Question about Maytag Atlantis MAV6000 Top Load Washer
Maytag model 6000
I have had the model 6000 for 7 years. At one point it cleaned clothes very well. Now I need to wash the clothes 2 or 3 times to get them clean. no I am not overpacking the machine. I do have dogs so there is lots of dog here on things. Does anyone have any advice what might be the problem without tossing out the unit
  • 641 Answers
Did you changed detergent's type ? Do you know if water during the process becomes hot ?
Posted on Aug 06, 2007
SOURCE:
Why is my maytag 2000 washing machine leaking from underneath when it is only 2-1/2 years old
You need to establish the area that you have seen the water pooling and trace it back if possible.Make sure you disconnect the machine from the power point before you conduct these checks. Is the water clean, dirty or oil contaminated. if you can't determine exactly where the leak is coming from try placing a chux cloth around a hose with a cable tie before a wash then check it on the completion of the cycle - make sure the chux cloth does not effect the operation of the machine.
Oct 20, 2014 | Maytag Washing Machines
My Maytag Bravo dryer adds extra minutes to cycles. If I set it for normal or bulky it will run for some time and when I check to see if it's done it still has over an hour left on it, more than the...
Your dryer has a moisture sensor, if it senses that the clothes aren't dry enough it will extend the cycle. A couple easy things to check:
1. Be sure the spin cycle on your washing machine is working properly. If the clothes are too wet when you add them to the dryer your dryer will need to add more time to get the clothes dry
2. Be sure your lint filter is cleaned after each load, and have your dryer exhaust vent cleaned- it could be clogged.
Oct 29, 2013 | Maytag Dryers
A co-worker sold me this washer: model MAV6250Aww, ser# 20480262zu; that had just sat in storage for a while. Washed clothes came out with a lot of lint- even after a repairman "cleaned" it out. Any...
These washer are notorious for linting, there is no real solution, reduce wash time to bare minimum, try sorting clothes into different categories, whites separate washed from dark clothes, use good quality detergent. The only way to fix this problem completely is a neutral drain kit, I do not believe Maytag sells one.
Oct 20, 2013 | Maytag Atlantis MAV7260B Top Load Washer
Is there any kind of recall on a Maytay front loading washer, model #MAH6500AWW? I am having problems with mildew in the rubber part and terrible smelling water in the bottom.
The cleaning process for your Maytag Neptune front-loading washer, for example, requires some time and patience. Over time, your washing machine will need to be cleaned. It can develop offensive odors through multiple wash cycles. This makes the washing machine less effective at cleaning the clothes you put into it. Maytag offers some sound advice for cleaning your front-loading washing machine.
  • Pour 2/3 cup of liquid chlorine bleach into the bleach compartment of the dispenser drawer of your Maytag Neptune front-loading washer.
  • 2
    Run your Maytag Neptune front-loading washer on the "Clean Washer" setting. Press "Start" to start the cycle.
  • 3
    Leave the door open once the cycle is complete to allow the inside of your Maytag Neptune front-loading washer to ventilate and air dry.
  • 4
    Look closely at the gray seal of the Maytag Neptune front-loading washer's door opening. This seal can have a buildup of debris or detergent residue.
  • 5
    Spray the seal with an all-purpose appliance cleaner and scrub away any debris or residue with a cloth or scrubbing pad. Dry with a clean cloth.
  • 6
    Remove the soap dispenser drawer. Press the release lever and lift it out to clean.
  • 7
    Take out the inserts and rinse them and the drawer thoroughly.
  • 8
    Wash with a mild soap and cloth to remove any residue. Dry thoroughly before replacing.
  • ALWAYS LEAVE THE DOOR OPEN WHEN NOT IN USE! This prevents the mold and mildew from forming once you get it cleaned.
    Aug 20, 2011 | Washing Machines
    Clothes not fresh as with a topload washer
    Call a servicing dealer and see if there is an update for your machine that has an extra circulation hose and port
    Jul 04, 2009 | LG WM-2277HW Front Load Washer
    Maytag Top Loader Thumps When In Spin Cycle
    My guess is that one of the three counterweights have separated from their support. Probably rusted away.
    36 years is quite a feat. Today's machines would be lucky to 1/3 of that life.
    Sounds like its time to go shopping.
    Do you have an anniversary coming up?
    Ladies love washers for an anniversary gift.
    May 24, 2009 | Maytag Atlantis MAV6451 Top Load Washer
    Moisture in dryer
    is it cold outside clean your vent run dryer with out vent on gas dryer?
    Feb 24, 2009 | Maytag LSE7806A Top Load Stacked...
    Maytag MAF1200AAW
    WASHER MAGIC is the revolutionary product specifically formulated to safely and effectively clean the family washing machine. Top loading machine use whole bottle. Front loading use 1/2 bottle. You may rub Washer Magic on with a rag to eliminate odors.
    Why Use WASHER MAGIC? Every time you wash your clothes, hard water and detergents causes lime scale and rust to build up inside the tub, pump and hoses. This build-up reduces the ability of your washing machine to perform. Mineral build-up acts as an abrasive increasing the wear on your clothes. The result: your clothes are not as clean as they could be and wear out sooner.
    If you are unhappy with the way your clothes comes out of the wash, then WASHER MAGIC may be the solution you have been looking for. Only WASHER MAGIC can restore the family washing machine to the way it performed when it was new. Use once a month for optimal washer performance and to keep control of trouble causing build-up.
    Aug 04, 2008 | Washing Machines
    Maytag front load washing machine Model MAH5500B misses spin cycle
    either balance load sensor or machine failing to drain in the allocated time, check pump/filter for blockage
    Nov 01, 2007 | Maytag Neptune MAH5500B Front Load Washer
    Maytag Atlantis MAV6000 Top Load Washer Logo
    44 people viewed this question
    Top Maytag Washing Machines Experts
    jimorris77
    Sheldon Dedek
    Bill Long
    Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
