My desktop dissapaired there is only the my computer screen
You can access alot of other things on my computer but it is long and hard
  • 135 Answers
Maybe the speed of the system using this computer is not right, I might advise you to reformat or refresh the operating system of your computer. Check also if you have enough space to hard drive, maybe you do have files and games or application into it.
Posted on Mar 11, 2009
Is the Lenovo 23" All-In-One Touch Screen Computer 57317005 a good gaming computer
Nope. The Intel graphics card is hardly game worthy. Do not use this for a gamers computer.
Nov 01, 2014 | Lenovo C540 Touch 23" Touch-Screen...
I have an emachines ET1331G-07w.....I cannot boot up windows. My screen is black and reads.......Reads......Reboot and select proper boot device......Tried alot and have no solution?? TY
Usually this error message means the computer doesn't "see" your hard drive. Remove the power cord then remove the side panel of the computer case. Check that the hard drive power cable and data cable are both plugged in firmly to the hard drive and to the motherboard. Plug the power cord back in and try booting up.
Nov 19, 2013 | E-Machines eMachines Desktop PC
ACER not booting up, safe mode message, blank screen
possibly you can remove the hard drive and connect it to another computer and access it that way, just connect it and boot the computer as normal if the drive is not corrupted you should be able to access it and save files such as pictures and documents to the other computer if he's wanting to save installed programs he is out of luck unless he has downloaded and saved the installer file or .exe cause installed files and programs can not be saved.
Feb 10, 2013 | Acer Computers & Internet
I have a Dell 2400 Desktop that all of a sudden won't access the login screen. It powers on then the hard drive makes noise with the green lights blinking but it then says press F1 to continue but
First thing, check to see if the is a floppy disk in the floppy drive, if so removes this disk. If there was no disk in the floppy drive then it may be a hard disk problem.
Check the BIOS to see if the hard disk is detected, if not open the case and re-seat the data cable on the hard drive and also where it connects to the motherboard disk controller.
If it still gives this error message and the BIOS does not detect this hard drive, then the hard drive is probably faulty.
To get the computer operating again, install a new hard drive in your computer and then install Windows on this hard drive plus the computer's device drivers and your programs.
Nov 05, 2012 | Computers & Internet
Black Screen of DEATH
well try finding someone who repairs coumpters from their home it is alot cheaper. explain your problem they should tell you weather they can fix it
Jun 30, 2012 | IBM NetVista PC Desktop
Windows has shut down to prevent damage to computer, Blue screen comes up every time and cant access not even in safe mode. -Error Codes: 650f : 0244 & 650f : 1A44 -Message: 185076...
Hello
This is a hard drive failure.Try holding down the f8 key while booting up and choose command promt.
Once there use Chkdsk .
Here is a link that explains how.This will check the drive and possibly repair it.If not you will need a new hard drive
http://support.microsoft.com/kb/315265
Aug 01, 2011 | Computers & Internet
The computer powers on but will not pass the compaq bios screen, i cannot access bios either, it is totally frozen???
It may be a number of things but first I would try the poer supply as if the voltage is too low as the computer tries to load it draws more power and will seize up, next I would try some new RAM as if there is no available RAM the computer cannot function.
If it were the hard drive, I would expect a hard drive error report.
Oct 23, 2010 | Compaq PRESARIO SR1475CL AMD Athlon 64...
Okay so first off I have ALOT of important docs and what not on my laptop so it is a must that I require these items ! okay So I just got back from Denver and had used my laptop only once and it worked...
Sounds like a graphic card problem. You should be able to remove your hard drive and connect it to a desktop computer and access the drive and get your important files.
Aug 06, 2010 | Toshiba Satellite A215-S5837 Notebook
Blank desktop
I had this problem also, I found that running windows update and getting vista SP2 solved my problem. If this doesn't work, after you login in and you get the welcome screen with the spinning circle hit ctrl+alt+del and log off, then re-type your password and it should work, but you may have to do this a few times. I hope this helps! put a comment down if you need more help!
Jul 24, 2009 | Gateway 700 XL PC Desktop
My mom has a lenovo 3000 j series computer, it just keeps running through start up, do you know how to wipe it clean and where do i find all the disks reinstall everything
Tap F8 while booting up to gho to the boot select screen. Choose safe mode. After you get in with safe mode, use the utility system recover. THis is found in START->ALL PROGRAMS->STYSTEM RECOVERY->SYSTEM RECOVERY. From there, just follow the onscreen help
Apr 16, 2009 | Lenovo 3000 J Series 2.10G Xpp PC Desktop
Computers & Internet Logo
16 people viewed this question
David Payne
David Payne
