Question about Hotpoint Washing Machines
HOTPOINT ULTIMA WMD942 ERROR CODE F05
ERROR CODE F05 WHAT DOES THIS MEAN?
  • 7 Answers
SOURCE: HOTPOINT ULTIMA 1200 WM72 Error Code
f30 code means there is a problem within the motor curcuit,check connections at the motor and check motor brushes are not worn.
Posted on May 18, 2008
barkencoa
  • 3463 Answers
SOURCE: error f05
Check that water is draining out o/k and that the outlet hose is not kinked or restricted.
Make sure pump is o/k.
if it has a removable filter at the front, then remove and clean.
If no exterior filter, then remove rear panel of waher, locate pump at bottom right of m/c. undo the clip that secures the large black hose to the bottom of tub, and remove the hose.
Remove and clean plastic filter inside the hose.
Refit and make sure the hose is on properly, test for leaks.
Hopefully, this will solve the prob.
Plz rate my solution.
Thanks.
Posted on Jan 06, 2009
SOURCE: Hotpoint WT965 ultima fault code
I have a ultima WMD940 won't drain and comes up code F05. Please can you help my washing is piling up
Posted on Jan 07, 2010
  • 118 Answers
SOURCE: have an hotpoint ultima wt940
  • F05 - Pressure switch jammed on full - Check pump for blockages.
  • I would recommend you pull out your machine and check the drain pipe and pump hope this helps.
Posted on Feb 21, 2011
rickead1
  • 1998 Answers
SOURCE: error code f05 hotpoint ultima
In your service manual it states F05 - Pressure switch jammed on full many times I find this is due to a blockage in the drain line and if you take and clean out the drain line it usually alleviates the problem most of the time due to this error. I also find that while doing this it is best to also check the drain line that comes off the water opump as well as the one that goes from the bottom of the tub to the pump as well. Also checking the pumps impellar that it does spin freely assures future useage without problems for a much longer time with your washer. If you have any further questions message them back. Please also remember when our chat has fully concluded to rate how this opinion has helped in your appliance situation. By doing this it allows me to continue helping others in similar situations in the future.
Thank you
Rick
Posted on Nov 14, 2011
Have an hotpoint ultima wt940 an error code of f05 came up.how can i fix it?
Jan 22, 2011 | Hotpoint Ultima WF860 Front Load Washer
F 05
Hello,F05 means that the pump is not getting rid of the water.
You to locate and clean the filter, and or check the pump for a blockage or restriction.
Thanks
May 23, 2010 | Hotpoint Ultima WF860 Front Load Washer
Machine stopped mid cycle with water still inside and the panel is saying FO/5
F05 means you have a pressure switch fault, check the pressure chamber or pipe also the wiring from the switch. For more Hotpoint, Creda or Idesit error code definitions use this link
Mar 18, 2010 | Hotpoint Ultima WF860 Front Load Washer
Error Code F-05
Error code F05 denotes pressure switch jammed on full.
Remove lower rear cover of washer.
Remove large black hose on bottom of drum.
Remove and clean filter inside hose.
Refit back and test.
Please rate my solution.
Thgankyou.
Feb 04, 2010 | Hotpoint Ultima WF860 Front Load Washer
Coming up on screen F05
Error code F05 means pressure switch jammed on full.
Locate and remove large black hose fastened to bottom of drum.
Remove hose onto pump, and check for blockage or obstruction here as well.
This should solve the problem.
Please leave feed back.
Thankyou.
Jan 10, 2010 | Hotpoint Ultima WF865 Front Load Washer
Cycle does not finish door wont open error code f05
F05 means pressure/\waterl level switch is jammed on full.
Remove lower rear panel of washer, locate and remove large black hose fastened to bottom of drum.
Remove and clean plastic filter inside hose.
Remove hose onto pump, and check for obstruction here and in the pump.
Thanks
Nov 12, 2009 | Hotpoint Ultima WF865 Front Load Washer
Hotpoint WF860 Washing Machine displaying error F-65
there is no F65, perhaps it's F05 which means it will not empty water (not oumping out). Should av gone to specsavers !
Apr 12, 2009 | Hotpoint Ultima WF860 Front Load Washer
WD865 Hotpoint - F-05 error
F05 means that the pressure switch is jammed on full.
You need to check the pump is pumping out o/k, and if there is a filter, check and clean.
Jan 11, 2009 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint WT965 ultima fault code F05
Aug 27, 2008 | Washing Machines
Washing Machines Logo
168 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
freddyfox
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
