Question about Acer Aspire Computers & Internet
Touchpad mouse not working
Can't get the touch pad to work
Hello did you try the special keys? Maybe someone turned it off. On mine, it is the fn key with the f1- look for a blue symbol on the F keys tthat may look like a screen with an X- I hope this helps- Have a great day/night. :)
Posted on Apr 20, 2013
SOURCE: Toshiba Satellite A85-S107 laptop touch pad L-R key not working
try using the fn and f9 to enable or disable the touchpad.
Posted on Aug 02, 2008
PABLOCSA
  • 1124 Answers
SOURCE: Touch Pad mouse not working
Connect and external mouse, then go to Toshiba website and download the touchpad driver for your laptop and reinstall them again.
Posted on Oct 10, 2008
Dr_Joseph
  • 86 Answers
SOURCE: mouse touch pad problem Lenovo Y410 model notebook
Just above my keyboard there is a little black strip with little lights.
they are control buttons and if you tap one of them it turns the touchpad off and on (so it's very easy to do accidentally).
 If you look really closely at the strip in good light (or restart the laptop to see them flash on and off) you'll see that one looks like a touchpad crossed out. Just press this to get your touchpad back.
If it doesnt solve the problem, I have noticed that the touchpad can be knocked out by a Window Update of something called ideacom. If you believe this could be the problem please clarify.
Posted on Jan 28, 2009
  • 45 Answers
SOURCE: the mouse touch pad doesn't work
Fn+F9 is the hot key for enabling or disabling the touchpad
Posted on Aug 21, 2009
parrotheadpc
  • 2600 Answers
SOURCE: acer aspire one mouse pad clicks not working stuck on right click
If you are saying the right button is down and is not coming back up, then either the plastic lip on the button is jambed against the palmrest, or the actual mechanical part of the mouse button underneath has collapsed and has become non-functional. If the right button clicks but does not do anything like bring up the selection window in windows then that may be a hardware issue related to XP, try this, go to the control panel > system > hardware > device manager> scroll down the Mice and pointing devices. Highlight the touchpad and click on uninstall. Make sure you are connected to the internet when you reboot and have your usb mouse hooked up so it is easy to work around this. When windows reboots it will be forced to reinstall the touchpad because it will recognize it as a new device and want to install drivers for it. If it asks to search windows update for a fresh driver, allow it and let it finish the install. See if that corrects the problem. If it is mechanical in nature, then the palmrest is going to have to be taken off and the touchpad button assembly underneath replaced.
Posted on Oct 06, 2009
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
Touch pad not working
Click Start/Control Panel andlook for the Mouse and open it to check the mouse properties. Make sureyou don't have the touchpad disabled.
Some models will allow you to toggle the touchpad on or off by clicking on thebutton that is located at the top of the touch pad in the middle.
Some models will allow you to toggle the touchpad by tapping twice in the upperleft hand corner of the touchpad.
Some models will require a keystroke to toggle the touchpad. Press andHold the ALT or FN function key located at the lower left portion of thekeyboard, then hit the key that toggles the touchpad. The correct key tohit will have the icon of a finger pointing at a square that represents thetouchpad.
Download and reinstall the touch pad drivers.Get online and got towww.google.com In the google search box type: "Acer Support"(without the quotes and put your manufacturer name before Support). Lookfor downloads and drivers. Enter your model number and operating system whenrequested. Download and install the Touchpad drivers.
Jun 04, 2012 | Computers & Internet
My Dell Vostro 1014 laptop's touch pad does not work!! The buttons work fine but I'm having problems with the pad. The drivers are up to date and the application used to control the touchpad c
If you have a external mouse, or you can borrow, go into device manager to see if the pad is enabled, if okay! try a system restore bringing the computer back in time before this happened, if still no luck the sensor pad maybe defective, the last option a complete recovery of the operational system to factory setting, this will prove if the sensor pad is defective, or wire ribbon might have come loose from the motherboard.
Apr 01, 2012 | Dell Vostro 1014 Laptop Computer
Sencitivity of touch pad how to adjust
Nearly every modern laptop computer comes with a touchpad for on-screen interaction. Depending on your operating system and touchpad driver versions, you can update the speed, sensitivity, tap speed and clicking functions of your computer's touch pad. Accessing these settings and updating them to meet your needs is a quick and easy process with both the Microsoft Windows and Apple OS X operating systems.
Change Touchpad Settings in Windows1. Open the Control Panel by clicking the Windows Start button and selecting "Control Panel." Depending on your Windows configuration, this option may be located within the Start Menu's "Settings" sub-folder.
2. Double-click the Control Panel's "Mouse" icon.
  • 3. Click the Touchpad tab. This tab can have one of several names, depending on your computer manufacturer, your operating system version and your device drivers. However, the most common labels include "Touch Pad," "Device Settings" and "Dell Touchpad." If you do not see any option resembling these, you may not be able adjust your laptop's touchpad settings. Refer to the "Warnings" section if this applies to your computer.
  • 4. Locate the "Scrolling Settings" area within the touchpad properties tab. Adjust the settings to meet your needs and then click "OK" to close the dialog boxes and confirm your changes.
  • for MAC OS
  • Click the Apple menu and then select "Preferences."
  • 2
    Click the "Keyboard & Mouse" icon.
  • 3
    Select the "Trackpad" option from the top of the Keyboard & Mouse dialog box.
  • 4
    Adjust the trackpad settings to meet your needs, and then close the dialog box to confirm your changes.
  • Dec 01, 2011 | Computers & Internet
    Touch pad is way too sensitve and any hint of accidentally touching it send mouse and/or characters all over the place. Makes this computer very difficult to use.
    Try these steps:
    1. Go to the Control Panel and double click on Mouse
    2. Go through the tabs in Mouse Properties window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
    3. On that tab, find the "Sensitivity" setting. Try changing this setting to lower the sensitivity of the touch pad to the degree you find acceptable.
    4. Click "Apply" to apply the changes, then close the "Mouse Properties" window.
    May 16, 2011 | Sony 4-660-223-01 Touchpad Keyboard
    I was just working on my laptop using my touchpad mouse. I'm sure I accidently hit a button but I didn't think I did. Well anyways, the pointer stopped responding and the orange light in the top...
    many touch pads have a switch that you can toggle on and off to turn the touchpad on and off. It is usually in the immediate area of the touch pad.
    May 11, 2011 | Computers & Internet
    How do you turn off the touch pad
    Some notebook users find the touch pad annoying because at times, while typing fast, their thumbs accidentally brush up against the touchpad. This is frustrating because the mouse cursor jumps to a random location on the screen and can cause undesirable things.
    To turn off the touchpad when an external mouse or other pointing device is present, you can goto the Control Panel and double click the Mouse properties icon.
    Click the Device Select tab and check "Disable Touch Pad when USB Pointing Device is present." The cursor will no longer move via the touchpad.
    Oct 24, 2010 | HP Pavilion dv4000 Notebook
    Dell Inspiron 1501 Touchpad locked up
    Check the system setup F2 at start, and ensure the touchpad is enabled, next try an external mouse, see if it works.
    If and external mouse works, the touch pad has failed and a new palmrest is needed.
    Jul 29, 2009 | Computers & Internet
    Lenovo touch pad not working properly
    Have you tried pressing the Fn + F8 keys? This combination is used to disable and enable the mouse pad.
    May 27, 2009 | Lenovo IdeaPad Y510 Core-2 Duo: Y510...
    Computers & Internet Logo
    14 people viewed this question
    Mohammed Ebrahim M
    Mohammed Ebrahim M
