Question about Casio Wave Ceptor WV57HA-1AV Wrist Watch
I have watchWVA-105H.I had the battery replaced
I have watch style WVA-105H. Module number 2735 I had the battery replaced when it stopped working and now only the digital screen works. I have tried all the methods from the manual,but no luck. span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
  • 916 Answers
Please check the manual for battery placement. Then please replace any batteries the watch may have and see if the problem is still there.
Posted on Apr 04, 2009
    Sergeant:
  • 320 Answers
Clean the area where the battery is inserted in the watch. clean it with isoproyl and tissue paper.
Posted on Mar 24, 2009
    Brigadier General:
  • 3,614 Answers
remove again the battery into the slot and re-seat it again
  • 495 Answers
If your watch has any kind of illuminated dial or dial light, you may have found the battery for that instead of the one powering the watch itself. I have one similar and did that same thing only to find that the watch still wouldn't run. The battery that powers the illumination is larger and in my watch, the battery for the watch portion is half the size and located below and to the side of the other cell.
    Sergeant:
  • 300 Answers
Check out the internal mechanism it will be dust inside and needs cleaning as the digital screen works that means battery is proper.
  • 412 Answers
I think ro replace some wrong battery.....
double check the new battery ........
Ive got a Casio 2735 wva-105h watch that Ive had since 2004. Its Been 10 years and still havent needed to change the battery yet and still fully functional. Is it Solar or anything like that? How is i
Hi Paul
Yes this has a battery, it sounds like you are one of the lucky ones that hasnt needed to change it yet, there life span is approximatley 10 to 15 years before they need changing, so either yours is in the 15 year catagory or its comming up for a change...hope that helps
Nov 25, 2014 | Casio Watches
Why does my Wave Ceptor WVA-105H work sporadically after getting wet?
Try a new battery. When water got in there it may have shorted the battery and drained it. It may work for a short time and then die. Also put the watch on you car dashboard in the sun to bake it instead of the oven unless you have an electric oven. For electric oven use a thermometer to get temp of 140 F then turn the oven off and put the watch in for an hour.
Aug 16, 2014 | Casio Watches
Need a back seal for Casio WVA-105H
mcdevito75 here, Look for any small watch repair shop in your area, they will sell you a new o"fing for the back cover of your watch.
Jul 16, 2010 | Casio Atomic Timekeeping Waveceptor Watch...
Problem with WAVE CEPTOR watch band
http://world.casio.com/wat/download/en/manual/
There are so many applications use of the manual will be mandatory.
Use the four numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
http://antiqueclock.clockstop.com/
May 06, 2010 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Manual for watch casio wva-105h
Click on my profile (escapement), then click on Tips and Tricks. There you will find links to all watch manuals. Rate me, please .
Apr 15, 2010 | Casio Watches
Casio Waveceptor 2734 WVA-105H watch not working
You can use the manual to manually reset the time. After you succeed in setting UK time zone, wait until midgnigth: it should synchronize itself with the time signal from Germany. If unsuccessful to do so, it will keep attempting to synchronize itself at 1, 2, 3, 4, and 5.
Read the manual to figure out how to place the watch on a window sill. It might be better to be outside.
Keep in mind that the success of the operation depends on meteorological conditions.
Good Luck.
Feb 05, 2010 | Casio Watches
Waveceptor watch WVA 105H. Reception indicator had disappeared from the display this morning, so I attempted a manual receive. After about 5 minutes the flashing display was replaced with...
I have a wave ceptor casio watch 2734 model WVA 105H, however I've lost the manaul. I have a problem, the digital time reads correctly but analogue time is incorrect. How do I move the hands to the correct time? If you could find a solution it would be most appreciated.
Aug 15, 2008 | Casio Watches
Casio Wave Ceptor WV57HA-1AV Wrist Watch Logo
98 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Ansel Alberto
Ansel Alberto
Are you a Casio Watch Expert? Answer questions, earn points and help others
