Question about Philips Magnavox 9P6034C 60" Rear Projection Television
Replacing the coolant on a Philips 9P6031 C103 rear projection TV
I am cleaning the "fungus" from the crt coolant on my Philips 9P6031 C103 rear projection TV. It had a very heavy coat of the junk. The concave lens that seals the coolant in the chamber is "etched" on the coolant side. It dries looking like hard water droplets on glass, however it is definitely etched into the surface of the lens and will not wash off. I need a part number for this lens piece and the name of someone that carries the part.
I reassembled with new fluid and picture is near new quality. Maybe the etching is not that important. Comments?
  • Philips Master
  • 3,459 Answers
Www.TvRepairKits.com may have some spare tube parts including the lens.
Hope this helps,
Posted on Mar 15, 2009
Tv has a red tint
the most common cause would be the CRT coolant need replacement in the green and blue CRTs which make the red dominate. Replacing the coolant is the number one cure for that problem. Do not try adjusting the screens as that will only lead to more problems with a phillips. CRT coolant is all thats required.
Nov 21, 2011 | Philips 50P8341 50" Rear Projection...
How hard is it to change the cooling fluid in phillips projection tv.
The CRT coolant change is all mechanical which involves removing the crt and disassembling the coolant chamber so it can be cleaned then reassembled and filled with coolant the phillips CRT coolant kit from www.tvrepairworld.com has the coolant and the instructions for the repair on cd
Jul 31, 2011 | Philips 60PP9352 60" Rear Projection...
I just bought it and it is fuzzy and all the white has a glow around it
U bought this tv used right,hope u pay it cheap?Ur tv have CRT coolant porblems.It have CRT coolant contamation,must replaced the coolant.Tries Websites Tv repair World.com,Tvrepairkits.com to buy the CRT coolant kit to replaced.
Mar 30, 2010 | Philips Magnavox 9P6034C 60" Rear...
I have a phillips magnovox 9p6031 c103 rear projection tv. At first the screen would shrink and have an orange look, when I would go through the convergence re-set it would clear up, now the tv makes a...
This problems is the cause of 2 Convergence is dead also.Know how to solders?Buy a convegence kit at Tv repair World.com,Tvrepairkits.com to repair it ur self.The shop will cost u $300 for parts and labors.
Nov 29, 2009 | Philips 46PP9302 46" Rear Projection...
Magnavox Philips 60" 9p6031 c103
deflection problem very common on that model. You can get a new LSB board at the following link, leave them a email and they will respond quickly with a price quote for the LSB if they dont have it listed already, they are cheaper than anywhere else for replacement boards for phillips, RCA and GE. Heres the link.
http://servicemanuals.vstore.ca/
Jan 24, 2009 | Philips Magnavox 9P6034C 60" Rear...
I have a Philips Magnovox 8P6044 C101 60" rear projection tv that appears dim and slightly blurry. Waht are the suggested fixes and what would be a range of repair costs?
as far as the foggy / blurry appearance goes, you more than lkely have contaminated CRT coolant. This coolant (inside the lenses) should be crystal clear, and normally over time, with heat and time the crt's will grow a sort of bacteria in the coolant. I have drained crt's and the coolant has looked like applesauce before. Once you clean the crt's and replace the coolant with new coolant, the pic should be just as good as new!
Nov 29, 2008 | Philips Magnavox 51MP392H Rear Projection...
60inch big screen philip t.v picture looks kind of orange in picture
crt coolant it tube is contaminated with a orange like fungus which is orange in color new coolant is needed.
May 01, 2008 | Philips 60PP9352 60" Rear Projection...
60 inch phillips magnavox projection tv
CRT coolant change and advanced convergence - how to
I documented the procedure I did on a Philips 55" rear projection 55p916
http://tinyurl.com/lmp6eu
CRT coolant change procedure
http://tinyurl.com/l7bd7r
basic and advanced convergence
Dec 24, 2007 | Philips Magnavox 51MP392H Rear Projection...
60# ptv810 aho1
yes it is , Sounds like your Convertions is out and need to be set.
Nov 21, 2007 | Philips Magnavox 9P6034C 60" Rear...
Blury picture, convergance problem
What you're describing is probably contaminated coolant in the crts. Between the outer part of the crt and the lens is a chamber filled with a coolant (ethyl-glycol) which can become contaminated and cause blurred picture. I'd strongly recommend taking this to a shop the procedure for changing these is a bit beyond the layman level.
Remove Crt assembly. Mark the Crt lens position for accurate reasssembly.
Mark the centering ring's postions to make easier realignment and carefully remove lens assembly by removing the four torx screws. Keep Crt assembly vertical so you won't leak the fluid...
Remove the inner lens by carefully prying up on the edge of it.
Dump out the fluid in the sink and wash the face of the Crt and chamber with water to remove all the fungus and crud. Flush the chamber with isopropyl alcohol to kill all the fungus and dry thoroughly.
Reassemble inner lens and outer lens and tighten all four torx screws.
Remove side filler plug and fill chamber with approved new Crt coolant, reinstall and converge.
Repeat this procedure for the other two Crts. It will need this done whether it looks clear or not !! The green and blue Crts in this unit are prone to this failure.
Hope this helps
Bill
Nov 14, 2007 | Philips Magnavox 51MP392H Rear Projection...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
357 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
