Question about GeoSpring hybrid water heater - GEH50DEEDSR
FILTER ALARM LIGHT WILL NOT RESET - GeoSpring hybrid water heater - GEH50DEEDSR
How do I deleate the change filter light?
My model is the psp511lca but it may be the same type of reset. I have a dial I turn to the "change filter" option and then press the up and down temperature buttons simultaneously and hold for a few seconds. When you turn the dial back to "run" the change filter light on the display is gone.
Sep 12, 2014 | LuxPro PSP711TS Touch Screen Programmable...
Reset air psp511lca
To reset the air filter indicator:
1. Open up the control panel and turn the dial to "Air Filter"
2. Press the temperature up and down buttons simultaneously
3. Turn the dial back to "Run"
If you forget these instructions, you can find them in the owner's manual. You can download the manual here:
http://www.luxproproducts.com/pdfs/PSP511LCa_NL_ENG_Manual1.pdf
Dec 28, 2013 | LuxPro PSP711TS Touch Screen Programmable...
Flashing filter light on my lux 500e thermostat
turn the knob to filter & hit enter...should reset
Dec 17, 2013 | Lux Thermostats TX500E 5-2 Digital...
Geospring water heater keeps beeping even though filter is clean
Same thing happened to my GE Hybrid Geospring Water Heater. Luckily, I bought the extended service plan from Lowes. The problem is a leaking evaporator coil in the heat pump (top portion) of the water heater. Believe it or not, the evaporator coil may be freezing up due to low refrigerant levels, which triggers the filter alarm. GE knows all about this problem, and it is covered by the 10 year warranty FOR PARTS. Labor is not covered, even though this is a big defect. Unless you bought the extended warranty... You will need an HVAC service tech to fix this problem, preferably one who works for GE Appliance services. Last, but not least, owners need to report this to the Consumer Product Safety Commission (CPSC.GOV), as in my opinion A RECALL IS IN ORDER HERE. After all, the thought that 410A refrigerant is leaking into my home (my water heater is in our multi-purpose room) is ANYTHING BUT SAFE!
Sep 06, 2013 | GeoSpring Hybrid Water Heater
Filter light keeps beeping
GE knows there is a problem with this and will send a serviceman out with parts to fix free of charge even if you are out of warranty as I was. Just call them at 888-443-4394
Jul 07, 2013 | General Electric GE GeoSpring Hybrid Water...
How to reset filter indicator on luxpro psp511lca
RESET FILTER COUNTEROnce you have replaced your filter, the filter life counter is reset back to its fullamount remaining value by turning the dial to AIR FILTER and pressing the UPand DOWN buttons together at the same time. NOTE: The counter is also reset bychanging the filter setting value, as described above, to a different number ofdays.
Jul 17, 2012 | LuxPro PSP711TS Touch Screen Programmable...
Red alarm light on constantly and heating wont work unless over ride system
Have you tried turning one of the thermostats off.? They are both talking to the same unit and they may be arguing with each other.
May 21, 2009 | Dayton Water Heaters
GeoSpring hybrid water heater - GEH50DEEDSR Logo
435 people viewed this question
Top GE Water Heaters Experts
RSole
Gene Haynes
Steven Brandon
Steven Brandon
Are you a GE Water Heater Expert? Answer questions, earn points and help others
