Question about Philips bSure SV1 Multimedia Projector
Problem with my phillips lc 3146 projector - Philips bSure SV1 Multimedia Projector
How can I find the bulb life remaining?
1,turn on the projector
2,press and holding down "UP" for 20 seconds,
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Mar 05, 2014 | Eiki LC-XB28 XGA LCD Projector Multimedia...
Eiki LC-XB23 Projector vertical bands top to bottom of screen
almost sure 1 or more lcd panels are defective
sorry, but than it is end of life for this projector.
May 20, 2012 | Eiki LC-XB23 Projector
Projects blurry picture onto screen even after adjusting the focus. It is an EIKI Diamond Projector LC-SD10.
Did you connect signal with native resolution 800*600
blurred picture can also be caused by extreme contamination of optical parts
Aug 22, 2011 | Eiki LC-SD10 Projector Multimedia...
Eiki LC-SD10 Projector will not power on.
any led on ? if no, check thermal switch near lamp house or dried out capacitors in power supply
Aug 20, 2011 | Eiki LC-SD10 Projector Multimedia...
Need to remove bad lamp from the HC100 projector
1. Reverse the projector gently.
2. Loosen the screw (a) using a Phillips screwdriver (+), and remove the lamp cover (b).
3. Loosen the screws (c) using a Phillips screwdriver (+).
4. Pull up the handle.
5. Pull out the lamp box by the handle while holding the projector.
Pull the lamp box out of the projector slowly. If it is pulled out quickly, the lamp may break scattering
glass fragments.
Do not spill liquid on the removed lamp box or do not place it near any flammable object or where children
can reach to prevent injury or fire.
6. Load a new lamp box securely into the projector in the right orientation.
7. Put the handle back to the original position.
Make sure that the handle is locked.
8. Tighten up the screws (c) using a Phillips screwdriver (+).
9. Tighten up the screw (a) using a Phillips screwdriver (+) to secure the lamp cover.
Jul 20, 2011 | Mitsubishi HC100 DLP Projector
In reference to the Eiki LC X999 projector
I figured it out by opening the bottom. The lamp was easy to change.
Jan 29, 2010 | Eiki LC X999 Multimedia Projector
In few minutes after turn on the projector (Eiki Lc-xnb4m) , it shut off automaticlly. and i connect notebook with the projector ,no any reaction. i don't know how to operate it?
are any of the leds flashing? could be overheating. blow out the dust with canned air. if the lamp is old, it could be that it needs to be replaced. if the fans go out immediately as well, it could be the power supply.
Aug 22, 2009 | Eiki LC-XE10 Projector Multimedia...
I do not know how to use Eiki LC-300
The operation manual is at this addres (http://www.eiki.com/docs/owners-manuals/lc-300_owner-manual_2000-06-05_en_na.pdf?sfvrsn=14). It is a PDF & very easy to download. If you need any other help, write back.
Oct 14, 2008 | Eiki Projector lamp Projector Lamp for...
Bulb Life
hi,
This is 2000 Hours, 160 Watts, UHP lamp. dont keep it on always.Check the usage and then replace the lamp. It's better to turn off the projector after each class.
The lamp is around $400.00 for Eiki LC-SD15.
Viren
Rave Services India
Feb 07, 2008 | Eiki LC-SD15 SVGA LCD Projector Multimedia...
Philips bSure SV1 Multimedia Projector Logo
Top Philips Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Philips Office Equipment and Supply Expert? Answer questions, earn points and help others
