Instructions for ykr f06 remote - Heating & Cooling
YKR-K/002E cant switch it off with remote?
Make sure the batteries in the remote are good. Reset the aircon and the remote and try again. If not working, need to be fixed.
There may be a switch around the outdoor unit of the aircond for switch off.
Feb 25, 2014 | Heating & Cooling
Need instructions for remote AUX ykr-f/06
anyone have a manual book for a remote control aux ykr-f/06 cant set the timer could anyone scan and send a copy to bug-it@hotmail.com plez
Jan 23, 2013 | Heating & Cooling
Indesit 123 FAULT F06
I had this error and engineer said the meaning of the codes on the web are wrong as they don't like to disclose their real code meanings for pure protectionism reasons. F06 on IWD7145 is a burnt out door interlock IDC error. He replaced the part number C00085194 (replacement door interlock) and microritardator part number 085194 and it works ok now.
Sep 06, 2012 | Indesit W 123 Front Load Washer
I have a conia YKR-F/06 air con & my remote wont work, can u turn it on from the unit itself?
Some units having manual button in unit itself. But you can't change temp setting or mode setting by that. It's advisable to get new remote and operate this. Thanks.
Dec 31, 2010 | Heating & Cooling
Trying to understand the continuity check for F06 error
When you do a continuity check you do not have it plugged in. It is best to unplug at the motor so there is no feedback.
Jul 07, 2009 | Whirlpool Duet GHW9150P Front Load Washer
F06 error
Unplugging it sometimes corrects the problem. However, it must be unplugged for SEVERAL minutes.then start it again i think it ll set it ok becuase sometimes it all sets it right.
or
Check the wire harness that goes to all your connectors on the Motor, MCU, and CCU. I have seen a loose wire connector do this F06 error.
If all checks ok, then its like a faulty CCU, check your owners manual, some are covered under warranty for up to 5 yrs.
now check the CCU,MCU and Motor any one of these must be faulty that will only lead to F06 error.
Jun 19, 2009 | Kenmore 45087 Front Load Washer
Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Nov 22, 2008 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Heating & Cooling Logo
210 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
