Question about Garden
Snowblower oil leak
Tecumseh/Ariens snoblower (OHV110 snowking engine) with oil leak, I have this 3 yr old machine and it has always seeped oil from the engine (my brother has a Husqvarna with the same engine and has the same problem. It is not the oil drain or the crankcase breather. Can you help? Thank You.
  • 2 more comments
  • ratsasleep Mar 11, 2009
    Hi, I changed the belts about 6 wks ago and front seal looked ok, but oil only accumulates when throwing snow, I will start it and observe front seal under full power. Is there another possible source for a leak of this type as I was surprised when I saw my brothers snowblower showing the exact same problem.Thank You.
  • ratsasleep Mar 12, 2009
    It becomes visable at the base of the engine due to the engine being painted black and the snowblower is painted orange-it is very visable at this junction and runs down the orange painted frame-my theory is it is seeping from where the motor case halves split but most of that is covered-pull start casing etc. while a total disassembly prob. would reveal the source it would be good to know what I am looking for to save time, money, and materials, also if this is common that may be good to know when upgrading in a year or two.
  • JERRY ABELL
    JERRY ABELL May 11, 2010
    where does the oil accumulate on the machine
  • JERRY ABELL
    hello, is the oil leaking from the front oil seal where the crankshaft comes through engine cover.
SOURCE: need diagram of how to replace snowblower belt
not sure my neighbor did it while I was on the phone.
thanks,
cindy
Posted on Jan 29, 2009
pippall
  • 1486 Answers
SOURCE: oil drain
Under cutting propller box
Posted on Jul 08, 2009
rwvanlue
  • 486 Answers
SOURCE: I have a Sears Craftsman mower with Tecumseh, major oil leak
On many Tecumseh engines, there is a crankcase breather located under the flywheel. It has a cork gasket to seal the top plate of the breather. Either the rubber breather housing is cracked, or the cork gasket needs replaced.
Posted on Nov 08, 2009
rwvanlue
  • 486 Answers
SOURCE: looking for governor linkage set up took apart
cc4d3bd.jpg hmsk linkages
Posted on Nov 22, 2009
Testimonial: "Just what I needed. Thanks"
brado83
  • 106 Answers
SOURCE: I have a tecumseh 5.5hp LH195sp-67514 engine on my snowblower
Hey mate,
First of all check all your fuel lines from your tank to your carb for cracks, with the carb it is common on these to leak past the needle and seat in the carb, I would remove the float and try clean up the needle and seat first, then if that doesnt work you should be able to purchase the needle and seat as a spare part and not have to replace the whole carb...
Most times this problem can be rectified with a quick clean up of the needle and seat as there could be some forign matter or debris under it, be sure to reset the float level/seat turn the carb upside down a check that the float is sitting level or parallell with the carb body...
Hope this helps
Brad
Posted on Feb 05, 2010
Testimonial: "Brad, Thanks brother. I will give it a try."
I have Ariens model 932039 gas snowblower with tecumsah motor engine is blown how do i find a replacement
often if you go to the store that sells those type of machines you can buy a replacement engine but you will likely pay almost the cost of the new machine itself. sometimes if you go to a repair shop they will have a separate engine for sale. If you can find it a Briggs engine should fit as well.
Feb 04, 2018 | Ariens Garden
Are there any left hand threads on the Ariens ST824 snowblower model 924050
As far as I know there is none on the Tecumseh engine. For the rest of the blower there shouldn't be any but there could always be some.
Manufactures tend avoid left hand threads as much as possible.
Feb 13, 2015 | Ariens Garden
Yardworks snow blower
Leaks are normally from bad seals or ones put on engine wrong. Many snow blowers leak oil, very common. Electric start needs to be taken apart. Rust is problem most likely. When you engage the starter it kicks out the gear to turn over engine. Carefully remove the starter from engine, try to start starter an if the pinion gear does not kick out from starter disassembly it an try to clean rust away from action. Dont break wires around electric motor careful about getting dirt an rust in winding. Try to lube spring an moving parts around gear. One other thing it could be a sheared off gear on starter also.
Mar 22, 2014 | Tecumseh Garden
My snowblower Yard Machines 26" 8HP started but
Clean the carburetor and check the intake manifold to the head for air leaks/bad gaskets.
Jan 13, 2011 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Using ariens snowblower today, model# 924026 and heard a ping and everything stopped. Tecumseh engine model3 H80 155006. Some white smoke came out and some oil leaked down side of metal part that oil is...
Check your compression tecumseh's are known for the exhaust valve seat poping out of the head. If you have compression check the governor shaft it should only turn about a 1/4 turn.
Dec 18, 2010 | Tecumseh Horizontal Tiller Engine 8 Hp, 1"...
Garden Logo
2,565 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
