Bizhub Copier C350 quit "printing", no error codes
V\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} b\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} 285 7772400 10058400 259 261 257 280 262 283 1 05R[$*YPZ=TJ1]@9=WC"7C` 5 1 0 286 False 0 0 -1 304800 243 True 128 77 255 3175 3175 70 True True True True True 282 134217728 1 1 -9999996.000000 -9999996.000000 8 Empty 128 10066380 13421798 13421772 13260 3368499 16777215 26 Maroon -87325200 -87325200 (`@````````` 267 263 5 My Bizhub C350 copier is all of sudden not "printing" anything on the paper. Machine acts normally when I press the copy button, but the paper comes out blank, or very nearly blank, sort of a very pale gray "fuzz", but no discernible image. If I try to send a job to the copier from my computer, I still get a blank page. (And NO, I did not try to copy any US Currency-which apparently renders the copier useless?) I am receiving no error codes, I have just replaced the yellow and cyan toner cartridges, and I did recent replaced the magenta and black carts. I have also used all 4 of the charger cleaning tools as directed in the manual.
  • Anonymous Mar 14, 2009
    If I could scan the page, you would see next to nothing at all on the page, you have to look very very close to see anything at all, I guess 'fuzz' was not the best description, It barely shows anything and when I did scan it, the page looks white. Does this make sense to you? A friend asked a copier tech friend who said that blank pages could indicate the main board is 'fried', but wouldn't such an issue trigger some sort or error msg or shut down?
    (am I replying correctly? This window wants me to check "solution" or "I have the same problem"!!)
  • sam gerban
    sam gerban May 11, 2010
    if you could scan a copy of the image you are getting that will be of good help,so i can help you,
  • 145 Answers
CAUSE: A failed PWB-MC board.
SOLUTION: Replace PWB-MC (p/n 4036-7811-01).
try and unplug the machine while its on first wait 5-min and plug back on if that won't help you will need the above board
good lock
Posted on Mar 18, 2009
Konica minolta c350 error code c-0096
If your copier models is Konica minolta Bizhub C350 reset the error code:
Turn OFF the copier.
Press and keep pressed the Utility key and turn ON.
Keep pressed the Utility key and wait will Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier,wait 1 minutes and turn ON.
If the code persist enter in the service mode,select counter,select service call condition and read the trouble code description to lacalizate the truble.
If your copier model is KonicaMinolta Dialta CF3102 or OCE CS 220 the code C0096 refer to Transfer belt separation.
Apr 09, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub C350 envelope problem
Load the envelopes in the bypass tray select paper on the copier control panel select by pass tray change tray select normal DO NOT select envelope select custom enter size, on printer preference select envelope tray and print
Apr 18, 2012 | Minolta bizhub 200 All-In-One Printer
How do you clear error code on a bizhub C350. A piece of paper was fused on the fuser unit and we were able to get the paper off. Now we have no access because the panel is locked.
while powering up machine hold down utility/counter key until trouble reset appears on screen. select it and ok should apper under it. power down machine for atleast 10 sec and turn machine back on.
Jul 22, 2011 | Konica Minolta bizhub 350 All-In-One Laser...
Hi can a Matching paper size is not available cause a printer konica bizhub c350 to be offline?
If your copier is connected to your network and you get this error, the answer is no. If you are getting the miss match error then the print job could be stuck in the que. This would cause it not to print. If you dont know how to clear the print job, restart your computer and try to print again using the correct paper size.
Mar 08, 2011 | Konica Minolta DiALTA Di183F Copier
Bizhub C350 Malfunction Code C-0510
I have this malfunction code, C-11A3, coming up on my Konica/Minolta Bizhub 350 copier/printer. Anyone know what it is? I don't use the techs, because they charge much I don't pay for the service anymore-seems like most things should be able to be fixed by the owner. I needed help for this code
Mar 21, 2009 | Konica Minolta bizhub C250 All-In-One...
Problem.
open right side door of your machine and check check all gears are working properly this code belong to main motor
Oct 26, 2008 | Office Equipment & Supplies
LCD Display displays Error C0510 Can't do anything about it.
low temperature issue. There is a trouble reset procedure that should be performed by a Minolta tek
Konica C350 questions
You can print envelopes from any software, like Microsoft Word. Just be sure to enter the proper settings at the copier as fatr as size and media weight/type.
The copier should be able to fold 3 sheets, but that depends on what model finisher you have. To fold you need to load the paper landscape, so it runs through on the 8.5 side and not the 11 like normal.
Jun 27, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
355 people viewed this question
