Question about Garden
Taking apart B&D GL550 strimmer
Taken all the screws out but it still won't come apart
3 Suggested Answers
SOURCE: how can i repace the
Instructions can be found at: https://www.2helpu.com/PDMSDocuments/EU/Docs//docpdf/gl550_uk.pdf.
If the line keeps getting too long, it's because swivel 14 in diagram 7 was in the wrong position when you inserted the spool - just move it to the ouside position, re-insert the spool and away you go. Frankie.
Posted on Jun 11, 2008
SOURCE: GL 720 strimmer
There is a screw under one of the black labels on the side. Think it is the one showing different length positions.
Derek
Posted on Sep 10, 2008
I have the front of my 2007 Heriage Classic taken apart, but can't take out the screws on the bottom of the forks. What size allen wrench do I need? The wrnches in my set are either too big or l
Use a long 6mm allen to remove the bolts. Tap the centers of the allen bolts with a hammer and punch to loosen them before removal. I always use a butterfly air tool to remove them. Super easy! You'll want to replace the allen bolts and copper washers when assembling the forks.
Dec 18, 2012 | Harley Davidson Motorcycles
My Kenwood A-51 amplfier won't play music when connected to speakers.
http://www.agtannenbaum.com/k_cat.htm#KENWOOD manual here..........meder's tv service
Sep 10, 2012 | Kenwood Audio Players & Recorders
So i've been using a poulan pro 4218 all summer, ran like a champ for me everyday all day. then the crankshaft holding the clutch and sprocket snapped.. not a problem bought the part and replaced it....
Sounds like a carb issue, the L screw on the carb adjust the fuel mixture from idle to half throttle, i would richen the L screw by unscrewing 1/4 turn, this should improve the running, however there is a special tool to adjust the screws, part no. 530035560, the screws are fuel, not air screws, increase a shade more if it is still not idling or accelerating properly.
Oct 30, 2011 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
When using the oven the electicity tripped; after resetting the breaker the oven does not appear to get hot; however the grill works, the light works and the fan works what could be the problem?
Sounds like the oven element has gone. When these elements go they often short against the outside casing of the element which is earthed (or should be). This trips the main trip switch in the house. Having tripped and cooled down, the element is now broken inside & won't heat up. Usually 2 screws to remove, either inside oven or outside at back. Element usually taken out thro oven. Take it & cooker info to your dealer & ask for replacement. Shouldn't cost much.
Jun 13, 2011 | New World Ovens
Please excuse my poor english. I was using a B & D Gl701 edger/trimmer when it suddenly stopped spinning. If I press the trigger I can still hear an engine sound (although it more reminds of a...
possibilites
The belt item 4 of below link has come off.
Or
The pulley that is item 3 has either seperated or it is damaged.
(Actual Black and decker website is here)
http://service.blackanddecker.co.uk/Products/DocumentsBDK.aspx?ProductID=7824&DocumentID=24548&size=3 (Enlarged view)
http://service.blackanddecker.co.uk/Products/DocumentsBDK.aspx?ProductID=7824&DocumentID=24548&size=1 (Regular view)
Or
The screw / bolt that is item 16 on page 10 of this manual has come loose:
http://service.blackanddecker.ie/PDMSDocuments/EU/Docs//docpdf/gl701%20-%20gl741%20t3-5_uk.pdf
If this item is under warranty... As much as I hate to say get it to a service center... You probably should do so. Could you fix it... yes. I think the cost of parts and your time would be equal to the shipping cost to the service center. At least if you send it off to the service center... you don't have to worry about not getting tiny piece parts re-installed correctly to reassemble the plastic body over the motor.
Thanks for choosing FixYa,
Kelly
Jun 07, 2011 | Garden
GL 720 strimmer
Derek
Aug 30, 2008 | Garden
Strimmer Case Removal
there are 2 small screw under the black plasic part. If you've taken all the "visable" screws out the molded plasic part snaps off. Also there is 1 screw under the label. Use your finger to locate the hole and just poke your screwdriver thru it label to remove it.
I hope that helps a little.........
May 22, 2008 | Black & Decker String Trimmer Cordless 12"...
How can i repace the line on a black & decker strimmer gl550
Apr 20, 2008 | Black & Decker String Trimmer Cordless 12"...
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
