chemistry : Li-ion
  • Voltage : 3.60V
  • Capacity : 1100mAh
  • Dimension : 41.90 x 35.40 x 8.10 mm
  • Color : Black
  • Brand : Sony Digital Camcera Battery
Replacement SONY NP-BG1 Digital Camera Batteries, Li-ion SONY NP-BG1 Battery Pack
on Jul 20, 2010 • Cameras
I need to replace the CMOS battery on the notebook.. The time and date resets every time turn off the computer I can not find the CMOS battery-Do you have any idea where it is physically located The...
try under the front panel which just pulls off you are looking for a silver round watch type battery about the size of a two pence piece or they sometimes coat theem in plastic blue or black with a red and black wire coming out of it.
2helpful
2answers
My iron won't turn on and if it does turn on it will shut off within seconds. Can you help with this issue? Black and Decker x420
Here is a tip that will help you to troubleshoot your iron and figure out what is wrong with it.
Electric Iron not Heating Up or not Working Right
http://www.fixya.com/support/r5300202-electric_iron_not_heating_up_or_not
heatman101
Battery NP-FM30
If you want to buy locally , here a list of the biggest Sony authorized resellers near Harrisburg,
In Harrisburg try:
Camera Repair Japan Co-
(770) 849-0555
View
One of the biggest ones is the one below in Lancaster.
Perfect Image Service Center Inc. 1862 Lincoln Hwy East, Lancaster - (717) 397-3019 Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If you want to buy online try one of the following sellers:
Sony InfoLithium M Battery NP-FM30, NP-FM50 ... $25.99 –
SONY Camcorder Battery NP-FM30 NP-FM50 NP-FM51$23.00
Top Samsung Computers & Internet Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Jean Thiebaux
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
