Question about Toshiba Office Equipment & Supplies
Error cd 60 - Toshiba Office Equipment & Supplies
How to fix error code 60 on a NSM City IV
error 60 =connection to cd player interupted no power voltage present for decoder board or cd player check connections of cables also check fuses philhemmings@hotmail.com
Jul 06, 2014 | Audio Players & Recorders
Why does my cd player say cd error & make cd skip
cd magazine/ player is going bad. most likely its the springs that keep it balanced while it spins the discs
May 14, 2014 | 1999 BMW 323i
I have not played my cd changer for a year and when I just try to play a cd now the system appears to look for cd but the word error comes up on the display. Just the word error not number. Any ideans...
Hi!
I dont't think that your cd-changer is broken. It may only need some cleaning. One year is time enough for dust to set on optical reader. I suggest to use a cleaning disk, available on every store selling optical media.
Hope it helped,
Bogdan
Sep 23, 2011 | Technics SL-MC70 60-Disc CD Changer
My cd changer is not recognizing the cd's that are inserted and the screen reads "error". why is that and how can I fix it?
if you have cd disk cleaner try to insert. if not work try to clean manually using cotton badge clean directly to optical lens.
Apr 20, 2010 | Technics SL-MC70 60-Disc CD Changer
Jukebox nsm2000
Error 60 is connection to the CD player interrupted.
There is no supply voltage present for the decoder board or the CD player.
Check that all of the cables to the decoder board are in good condition and connected correctly and securely.
Jun 14, 2009 | Juniper Networks IDP Upgrade Kit for ISG...
I have a 97 Buick Regal and I get a E20 error message:cd player
If the CD is over 60 minutes it will not play on domestic cars
May 29, 2009 | 1997 Buick.5 Regal
Error 70 / 60 /50
Those errors mean that there is an electrical or mechanical system fault. The pioneer website suggests to turn the car ingition off and on again, or press the power ON/OFF button on the display unit and try to play the CD again.
That seems like the obvious solution to me, which Im sure you have already done. You can try to contact Pioneer for more info.
Dec 05, 2008 | Pioneer CDX-FM687 6-Disc CD Changer
Cd player
M-Error is a mechanical error and could have a multitude of causes. just went through it with a TAD-5160 unit where it was a small slip gear moving a tin lever to ingage the transport sled to insert or eject the disk from and to the carusel. You may have to take the unit apart and asess the problem. Harleysp.
Mar 19, 2007 | Fisher 9925 Shelf System
24 people viewed this question
Top Toshiba Office Equipment & Supplies Experts
didi2005
jasbo
jasbo
Branko Djurdjevic
Branko Djurdjevic
Are you a Toshiba Office Equipment and Supply Expert? Answer questions, earn points and help others
