Grey bottom third of tv mostly,if goto xbox button it is normal blue
Hi 1/I have a transonic 49" about 2years old and it occasionaly flashes blue but then turn tv off and then on and then most of time ok. 2/ the picture though shows the bottom third in grey ,sometimes a smaller line of grey just appears in middle. Any ideas would be most appreciated
  • 41 Answers
SOURCE: TV has line down the middle
Remove the front sceen and check for a cob web acrossone of the px tubes, is one possible cause of your problem.
Posted on Jul 05, 2007
  • 6 Answers
SOURCE: Flickering blue picture
I finally got around to dismantling the TV. This is no mean task. The chassis is tethered to the rest of the set my over a dozen wiring harnesses and a few of these cannot be disconnected near the chassis but instead require removing the “right support” near the air duct and taking the shield off the lamp ballast. Once the chassis assembly is out, it is a further significant task to disassemble it to get at the various PWBs (POWER, FMT and DM) having the suspect caps. I’m sure reassembling everything will be a fun job!
I have not yet had a chance to fix and reassemble but I wanted to post this no as I’m not sure when I will get around to it.
I did find six of the fourteen known-problem caps to be visibly bulging -- both 3300s and two of the four 1000s on the PWR PWB plus two of the four 1000s on the FMT PWB (see photos below). Ironically of the four 1000s on the DM PWB, which I have heard are the most common to go bad, were bulging and I considered skipping these as the DM it is the toughest board to extricate from the chassis, however I figured I had come this far and I would just as soon replace all twelve 1000 uFs as the parts cost $0.23 and I really never want to have to do this again.
If I had to bet, the two 10V 3300uF caps on POWER board, which were actually leaking black goo, are the actual culprits, but with four of the 1000 uFs also bulging it is probable only a matter of time until they failed as well.
Here is the POWER PWB with the known-problem caps (C9A37, C9A38, C9A51, C9A52, C9A61 and C9A62) highlighted:
here's the FMT PWB with the known-problem caps (C8F19, C8F21, C8F22 and C8F27) highlighted:
and the DM PWB with the known-problem caps (C81A2, C81A3, C81B3 and C81B4) highlighted:
Here are close-ups of the bulging caps (C9A37, C9A38, C9A52 and C9A62) on the POWER PWB:
And here are close-ups of the bulging caps (C8F19 and C8F27) on the FMT PWB:
Posted on Feb 16, 2008
  • 301 Answers
SOURCE: mistubishi WD-52527 52" LCD Projection TV
those are going to be dust spots on the LCD panels internal to the optical engine. i suggest that you take the screen off and take off the panel i nthe middle of the tv with 2 screws in it and there will be an area that has 3 metal fins covering thin orange ribbon cables. the 3 square objects at the end of those ribbon cables will be the LCD panels spray wiht air compressor unitl clean and that should greatly help your problem.
Posted on Feb 20, 2008
SOURCE: RCA- R52WH74
I had the problem with my rca looking like it was in 3d. anyways, I read this post and ordered the part ($3.79). did the soldering and TV works perfect now. Txs so much for the info on how to fix the problem. I was so worried it was going to cost a ton to have someone repair the TV. Much appreciated!
Posted on Apr 20, 2008
  • 8457 Answers
SOURCE: sony 2004 KF-50WE610 power/standby button flash doesnt turn on
turn ur tv off for awhile turn it back on it should work,But ur video board it was bad now it dead.
Posted on Aug 12, 2009
Why is my sanyo tv flashing green, blue, and red ?
i turned it on nd it was still like that nd i gt more mad. i was gna throw the remote bt i presed the menu button randomly once or twice i dunno bt it came back(normal tv)
hope that helps
Apr 11, 2010 | Sanyo DS31520 31" TV
I have a Philips flat screen HD ready TV for my xbox. I don't know what type though as my parents have upgraded to an LG and we now have this Philips TV. I have Sky connected to one of the EXT ports and...
Perhaps the Phillips TV isnt compatible with some of the Xbox Settings.
Or mabye when you adjusted your settings it may have affected any graphics.
Apr 07, 2010 | Microsoft Xbox 360 Console
When i connect xbox 360 arcade[new] to my tv can't it to play
have you switched the switch to hdtv and NOT tv on the back of the big grey ariel plug going into your 360 ? then turn your tv to the aux or av channel as it wont be on a normal channel ??
Jan 26, 2010 | Microsoft Xbox 360 Console
Sony 2004 KF-50WE610 power/standby button flash doesnt turn on
Aug 12, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Remote missing on old dominator garage door opener
This is the most complicated way I know of coding a remote and I am a tech. who does this all the time.
Turn power off. Wait 3 sec's & turn back on. Quickly press program button on back of box twice. Lights will flash, bottom light will stay on. Press program button twice, & No. 3 light will start flashing. Press and hold your remote button until light stops flashing. Code will be accepted.
Apr 11, 2009 | Sears Craftsman LiftMaster Chamberlain...
Xbox 360 not conectin to tv
try using the standard av cables, if that doesn't work then it's most likely a gpu hardware failure. call 1-800-4MY-XBOXand the can help.
Jan 04, 2009 | Microsoft Xbox 360 Console
Dell 1200mp
Hi jezzwhizz
You'll see that at the back of your Projector there is 2 VGA ports 1 in (normally blue) and 1 out ( normally grey ).
You are most probably using the grey one , switch it to blue.
May 06, 2008 | Dell 1200MP DLP Projector
Universal remote control
What is the make of your universel remote control.
Mar 14, 2008 | Televison & Video
Vivitek tv
I have a 56" model that I have had a similar problem. My bulb burned out in <90 days. Warranty was 90 days on the bulb itself. When the TV picture goes out, the indicator LEDS blink on and off.
Here is what you have to determine:
1) First cover the left LED with a piece of paper so that you can't see it blinking. I don't know if your layout is the same as my TV. You may have to switch the paper blocking the LED.
2) Pay attention to the other LED and READ its' flashing code. In my case, the code was 2-3. It would flash 2 times, pause briefly, then flash 3 times. This meant code 23. That indicated the bulb was burned out.
3) If you look in the manual, It does have a code list of some sorts to tell you of the codes and their meanings. Hope this helps.
Nov 20, 2007 | Vivitek V37835 46 in. LCD Television
Televison & Video Logo
11 people viewed this question
Top Televison & Video Experts
Electro Med Services...
