Question about Sanyo DP42746 42 in. Plasma Television
I have no pictur
I have to unplug the ymain flat plug
  • Sanyo Master
  • 5,568 Answers
Please see this thread:
Sanyo failure
Posted on Mar 20, 2009
Panasonic TX-L42E5B tv sound working but screen is black
It can also be the YMain board or the back light inverter board or a capacitor or fuse has blown on the power supply board. Which you usually lose sound before you lose both sound and picture. Try to hard reset is for about 4-6 hours by completely unplugging it.
Mar 25, 2014 | Panasonic VIERA TX-L42E5B 42" LED TV...
How do I fix this Sanyo 1080 P flatscreen with a white line and a color problem to the right of the screen
i believe white line is caused by bad or dirty connection on upper buffer which is either connected to ymain pcb or built onto pcb.color distortions can be caused by bad ymain pcb or x pcb.hope this helps.
Mar 16, 2013 | Televison & Video
My LG Plasma television DU-42PX12XC had a loud pop
Your tv contains protection circuitry that would shut down the tv if the ymain was out. If the ymain had blown, you'd have no sound and just a flashing standby light. My gut tells me you need to replace the Power Supply Board (PSB). I've seen this before and after spending too much money trying to diagnose a ymain failure, I was surprised to learn that when you have sound but no picture, the psb is a gonner. Try ebay, shopjimmy.com or discount-merchant.com for a replacement.
Good Luck!
Apr 20, 2010 | LG DU-42PX12XC 42 in. Plasma HDTV
50" Maxent Plasma TV now takes almost 5 min to "warm up". Starts black then flickers to a decent picture
you need to have a licenced repair tech come look at it sounds like the inverter is going out its kinda likea ballast for florecent lights
Oct 28, 2009 | Maxent MX-26X3 Television
I bought this tv broken....original problem was
Anytime you replace the Ymain, it's recommended that you replace both Y upper and lower buffer boards also. Most likely you've damaged the Y again, so I would re-order all 3. In thte future unplug the P/S plug to the Y section and leave it discharge for about an hour before plugging it back in.
Aug 13, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
Picture problem
You need to replace the Ymain and the buffers. This is a very common problem with this set, and its magnavox and samsung counterparts. Look throught the other solved postings for a detailed description of how to dismantle and replace. Plan on spending at least $200 on this repair. Likely a bit more.
Jul 26, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
I have a phillips 42pf7220a/37 and 7 blink led
The Ymain Board is out if you have the back of the tv exposed disconnect the ymain board and then plug in the tv set and turn it on. the light should remain green and no longer flash. If this happens the Y main and upper and lower buffer boards should be replaced
Jun 15, 2009 | Philips Televison & Video
Hi, had a question about what you said, have a minute?
You need to replace the top and bottom y buffers when you replace the Ymain. If not, it will just go back out. If you have space, wire a 12 volt mini cpu fan near the left of the Ymain and the buffers, should last alot longer that way.
Jan 22, 2009 | Sanyo DP42746 42 in. Plasma Television
Samsung S4253- No Image, Only Multicolored Pixels; Sound OK
I had the same problem. Luckilly I had an extended warranty. Repair tech said it blew three main boards inside and to fix it out of pocket would have been more than the screen was worth. Hope this helps.
Jun 24, 2008 | Samsung HP-S4253 Television
Phillips TV- Plasma Model #42PF7220A/37
A tech will need to come out. When the tech do come out have him unplug the Y main and see if the led goes solid greem if it does have them replace the Ymain and the Y upper/lower boards. Most likely that will be the problem.
Feb 29, 2008 | Philips 42PF9630A 42 in. Plasma Television
Sanyo DP42746 42 in. Plasma Television Logo
167 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
