Question about Eureka Filteraire CV1601 Central Vacuum Bag
Need relay board dor eureka cv1601 - Eureka Filteraire CV1601 Central Vacuum Bag
Replacement Parts
Sorry we do not have parts here or parts books,.
Jul 06, 2017 | Electrolux Eureka Optima 437AZ Lightweight...
Bearing on brush is hard to turn and smells like it's burning
bearing hard to move will put strain on the belt and burn it. the bearing is easily removable pull it off, sometimes its just a good clean it will need, if will not come off tape it off. remove the muck build up and give the bearing a good soak in some wd40 or oil and wipe off and check for good movement then replace the belt. as it will snap more easy now it has been heated up.
Mar 15, 2014 | Eureka The Boss Upright Vacuum Cleaner
The piece on the bottom of the vacumn that controls rug height will not work
I had to use pliars to change the level. I only used that vac three times and I got rid of it. It cut off on me and never restarted. Sorry!!
Mar 05, 2014 | Eureka AirSpeed Bagless Upright Vacuum,...
Eureka abs AS1050 will not power on?
There is a wire in the motor housing that comes loose plug it back up and it should start
Nov 30, 2013 | Eureka AS1104A Bagless Upright Pet Vacuum...
My eureka vacuum stopped working.
Need more information. Does the motor run, does the brush turn, does it have suction?
Aug 03, 2013 | Eureka 4870 Boss SmartVac Upright Vacuum -...
How do I replace the fan motor? also, how do I get the fan off?
To remove the fan, you need to remove the front grill. Unscrew the 4 screws on the corner of the grill, then remove the grill. The fan can be removed by just pulling on the hub. The fan motor is attached to the machine by two nuts that face the back of the machine. So you need to remove the guts of the machine to unscrew the nuts.
To remove the fan motor, you need unscrew the screw that is above the AC plug, to remove the back grill, then remove the filter plate. Once that is removed, you need to remove four screws that holds the lower plate that houses the AC plug. Once that plate is unscrewed, then disconnect the power conector from the main board and then the green ground lug to free the AC plug.
You will need to remove the main board. To do that, you will need to disconnect the keypad/display connector. It the one that looks like a telephone RJ connector, its located near middle of the main board. Next, you need to unlatch the red wire that runs down from the main board to the front of the machine. Once that is undone, then the alunimum chasis that hold the main board can be slid backwards giving you access to unbolt the two nuts that hold the fan motor.
Hope this helps you.
Apr 30, 2011 | Ecoquest Fresh Air Air Purifier
I have an Aprilaire 700. Whenever the unit has been turned on, the water flow to the unit will not stop running. What part(s) do I need to replace so that the unit will properly turn the flow on and...
Hello, in order for the humidifier to turn on and off with the furnace you need either a sail switch or current sensing relay. A sail switch mounts in the return air duct and senses the return air when the furnace turns on thus turning on the humidifier and turning it off when the airflow stops. A current sensing relay works the same way but instaed of sensing airflow in senses current on the blower motors common lead and is easier to install than a sail switch. I will post a pic of both
robhvac47_24.jpgSail switch
robhvac47_25.jpg Current sensing relay
Feb 27, 2011 | Aprilaire Air Purifiers
Working on a furnace, with a booster fan tied into supply duct. fan isn't running and its rib relay is not lit
make sure u have power going to the fan if u do then the fan has got to be replaced if not ur relay may be bad make sure the power is getting to the relay
Feb 24, 2010 | Air Purifiers
Eureka Filteraire CV1601 Central Vacuum Bag Logo
Top Eureka Air Purifiers Experts
Are you an Eureka Air Purifier Expert? Answer questions, earn points and help others
