Question about HTC Merge Smartphone
To turn on the htc merge if power button is broke
How do you unlock a HTC Merge 2.1
Hello. You can unlock a HTC Merge model cell phone safer and easier using unique unlock code. You can get the unique unlock code for a HTC Merge from SuperUnlockCodes.com at affordable cost with an easy unlocking guide. Good luck.
Dec 16, 2014 | Cell Phones
My htc merge is just stucked on blank htc when i turn it on please help me
are you able to get into recovery mode?
With the phone turned off, Hold the 'Volume Down' button and the power button until HTC logo appears and 'Entering Recovery Mode' appears at the top in pink.
If you can access recovery then it could be possible to reset/reinstall android OS
Dec 11, 2014 | HTC Merge Smartphone
Htc merge wont pick up on wifi hotspots
You have to turn it on in the settings menu under manage WiFi.
Apr 09, 2014 | HTC Merge Smartphone
Power button wont turn
Soft reset by removing the battery, wait 20 seconds and reinsert.
If this does not solve the problem...
1. Remove the battery, wait for a few seconds, then reinsert the battery to turn off your Merge.
2. Press and hold the VOLUME DOWN button, and then briefly press the POWER button.
3. Wait for the screen with the three Android images to appear, and then release the VOLUME DOWN button.
4. Press VOLUME DOWN to select FACTORY RESET, and then press the POWER button.
If none of this works, get a new phone, hopefully you have the insurance.
Dec 17, 2013 | HTC Cell Phones
My htc merge can't get a signal
If you have just unlocked you phone by IMEI it is possible that you have no data connection. You can check here to see if it solves your problems. It is possible to be something related with the APN settings.
http://support.htcimeiunlock.com/entries/20118711-successfully-unlocked-my-htc-but-i-have-no-data-connection
Jan 22, 2013 | HTC Merge Smartphone
Why wont my htc merge turn on?
Have you tired leaving it to charge overnight ? You could remove the battery for a while then try plugging it in and try to turn it on.
Nov 18, 2012 | HTC Merge 6325 Plastic Case - Plaid Design...
I cant unlock my htc merge
TRY CODE FROM SERVICE PROVIDER......
Sep 26, 2011 | HTC Merge Smartphone
POWER BUTTON BROKE
The power button is broken and jammed. change it , everything will work fine.
Jul 24, 2009 | HTC PPC-6800 Smartphone
HTC Merge Smartphone Logo
161 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
