Question about Dodge Durango PS10042 Cherokee Map Sensor
Where is the map sensor in a 2007 dodge Durango
    Master:
  • 443 Answers
Where is the map sensor in a 2007 dodge Durango - 86c6bedc-7a24-415a-af04-f8aa8974383b.jpg Left front of intake area
Posted on Apr 07, 2014
  • Johnathan Lence
    Johnathan Lence Apr 07, 2014
    I'm sorry right front of intake
Code p1296,p0108,p1494,p0500 on 2000 durango, what most likely wrong?
P1296 No 5-Volts to MAP Sensor
P0108 MAP Sensor Voltage Too High
P0500 No Vehicle Speed Signal Circuit
P1494 Leak Detection Pump Switch or Mechanical Faul
I would try MAP sensor first.
Mar 18, 2014 | Dodge Durango Cars & Trucks
P0123 and p0068 on a dodge durango 2007
P0068 - MAP/MAF Throttle position correlation
P0123 - Throttle positon sensor/Swtch A Circuit high input
Nov 07, 2013 | Cars & Trucks
IAIR FLOW SENSOR LOCATION 1998 DODGE DURANGO 5.9
Your vehicle is not equipped with a Mass Air Flow (MAF) sensor, but it does have a Manifold Absolute Pressure (MAP) sensor. Here is a picture of where it is located.
93_cr99duran_14-030b.png&width=560&height=467&displaytype=display&imgrotation=&links=
Sep 21, 2012 | 1999 Dodge Durango
2000 Dodge Durango 5.2L V8 starts but won't run
By run - do you mean it dies when you put it in gear? Or that it just bogs down when you attempt to accelerate or drive away?
A plugged Catalytic converter will cause this. So will a Bad MAP or MAS (Mas Air ) sensor. So will a bad TPS (Throttle Position) sensor.
Need more input to answer more precisely.
Jul 25, 2012 | 2001 Dodge Durango
My 1999 Dodge Durango all of a sudden will not shift out of 1st gear and is consequently eating up tons of gas. Can you help me fix this problem?
Have your mechanic check your map sensor and your vehicle speed sensor as they could possibly be the cause.
Sep 01, 2011 | 1999 Dodge Durango
Does a 2002 dodge Durango with a 4.7L engine have a mass air flow sensor and if so where is it ?
No mass air flow sensor but if you are talking bout MAP-Manifold Absolute Pressure Sensor
The write up is right here
http://www.ehow.com/how_7974375_replace-1999-durangos-map-sensor.html
Hope this helps
Positive Feedback ALWAYS Appreciated :)
Mar 06, 2011 | 2002 Dodge Durango
I want to know how to replace the oxygen sensor in my dodge durango 2007
Locate the faulty sensor. Disconnect the wiring harness from the plug, use the special socket to remove the old sensor, apply anti seize lubricant to threads of the new sensor, install new sensor first hand tight then again use the special socket to turn it an additional quarter turn, connect the new sensor's plug and clear the fault code in the computer.
Oct 09, 2010 | 2007 Dodge Durango Night Runner New Cars
How hard is it to replace the MAP sensor on a 2001 dodge durango?
VERY SIMPLE!!!!!
4.7L The MAP sensor is located on the front of the intake manifold. An O-ring seals the sensor to the intake manifold.
  1. Disconnect electrical connector at sensor.
  2. Clean area around MAP sensor.
  3. Remove 2 sensor mounting bolts.
  4. Remove MAP sensor from intake manifold.
To Install:
  1. Clean MAP sensor mounting hole at intake manifold.
  2. Check MAP sensor O-ring seal for cuts or tears.
  3. Position sensor into manifold.
  4. Install MAP sensor mounting bolts (screws). Tighten screws to 3 Nm (25 inch lbs..) torque.
  5. Connect electrical connector.
Apr 23, 2010 | 2001 Dodge Durango
Getting a code p0121on my dodge durango 2001
Trouble code P0121 means: Throttle Position Sensor Voltage Does Not Agree With Map Sensor. You can replace the TPS for @ $30 from Autozone. Please vote appropriately and leave a comment. I hope this helps and Good luck.
Oct 29, 2009 | 2001 Dodge Durango
What Happens When a Map Sensor Goes Bad on 2001 dodge durango?
Manifold Absolute Pressure sensor controls fuel delivery and ignition timing, the pressure in the intake manifold will vary due to stress or work load, the MAP sensor monitors this, reporting to the computer. Good luck.
Jul 12, 2009 | 2001 Dodge Durango
Dodge Durango PS10042 Cherokee Map Sensor Logo
46 people viewed this question
Top Delphi Vehicle Parts & Accessories Experts
Doberman
Tom Chichester
Are you a Delphi Vehicle Part and Accessory Expert? Answer questions, earn points and help others
