Question about Refrigerators
Why my ge gav070bayr refrigerator is overheating at the casing
What can I do to my kitchen aid refrigerator very hot between refrierator and freezer
Is there a fan inside, or a damper that allows freezing air to go into the fridge? The fan may be stuck and overheating.
Jun 18, 2014 | GE (PSS26MSRSS) Side by Side Refrigerator
My GE Adora Model dss25ksra refrigerator decided last night to stop working. It's a case of "the lights are on but nobody is home". The lights inside will come on when the doors open, but the compressor...
Yes it does sound like a motherboard issue=> WR55X10942 Main Control Board It is also good to replace the=> WR07X10057 Start Relay and WR62X0079 Run Capacitor and examine the condenser and evaporator fan motors to insure they are working properly if the motherboard has been replaced. I am here should you need me, Thanks John Tripp Appliance 911
Mar 27, 2014 | GE Adora DSS25KSTSS Stainless Steel Side...
The freezer shelves in my ge Dss25KGRC side-by-side refrigerator/freezer keep falling down. It seems as though the shelves shrunk and no longer fit. Could it be that the freezer walls have gotten farther...
I had the same problem with my 3 year old GE Adora side by side. Call GE at 1800-386-1215. They were very helpful! They sent me all new shelves and drawers that were obviously wider because they fit perfect(only took a couple days)! Included in the shipment were spacers that I could of put on the ends just in case I needed more width. GE knows about the issue and is dealing with it on a case by case basis.
May 21, 2010 | Refrigerators
The compressors stops working sometimes and starts working again. What is wrong?
if doing it and their is no problem with temp unit working fine ---if not working fine either overheating or low freon overheating can b resolved most of the time by cleaning [ vacuum] the coils around compressor if problem continues after above will need to be serviced for either freon or elect controls
Oct 05, 2009 | GE Profile PSW26P Stainless Steel Side by...
Ge mini fridge seems to be overheating
the unit should have heat coming off the condenser coils on the back. some of the units have a little fan motor to help cool the condenser. make sure there is plenty of space for air flow around the unit, as this is crucial to normal operation.
Aug 25, 2009 | Sanyo SR-4911M Compact Refrigerator
Freezer not staying cold and compressor not cycling and overheating
if compressor going off on overload. you could have a defective compressor relay or compressor.
relay part# WR07X10025 cost aprx. 20.00
also be careful before buying parts b/c your model comes w/ a main pc brd that gives 98% of problems on ge refrig.
Jul 16, 2009 | GE GSS20IEP Side by Side Refrigerator
My GE side by side throws a LOT of heat
It might be low on refrigerant, this is one cause of overheating on the compressor, and condenser. This condition will not affect cooling tho, unless it is really low. As far as making fire, it wont because compressors have a breaker switch that go off when they get too hot.
Jun 28, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
The gas ignitor keep ticking in off or on positions
sounds like a short. call pro help since these areas are volatile. pro serv. has warranty in case of worse case scenario. pricey, but you'll sleep at night
Mar 18, 2009 | GE Profile PSW26P Stainless Steel Side by...
REFRIGERATOR HEATS UP TO 90
gheck and see if your condenser fan working or pull the refrigerator 3/4 off the wall
Feb 23, 2009 | GE Profile PSW26P Stainless Steel Side by...
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
